POV-Ray : Newsgroups : povray.general : Layered UV maps Server Time
1 Nov 2026 00:51:55 EDT (-0400)
  Layered UV maps (Message 1 to 4 of 4)
Subject: Layered UV maps
Date: 8 Mar 2006 02:31:16
Message: <440e8844$1@news.povray.org>
I am attempting to create a mesh with layered textures that follow
different uv vectors.  Is it possible to define a mesh with more than
one set of uv vectors?  Or use separate lists of uv vectors in a layered
texture?
Skip
Subject: Re: Layered UV maps
Date: 9 Mar 2006 14:30:00
Message: <vh01121nltubudp9pa2m6cu4p2pg1ja4en@4ax.com>
On Wed, 08 Mar 2006 01:31:19 -0600, Skip Talbot <Ski### [at] aolcom>
wrote:
mesh2 implementation of POV-Ray does not support this feature.
I also do not know any other 3d engine supporting this.
Solution shouldbe easy:
use 2 meshes with different uv vertices
or
use 1 mesh but play with layered textures#
-tb
>texture?
>Skip
Date: 9 Mar 2006 15:51:46
Message: <44109562$1@news.povray.org>
Depends what you mean by "3d engine".  Such an effect is extremely easy
in OpenGL (and I would assume Direct3D), so 3D Engines probably do
support it.
...Chambers
Date: 10 Mar 2006 02:49:39
Message: <44112f93$1@news.povray.org>
However, I need the textures to follow different UV coordinates on the
same mesh.  Sure I can layer textures on one mesh, but they are using
the same UVs.  I thought about creating a second mesh with the different
  UVs and scaling it slightly larger and giving it a transparent
texture, but this won't work if my mesh isn't convex (the two may
intersect).
Skip
> or
> -tb
>>texture?
>>Skip
