POV-Ray : Newsgroups : povray.general : Odd behavior in rendering of scene Server Time
12 Nov 2026 18:49:23 EST (-0500)
  Odd behavior in rendering of scene (Message 1 to 12 of 12)
Subject: Odd behavior in rendering of scene
Date: 30 Mar 2006 13:48:11
Message: <442c27eb$1@news.povray.org>
Hey all.
I recently upgraded my CPU from an Athlon XP 1800+ to 3000+.  Of course
I wanted to try benchmarking my system using POV-Ray.  I had stats for a
few old scenes of mine, so I chose one and rendered it in the latest
version of POV-Ray (3.6.1b).  Nice and fast, went from 1:04 down to
0:51.  Then I tried rendering it again, and it took 1:14.  The next
time, it took 1:25, then 1:34, then 1:41, 1:45.  Then it seemed to hover
around that value.  When I restart my computer and repeat the process,
it does a similar sequence.  The rendering time is always nearly the
same, but the parsing time gradually increases to a saturation point.  I
at first thought it might be an issue with the CPU, or memory, or their
operating at different clock frequencies.  That doesn't seem to be the
main issue, since it behaves in a similar way on our other computer, a
Dell, too.  I also did lots of diagnostic tests, and everything checks
out fine.  I think it may be an issue with POV-Ray itself.  Is it not
freeing up memory?  What's going on in there?  It's a fairly simple
little scene.  Other scenes where it's mostly rendering and doing little
parsing are a lot more consistent.  It doesn't seem to have anything to
do with the random number generation in the scene, because I tried it
without it, too.  If anyone can offer some suggestions or answers as to
what is going on, I'd greatly appreciate it.
Ben Scheele
Silmarillion: Ben's World
http://www.benscheele.com
Here's the scene:  (I've been rendering it at 320x240, antialias at 0.3)
camera{
   location 120*y
   look_at 0
   angle 40
light_source{ <50,300,20> rgb 1 }
background{ rgb .1 }
#declare r1 = seed(150);
#declare r2 = seed(200);
#declare r3 = seed(175);
#declare s = .35;
#declare d = .175;
#declare step = .25;
#declare E = 54;
#declare X = -E;
#declare EndX = E;
#while(X < EndX)
   #declare Z = -E;
   #declare EndZ = E;
   #while(Z < EndZ)
     #declare R = sqrt(X*X + Z*Z);
     #if (R <= E)
       #declare rot = 30*sin(d*R);
     box { -s, s
       pigment
{rgb<1+sin(d*R)+.3*rand(r1),.3+.3*rand(r2),1-sin(d*R)+.3*rand(r3)>}
       finish {phong 0.3 ambient 0.35}
     scale <step,1.5*rot+.001,step>
     translate <X,0,Z>
     rotate rot*y
   #declare Z = Z + step;
#declare X = X + step;
Subject: Re: Odd behavior in rendering of scene
Date: 30 Mar 2006 18:02:12
Message: <442c6374$1@news.povray.org>
Ben Scheele nous apporta ses lumieres en ce 30/03/2006 13:47:
> Hey all.
> Ben Scheele
Trying it with the current beta. My results using +b2
First render: Parse=26.978, bounding=15.011, trace=7:21
Second render:parse=26.788, bounding=13.859, trace=6:58
On an aging Athlon tbird 1400 and 512 Mb
I drive way too fast to worry about cholesterol.
Date: 30 Mar 2006 23:23:29
Message: <442caec1$1@news.povray.org>
Interesting.  Thanks for checking it out.  So it rendered faster the
second time?  Hmm.  Yeah, I remember when it used to take me 6 minutes
to render it.  It helps to have a few hundred MB of RAM free for doing
that scene.
-Ben
>> Hey all.
>> course I wanted to try benchmarking my system using POV-Ray.  I had
>> stats for a few old scenes of mine, so I chose one and rendered it in
>> the latest version of POV-Ray (3.6.1b).  Nice and fast, went from 1:04
>> down to 0:51.  Then I tried rendering it again, and it took 1:14.  The
>> next time, it took 1:25, then 1:34, then 1:41, 1:45.  Then it seemed
>> to hover around that value.  When I restart my computer and repeat the
>> process, it does a similar sequence.  The rendering time is always
>> nearly the same, but the parsing time gradually increases to a
>> saturation point.  I at first thought it might be an issue with the
>> CPU, or memory, or their operating at different clock frequencies.
>> That doesn't seem to be the main issue, since it behaves in a similar
>> way on our other computer, a Dell, too.  I also did lots of diagnostic
>> tests, and everything checks out fine.  I think it may be an issue
>> with POV-Ray itself.  Is it not freeing up memory?  What's going on in
>> there?  It's a fairly simple little scene.  Other scenes where it's
>> mostly rendering and doing little parsing are a lot more consistent.
