POV-Ray : Newsgroups : povray.general : 3 Gb memory limit? Server Time
6 Nov 2026 21:54:15 EST (-0500)
  3 Gb memory limit? (Message 1 to 18 of 18)
Subject: 3 Gb memory limit?
Date: 11 Mar 2006 08:10:08
Message: <4412cc30@news.povray.org>
When trying to run a render that uses over 3Gb memory I get this error
  0:01:18 Creating vista bufferPOVMS_ASSERT failed in povms.cpp line 2183:
POVMSObject_Set failed, out of memory
POVMS_ASSERT failed in povms.cpp line 2849: POVMSAttr_Set failed, out of
memory
POVMS_ASSERT failed in povms.cpp line 2183: POVMSObject_Set failed, out of
memory
memory
memory
Segmentation fault
Keeping it below 3Gb (by reducing the number of lights) it works fine.
Just wondering if I should keep that 3Gb limit in mind or if there is
something else going wrong.
Running:
Athlon 64x2 3800+
4 Gb mem internal (6Gb swap) (so available mem should not be a problem)
Suse 10 with Linux athlon64 2.6.13-15-bigsmp kernel
Self compiled Povray 3.6.1
Ger
Subject: Re: 3 Gb memory limit?
Date: 11 Mar 2006 08:40:06
Message: <duujsk$mqr$1@chho.imagico.de>
> Running:
> Athlon 64x2 3800+
I suggest you check your system configuration and compiler settings.
POV-Ray has no internal limitations concerning memory use.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 11 Mar 2006 09:54:04
Message: <4412e48c@news.povray.org>
> Christoph
Okay, thanks Christoph. I'm just trying to eliminate possible causes.
Next step is reinstall the system and try again :)
Ger
Date: 11 Mar 2006 10:16:18
Message: <4412e9c2$1@news.povray.org>
Ah, yes.  The Microsoft solution.
John
(who couldn't resist)
Date: 11 Mar 2006 10:25:34
Message: <4412ebee@news.povray.org>
> Regards,
> John
Who's Microsoft?
Ger
Who couldn't resist either
Date: 11 Mar 2006 14:15:03
Message: <duv7fa$qo6$2@chho.imagico.de>
But that only works on Microsoft system - elsewhere performing the same
installation once more will not lead you any further...
Date: 11 Mar 2006 16:07:23
Message: <44133c0b@news.povray.org>
> Christoph
The most likely reason for the troubles I'm seeing these last 2 weeks is the
fact that I increased memory from 2 to 4 Gb, switched out the video card
and added an Adaptec UW320 controller.Because of the memory I had to switch
kernel. It's in this kernel switching together with the new drivers that
something got screwy.
Ger
Date: 12 Mar 2006 19:06:43
Message: <4414b793$1@news.povray.org>
>> Christoph
Have you checked ulimit to see what your stack size and allowed virtual
memory are? 'ulimit -a' at the console should give you the values that
the system is currently set to allow. I'm not sure what Suse would set
their defaults at, but I think they would pick more conservative defaults.
The other option would be the memory settings in the kernel, but that
still shouldn't require a reinstall.
I want Linux to replace Windows, but I don't think this is what I had in
mind.
Date: 12 Mar 2006 19:42:05
Message: <4414bfdd@news.povray.org>
Hi, no, I have not checked those values, but after a re-install it all works
out nicely. It must have been a kernel problem because now I can run
renders as large as 10Gb* without too much trouble.
And for your info
core file size        (blocks, -c) 0
data seg size         (kbytes, -d) unlimited
file size             (blocks, -f) unlimited
max locked memory     (kbytes, -l) 32
max memory size       (kbytes, -m) unlimited
open files                    (-n) 1024
pipe size          (512 bytes, -p) 8
stack size            (kbytes, -s) unlimited
cpu time             (seconds, -t) unlimited
max user processes            (-u) 40960
virtual memory        (kbytes, -v) unlimited
> mind.
Ger
[*] With a lot of random included crap just to make the render bigger.
Date: 13 Mar 2006 09:13:26
Message: <44157e06$1@news.povray.org>
> Running:
> Athlon 64x2 3800+
It looks like you know what you are doing, but here are some things I
have run across regarding memory - based on 32 bit systems.
A single application (thread) is limited to using 2GB or 3GB depending
on your OS and settings within the OS.  I have found that typically in
Windows the limit is 2GB and Linux is 3GB (tho these can be affected by
OS settings).  I have run into these ceilings myself running various
applications.  I have found no way of allowing for more memory usage in
a 32bit system.  I set up 16GB swap once only to have the application
crash at 3GB.
Also, the OS might be capable of using much more than 2GB (or 3GB), but
it must be in the form of separate applications (or threads).  It might
be entirely possible to run (3) 2GB applications - tho I have not tried
or tested this myself.  Others here with more knowledge can set me straight.
I remember that these is a configuration within Linux that allows it to
use different memory mapping to allow for large memory usage.  If I
remember correctly, it was a kernel option and required the kernel to be
recompiled.
If your system is 64 bit, it could be that something is still limiting
it to using 32 bit memory addressing.
