POV-Ray : Newsgroups : povray.general : A macro that drops a vector-- what's the syntax again? Server Time
10 Jul 2026 11:50:58 EDT (-0400)
  A macro that drops a vector-- what's the syntax again? (Message 1 to 10 of 14)
Subject: A macro that drops a vector-- what's the syntax again?
Date: 9 Nov 2005 21:58:46
Message: <4372b765@news.povray.org>
I cannot get the following code to work:
#macro sign(a)
#if (a<0)
        (-a)
#else
        (a)
#macro ease_in(your_clock,your_array)
        #local rotdim=dimension_size(your_array,1);
        #local ennn=0;
        #while(ennn<rotdim)
                #if(your_array[ennn].x=your_clock)
(<your_array[ennn].y,your_array[ennn].z,your_array[ennn].t>)
                        #declare ennn=ennn+1e7;
                #else
                        #if(your_array[ennn].x<your_clock)
                                #local ennn=ennn+1;
                        #else
                                #local why1=your_array[ennn+0];
                                #local why0=your_array[ennn-1];
                                #local
teee=(your_clock-why0.x)/(why1.x-why0.x);
                                #local
teeecubes=0.5-0.5*pow(abs(cos(teee*pi)),0.5)*sign(cos(teee*pi));
                                #local
exxx=why0.y+(why1.y-why0.y)*teeecubes;
                                #local
eyyy=why0.z+(why1.z-why0.z)*teeecubes;
                                #local
ezzz=why0.t+(why1.t-why0.t)*teeecubes;
                                (<exxx,eyyy,ezzz>)
#declare ary=array[3]{
//an array of four dimensions:
//< time,  x_position[n], y_position[n], z_position[n]>
<0.00,     -16,47,24>,
<0.50,      0,52,-0>,
<1.00,     -16,47,24>
//sorry for the mess here!
#declare ltempwristpt=<0,0,0>+(ease_in(clock,ary));
sphere{ltempwristpt,1 pigment{red 1}}
Subject: Re: A macro that drops a vector-- what's the syntax again?
Date: 10 Nov 2005 00:36:05
Message: <4372dc45@news.povray.org>
> #macro sign(a)
> #if (a<0)
>         (-a)
> #else
>         (a)
> #end
> #end
#macro sign(a)
    #if (a < 0)
        #local Ans = -a;
    #else
        #local Ans = a;
    (Ans)
A similar solution for your other macro.
(Though isn't there a sign function or something like that already?)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 10 Nov 2005 01:01:53
Message: <kurtzlepirate-B61563.07015210112005@news.povray.org>
In article <4372b765@news.povray.org>,
 "Greg M. Johnson" <p t e r a n d o n @
 thecommononethatstartswithY.com> wrote:
::I cannot get the following code to work:
::#macro sign(a)
::#if (a<0)
::        (-a)
::#else
::        (a)
::#end
::#end
... abs() already exist in pov
Date: 10 Nov 2005 05:56:22
Message: <43732756$1@news.povray.org>
"kurtz le pirate" <kur### [at] yahoofr> wrote in message
news:kurtzlepirate-B61563.07015210112005@news.povray.org...
> ::#macro sign(a)
> ::#if (a<0)
> ::        (-a)
> ::#else
> ::        (a)
> ::#end
> ::#end
what's abs() got to do with sign(), except that you can make sign() with
sign(x)=x/abs(x) ?
cu!
Date: 10 Nov 2005 11:57:46
Message: <43737c09@news.povray.org>
sign(x)=x/abs(x) ?
  Look at his "sign" implementation. It's abs().
Date: 10 Nov 2005 19:14:32
Message: <4373e268@news.povray.org>
>>::#macro sign(a)
>>::#if (a<0)
>>::        (-a)
>>::#else
>>::        (a)
>>::#end
>>::#end
sign(x)=x/abs(x) ?
With a divide-by-zero error when x==0.
John
Subject: Has this bug been reported?
Date: 11 Nov 2005 17:32:03
Message: <43751be3$1@news.povray.org>
> #macro sign(a)
> #if (a<0)
>         (-a)
> #else
>         (a)
> #end
> #end
I've noticed that this way of using macros to express things leads to
parse errors.  There is a work-around (which has already been posted),
but the docs give no reason for this construction to fail.  Is this
behavior deemed worthy of correction?
John
Subject: Re: Has this bug been reported?
Date: 11 Nov 2005 18:12:00
Message: <43752540$1@news.povray.org>
>> #macro sign(a)
>> #if (a<0)
>>         (-a)
>> #else
>>         (a)
>> #end
>> #end
Well, they do, but I agree it could be a lot clearer.  In "Are POV-Ray
Macros a Function or a Macro?" it explains it:
"When the body of a macro consists of statements that create an entire item
such as an object, texture, etc. then the macro acts like a function which
returns a single value."
The "statements that create an entire item" is the important part here. What
the macro above is are *two* statements that create *two* items.  Basically,
the word "item" means what is best explained as "evereything you could also
assign to a single #declared variable".
> Is this behavior deemed worthy of correction?
It is correct, and it is also possible to obey the "one statement" rule! :-)
  It just requires slightly different syntax:
#macro sign(a)
#if (a<0)
         -a
#else
         a
is perfectly legal!
	Thorsten
Date: 11 Nov 2005 21:40:16
Message: <43755610@news.povray.org>
 Oi vey!  Too much late-night coding, I guess.  :-S
Yes, that's an abs() function.  I wanted a sign() function and so was
writing my own.
Perhaps it was late-night delusions, but I did think that povray 3.5 (the
apt-get version) was freaking with me when it came to nested function/macro
calls.
> #macro sign(a)
> #if (a<0)
>         (-a)
> #else
>         (a)
> #end
> #end
Date: 12 Nov 2005 03:09:05
Message: <4375a321@news.povray.org>
  The documentation could be clearer. It's difficult to explain clearly,
though. Any suggestions?
  The behaviour itself is logical, but not easy to explain.