>> It doesn't seem to have anything to do with the random number
>> generation in the scene, because I tried it without it, too.  If
>> anyone can offer some suggestions or answers as to what is going on,
>> Ben Scheele
Date: 1 Apr 2006 03:51:10
Message: <442e3efe$1@news.povray.org>
Hi.
On my Athlon 64 3700+ it takes 40 seconds using a 32bit Debian Linux.
Of course as on Linux there isn't a frontend with POV, it exits
comletely when the render is done, so subsequent renders take the same time.
Manuel
Total Scene Processing Times
   Parse Time:    0 hours  0 minutes 12 seconds (12 seconds)
   Render Time:   0 hours  0 minutes 28 seconds (28 seconds)
   Total Time:    0 hours  0 minutes 40 seconds (40 seconds)
Date: 1 Apr 2006 23:42:17
Message: <442f5629$1@news.povray.org>
Good, more information; thanks Manuel.  I tried restarting the program,
and that reset the time back to around my minimum.  That wouldn't help
for animations, but it's good to know that that works, and I don't need
to restart my whole computer to get that effect.  I still would like to
know what's going on within the program that would cause that, but that
would require insider information, it would seem.
Ben Scheele
Manuel Kasten wrote:
> Hi.
> time.
> Manuel
Date: 6 Apr 2006 22:13:20
Message: <4435cac0@news.povray.org>
I tried this with the current 3.6.1c and cannot replicate the issue. Render
time stayed the same for each render. Given 3.6.1c doesn't fix any issues
related to memory or render time (vs 3.6.1b) I can't explain the cause of
your problem.
-- Chris
Date: 10 Apr 2006 14:01:36
Message: <443a9d80$1@news.povray.org>
Thanks for looking into this issue as well, Chris.  I tried installing
this latest version and it still has that issue for me.  Here is a set
of render stats for successive renderings.
Parse + Render = Total
16 + 36 = 0:52
41 + 37 = 1:18
49 + 36 = 1:25
56 + 37 = 1:33
60 + 36 = 1:36
63 + 36 = 1:39
68 + 37 = 1:45
75 + 36 = 1:51
76 + 36 = 1:52
The render time is fairly constant, but the parsing time is increasing
until it reaches a saturation point eventually.  That does seem like an
odd behavior, doesn't it?  Would you please describe your computer's
setup, Chris (RAM, CPU, etc.)?  Thanks.
-Ben
> your problem.
> -- Chris
Date: 10 Apr 2006 14:31:32
Message: <443aa484$1@news.povray.org>
You you perhaps have a virus scanner installed that is interfering with the
reading of files?
	Thorsten
Date: 11 Apr 2006 18:46:06
Message: <443c31ae$1@news.povray.org>
Thorsten Froehlich nous apporta ses lumieres en ce 10/04/2006 14:31:
> the reading of files?
>     Thorsten
I don't think that a virus scanner would cause progressively increasing parse time. It
would tend to
increase the first render time, then have a decreased, constant, effect on successive
render. RAM
fragmentation can cause this progressive increasing in parse time.
Fundamentalism #3: Shit must be born again.
Date: 15 Apr 2006 01:15:54
Message: <4440818a$1@news.povray.org>
Hey, thanks Thorsten and Alain.  I don't use an antivirus program, so
that couldn't be an issue.  I researched RAM fragmentation and that is
likely the culprit.  Aside from paying $15 for some RAM defragmenter
that may or may not improve performance, is there some tweak that can be
done in POV-Ray to get it to behave properly?
-Ben
>>> increasing until it reaches a saturation point eventually.
>> with the reading of files?
>>     Thorsten
> parse time. It would tend to increase the first render time, then have a
> decreased, constant, effect on successive render. RAM fragmentation can
Date: 15 Apr 2006 11:28:04
Message: <44411104@news.povray.org>
Ben Scheele nous apporta ses lumieres en ce 15/04/2006 01:15:
> -Ben
Try to find a shareware or free RAM defragmenter/optimiser. If it don't help, you just
uninstall it
and you don't have to pay anything. If it does help and you are satisfied with it, you
pay the
licence if it's a shareware.
You can search on ZDNet (downloads-zdnet.com.com) for that. Keyword: ram
Jehovah's Witnesses: >Knock< >Knock< Shit happens.
Date: 15 Apr 2006 12:22:10
Message: <44411db2$1@news.povray.org>
As was pointed out before, POV-Ray *does* behave properly. Why it doesn't
appear to be doing that on your computer is hard to tell, but clearly unique
to your setup. Basically, the problem you are seeing is not one of POV-Ray,
but of your computer, so changing POV-Ray won't help in any way.
How you could fix your computer is impossible to say, but a general
suggestion might be to backup for data, format the harddisk and reinstall
your operating system. With many Windows problems this tends to help :-)
	Thorsten
