POV-Ray : Newsgroups : povray.general : Help with scene aesthetics with regards to glass like objects Server Time
8 Mar 2026 00:08:55 EST (-0500)
  Help with scene aesthetics with regards to glass like objects (Message 1 to 4 of 4)
Subject: Help with scene aesthetics with regards to glass like objects
Date: 9 Feb 2006 10:15:23
Message: <43eb5c8b$1@news.povray.org>
I created a scene with some glass like superellipsoids. The scene has
radiosity and a high max_trace_level. What I am finding is that it looks
very unrealistic with unsmooth transitions in the reflections in the glass
columns. Even with anti-aliasing on, the transitions aren't smooth at all
and it looks very computer generated and not very real. Can anyone help me
with ideas on how to make this scene look better and more realistic?
Thanks
glasscolumns.pov scene text follows.
#include "textures.inc"
#include "shapes.inc"
#include "metals.inc"
#include "glass.inc"
#include "woods.inc"
global_settings {
  max_trace_level 50
  radiosity {
      pretrace_start 0.08
      pretrace_end   0.02
      count 100
      nearest_count 5
      error_bound 1.8
      recursion_limit 3
      low_error_factor 0.5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 0.25
      adc_bailout 0.005
sky_sphere {
      color red 0.7 green 0.7 blue 0.7
   location <400, 200, -1000>
   direction <0, 0,  6>
   right x*1.33
   look_at <0,60,0>
light_source {
  <300,200,-500>
  color red 0.5 green 0.5 blue 0.5
  looks_like {sphere {<0,0,0>,5 pigment {color White} finish {ambient 1}}}
light_source {
  <-50,400,-500>
plane {
  <0,1,0>,0
    finish {diffuse 1}
#declare block=difference {
  superellipsoid {
    <0.1,1>
    scale 0.5
    translate <0,0.25,0>
  superellipsoid {
    <0.1,1>
    scale 0.495
  translate <0,0.5,0>
#declare large_block=union {
  object {
    block
    scale <30,100,30>
    interior {ior 1.5}
      pigment {color rgbf <0.90, 0.94, 1.0, 0.9>}
      finish {
        specular 0.6
        roughness 0.002
        ambient 0
        diffuse 0.1
        brilliance 5
        reflection {
          0, 1.0
          fresnel on
#declare large_block_green=union {
  object {
    block
    scale <30,100,30>
    interior {ior 1.5}
      pigment {color rgbf <0.8, 1.0, 0.8, 0.925>}
      finish {
        specular 0.6
        roughness 0.002
        ambient 0
        diffuse 0.1
        brilliance 5
        reflection {
          0, 1.0
          fresnel on
#declare large_block_clear=union {
  object {
    block
    scale <30,100,30>
    interior {ior 1.5}
      pigment {color rgbf <0.99, 0.99, 0.99, 0.9>}
      finish {
        specular 0.6
        roughness 0.002
        ambient 0
        diffuse 0.1
        brilliance 5
        reflection {
          0, 1.0
          fresnel on
union {
  object {large_block translate <0,0,50>}
  object {large_block_clear translate <-50,0,50>}
  object {large_block_clear translate <50,0,50>}
  object {large_block translate <-50,0,0>}
  object {large_block_green translate <0,0,0>}
  object {large_block translate <50,0,0>}
  object {large_block translate <0,0,-50>}
  object {large_block_clear translate <-50,0,-50>}
  object {large_block_clear translate <50,0,-50>}
Subject: Re: Help with scene aesthetics with regards to glass like objects
Date: 9 Feb 2006 12:44:51
Message: <43eb7f93$1@news.povray.org>
"Michael Goldshteyn" <mgo### [at] comcastnet> wrote in message
news:43eb5c8b$1@news.povray.org...
> unsmooth transitions in the reflections in the glass columns. Even with
> anti-aliasing on, the transitions aren't smooth at all and it looks very
> computer generated and not very real. Can anyone help me with ideas on how
Two possible ideas, and both would slow the rendering down. Camera focal
blur and/or refractive dispersion. However, neither would be direct a remedy
for softening reflections.
I'm not certain of what you might be talking about exactly anyhow. Is it
only the reflectiveness? Or is there something else about it? I tried
rendering a small section at a large enough size to see the glass columns
but I'm still not completely sure if it's only reflection causing the sharp
and dashed lines I'm seeing. Oh, also might be possible to lower
max_trace_level without causing blackout areas, since I tried 15 instead of
50 and it looked fairly okay.
As you might already know, the superellipsoid primitive in a CSG difference
can be slow to render, so I hope you're ready for slower rendering if you
take me up on my suggestions.  ;)
Have you considered using MegaPOV? It can blur reflections (or at least did
in some version). And there's also the regular POV version method of
blending textures, just search for "blurred reflection" and you should find
plenty of past discussion about it.
Date: 9 Feb 2006 13:48:12
Message: <43eb8e6c$1@news.povray.org>
"Bob Hughes" <omniverse@charter%net> wrote in message
news:43eb7f93$1@news.povray.org...
how
remedy
sharp
of
difference
did
find
> Bob
My few suggestions would include using a tight specular highlight with a
softer phong highlight. (borrowed from Lightbeam's glass technique I think.)
Then, maybe use a slight normal scaled large enough so it's not obviously
repeating on the individual objects. Something like
normal {waves 0.2  scale 0.7 }
adds a little character to a unit sphere by just giving the glass a bit of
non-uniformity.
Also, I no longer use colors in pigments for glass. purely rgbt<1, 1, 1, 1>.
Then I do coloring in the interior statement:
interior {
  ior 1.5
  fade_color <0.3, 1.0, 0.3>
  fade_distance 0.15
  fade_power 1003
  dispersion 1.1
  dispersion_samples 7
} // requires tweaking per object
These are things I like to use, they might not always be realistic but I
find them nice.
Date: 15 Feb 2006 02:35:01
Message: <web.43f2d8c354208563a671bd170@news.povray.org>
> Thanks
One more (and probably better) solution:
Add conserve_energy to the finish blocks; the result looks much better and
more realistic.
