POV-Ray : Newsgroups : povray.general : 5D-Vector troubles... Server Time
1 Nov 2026 00:00:10 EDT (-0400)
  5D-Vector troubles... (Message 1 to 8 of 8)
Subject: 5D-Vector troubles...
Date: 18 Apr 2006 12:06:57
Message: <44450ea1$1@news.povray.org>
So, today, with my new keyboard finally set, I've begun working on a set of
macros which'll give me keyframe-functionality. To support all kinds of
parameters, I had decided to store everything internally in 5D-Vectors and
degrade them to whatever they should be. This was decided upon because
POV-Ray's Arrays don't like mixing of floats and dimensionally different
sized of vectors, and since 5D is the highest POV-Ray supports, I figured
I'd use that.
Anyways, looks like POV-Ray doesn't like the 5D-Vector that much, as it
complains that it's a color vector when it's trying to write it to disk. It
also doesn't respond properly to the dot-promotions (a la MyVector.x) when
using 5D and trying to access the filter or transmit channel. With properly
I mean that .t and .transmit access different parts of the vector.
Here's a quick code to showcase both these problems:
#declare Test = <1,2,3,4,5>;
#debug concat("t:",str(Test.t,1,0),"\n")
#debug concat("t:",str(Test.transmit,1,0),"\n")
#debug concat("t:",str(Test.filter,1,0),"\n")
#fopen _Out "test.txt" write
#write (_Out, Test)
#fclose _Out
The #debug showcase the dot-promotion-problem: it might be just a
design-decision, but I wonder why .transmit and .t look at different parts
of the vector. I understand that in 4D-Vectors, the fourth component is
often used for transmit instead of filter, but if I've got a 5D-Vector, .t
and .transmit should return the same component, no?
Finally, the last three lines show how POV-Ray doesn't want to write the
5D-Vector. You can comment out the debug-lines in case you're thinking that
the .filter-access somehow internally turns the 5D-Vector into a
color-vector, doesn't make a difference.
Anything I'm missing here? Shouldn't POV-Ray just take anything from 1D to
5D as data and only interpret it as color when it's used where color is
asked?
Tim
aka "Tim Nikias v2.0"
Subject: Re: 5D-Vector troubles...
Date: 18 Apr 2006 15:52:37
Message: <44454385@news.povray.org>
Tim Nikias <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> wrote:
> .t and .transmit should return the same component, no?
  't' does not mean 'transmit' even though 'transmit' starts with a
letter t. (The fact that it starts with t is just coincidence.)
Date: 18 Apr 2006 18:23:32
Message: <444566e4$1@news.povray.org>
Hm. What does the "t" stand for then?
Date: 18 Apr 2006 19:18:28
Message: <444573c3@news.povray.org>
  Nothing. It's just the common next dimension index denomination after
x, y and z.
Date: 19 Apr 2006 11:32:41
Message: <44465819@news.povray.org>
> x, y and z.
If .t is the common next dimension index denomination after x, y, and z,
it is likely that it stands for 'time'.  You know, the fourth dimension?
Tim Cook
Version: 3.12
Date: 19 Apr 2006 15:38:50
Message: <444691ca@news.povray.org>
  Maybe it originates from the tensor metric of the GToR. Of course in
POV-Ray it doesn't make too much sense to call it "time", but just 't'. :P
Date: 21 Apr 2006 15:36:46
Message: <4449344e$1@news.povray.org>
Well, even though I've learned that ".t" is not the same as ".transmit",
there remains the mystery of 5d-Vectors returning a parse error when trying
to write the vector to to disk. Intended behaviour? Something to be fixed
for 3.7? :-)
Tim
Date: 21 Apr 2006 17:05:00
Message: <web.444948731b20d58c6c4803960@news.povray.org>
> for 3.7? :-)
> Regards,
> Tim
> Homepage: <http://www.nolights.de>
I think intended error.  5D vectors are automatically assumed to be colour
vectors which can't be written directly. 2D, 3D & 4D vectors can be written
directly as long as they haven't been declared as colour vectors.  If
declared as colour vectors, they too create an error. The reason for this I
don't know, perhaps the developers can answer that one.
Consider:
#declare Test1 = <1,2>;
#declare Test2 = <1,2,3>;
#declare Test3 = rgb <1,2,3>;
#declare Test4 = <1,2,3,4>;
#declare Test5 = rgb <1,2,3,4>;
#declare Test6 = rgbt <1,2,3,4>;
#declare Test7 = rgbf <1,2,3,4>;
#declare Test8 = rgbft <1,2,3,4,5>;
#declare Test9 = <1,2,3,4,5>;
#write (_Out, Test1)
#fclose _Out
Test1, Test2 & Test4 write fine as they are assumed to be regular vectors.
Test3, Test5, Test6, Test7 & Test8 create an error because they are
explicitly declared as colour vectors.  Test9 creates an error because it
is assumed to be a colour vector of the type rgbft.
-tgq