Now, my experience is only with a 32 bit system.  I understand that 64
bit systems have much different limitations, but I have no experience
with them.  I hope that this sheds a bit of light for you.
LAter... Tom
Date: 13 Mar 2006 09:57:58
Message: <44158875@news.povray.org>
>> Running:
>> Athlon 64x2 3800+
> crash at 3GB.
This is most likely due to limits inside the application, not the OS
I'm currently running 2 renders of 2.5 Gb each, alongside the usual bunch of
office thingies, mail, news, browsers, photo editors, etc etc.
Swap space usage is upto 3.5 Gb now.
> straight.
> recompiled.
Correct, when you go above 3 Gb you will need to change the kernel to the
"big" version allowing for more internal memory, and this is where my
problems started. It turned out that something fishy had happened when I
switched kernels.
Not under Linux, I don't know about 64bit Windows
With the arrival of 64 bit systems the phrase "The sky's the limit" has been
superseded with "The sky's just the beginning" :)
> LAter... Tom
Ger
Date: 13 Mar 2006 10:19:24
Message: <44158d7c$1@news.povray.org>
And, yes, you do know what you are doing :-)
>> crash at 3GB.
Not on a 32 bit system where accessing that much memory is a problem.
Lots of research and trial and error have shown me this.
> switched kernels.
That's what it started to look like to me when I was replying to your
message earlier.  That running 64 bit should not have any problems, but
something is still holding you back.  And a misconfiguration in the
kernel could do that :-)
A misconfiguration could hold you back - what I was getting at.
Every once in a while we throw something at a computer that is just too
much for it.  I know of two incidents where I've needed more than 2GB of
memory.  One was due to a bug in AutoCAD - which I now have a workaround
for.. the other is aligning 50+ 3D data scans (2 million data points
each) which we do in sections.
Maybe our next computer will be a 64 bit system so that we can see how
it affects our work flow.
LAter... Tom
Date: 13 Mar 2006 11:47:07
Message: <4415a20b$1@news.povray.org>
Errr, no. It's because a 32-bit address can only address 4G. What would
you have malloc() return for the fifth gig of memory? The "limit inside
the application" would be one of not manually implementing
bigger-than-32-bit pointers and its own swap space.
Most people who went from 16-bit 32-bit processors stopped worrying
about implementing more per-process storage than available address
space. Of course, it was all the rage being able to edit a file bigger
than 64K back in 8080 days. :-)
     "I think these anchovies are spoiled.
      They're not flat."
Date: 19 Mar 2006 22:08:29
Message: <441e1cac@news.povray.org>
  Don't base your answer on 32-bit systems since he is using a 64-bit one.
  A friend of mine has an amd64 and he tried how much memory he can
allocate in linux. In linux you can actually allocate more memory than
is physically available (even when counting swap space). It's only when
you try to *use* more memory than what is physically available when it is
not possible.
  I don't remember exactly how much he could allocate, but it was less
than 2^64. However, it was way over 2^32. It might have been something
like 2^48 or whatever. I don't know why there's such a limit, but I assume
that his motherboard limits the address space of the system to that
(it's not unusual for motherboards of new processors to not to support
everything the processor could).
  I don't know why he cannot use more than 3GB in his system, though.
Date: 20 Mar 2006 04:34:58
Message: <441e7741@news.povray.org>
> not possible.
I couldn't use the memory because something went wrong when I switched
kernels. I upgraded my machine from 2Gb to 4 Gb and had to switch to the
"big" kernel. It supports >3Gb memory. In my case the "bigsmp" kernel since
I have an AMD X2 (dual core).
I have since reinstalled my system and for the sake of testing ran renders
that needed > 10Gb of memory and that went just fine.
Ger
Date: 20 Mar 2006 11:07:03
Message: <441ed327$1@news.povray.org>
Your statement is very judgmental and a week after the fact.
You may not have read completely what I wrote:
"If your system is 64 bit, it could be that something is still limiting
it to using 32 bit memory addressing. "
I offered what information I knew.  He might have already known it all,
but then he might not have.  I didn't presume that my information about
32 bit systems would solve his problems.  I only thought that if I
offered what I knew that it might trip his mind on what was actually the
problem.
And his problem was a 32 bit one.
read the thread - he didn't have 'big' memory compiled into the kernel.
LAter... Tom
Date: 20 Mar 2006 12:49:13
Message: <441eeb19@news.povray.org>
>>   one.
> problem.
Neither 32bit nor 64bit. It was a screwed up kernel.
What put me on the wrong track at first was the fact that povray crashed
at(or very near) the 3Gb limit (which is 32 bit)
I did have the "big" kernel but it was erroneous and that's what threw me
off
> LAter... Tom
Ger
Date: 20 Mar 2006 15:30:24
Message: <441f10e0$1@news.povray.org>
>> problem.
Ok, a kernel that was saying it was big, but acted small :-)
Whatever the problem was, it is now fixed :-)
> off
Don't you love it when the problem is something deep that's hard to
find.  At least it wasn't something that took you years to figure out by
accident :-)
Thanks for your reply in setting me straight.
I was mainly defending my desire to help out a fellow POVer.
LAter... Tom
