Hi!
I wanted to cut a "pyramid without a top" out of a box. This is for a
backround of a game so I used an orthographic camera.
But the shading is all wrong. To show the problem, I squeezed the
prism to have a really shallow angle (see the scale-statement in the
prism), so nearly no difference in the shading of the box and the cutted
out surface should be visible. Uncommenting the first three lines in the
camera-statement shows the problem.
On a sidenote, if you change the perspective camera to a location 37000
y-units far away, and an angle of 1, the problem is turned around. (I
guess, this is due to precision issues... - But there are no gigantic
numbers in the orthographic case.)
My POV-Ray Version is 3.6.1.icl8 on WinXPSP2
Any Ideas?
Thank you!
Kalle
//Sourcecode starts here
// orthographic
// right <650,0,0>
// up <0,490,0>
location <320,500,240>
look_at <320,000,240>
difference {
box {<0,-1,0>,<1+1/3,0,1>}
prism {
conic_sweep
1.1,0.8,4
<-0.5,0.5>,<-0.5,-0.5>,<0.5,-0.5>,<0.5,0.5>
translate -y
scale <1,.000005,1>
translate y
translate <0.5,-1,.5>
pigment { green 1 }
scale 480
light_source {
<240,500,-240>
color rgb 1
Wasn't it KalleK who wrote:
>Hi!
The problem seems to be related to the fact that the camera is pointing
perfectly vertically down. If you change the camera location to
<320,500,239.9> instead of <320,500,240>, then it all looks fine.
When you then remove the temporary scale statement, you can move your
orthographic camera much closer to the vertical <320,500,239.999999>,
easily close enough to be indistinguishable from the true vertical in
terms of the geometry.
Mike Williams
Gentleman of Leisure
KalleK wrote:
> Hi!
> guess, this is due to precision problems... - But there are no gigantic
> Any Ideas?
> Thank you!
> Kalle
> camera {
> // orthographic
> // right <650,0,0>
> // up <0,490,0>
> difference {
> prism {
> conic_sweep
> 1.1,0.8,4
> translate -y
> scale <1,.000005,1>
> translate y
> pigment { green 1 }
> scale 480
> light_source {
> <240,500,-240>
> color rgb 1
You've run into a pitfall with look_at. Pointing the
camera directly up or down that way gets it confused.
Better to *not* use look_at and do this instead:
orthographic
locatation <0, 0, 0>
direction <0, 0, 1>
right <650,0,0>
up <0,490,0>
rotate x*90 // point camera down
translate <320, 500, 240> // move camera where you want it
// location <320,500,240>
// look_at <320,000,240>
It might be x*-90 ... I always forget.
This way you retain a mathematically "pure"
vertical.
to all the companies who wait until a large user base becomes
dependant on their freeware, then shafting said happy campers with
mandatory payment for continued usage. I spit on your grave.
> camera {
> orthographic
> direction <0, 0, 1>
> right <650,0,0>
> up <0,490,0>
> vertical.
Hi!
Thanks to both of you. I tried the "pure" way but there were the same
black borders... So I will have to take Mike's compromise. But this will
do for the moment...
Thanks!
Kalle
>> camera {
>> orthographic
>> direction <0, 0, 1>
>> right <650,0,0>
>> up <0,490,0>
>> vertical.
> Hi!
> Thanks!
> Kalle
No problem. :)
I realize thtough that in my posting, I spelled "location" wrong.
Woops. :o Sorry.
> Woops. :o Sorry.
I've senn it while copy'n pasting... no problem at all...
Kalle
POV-Ray does not get confused at all! The proper use of look_at is clearly
outlined in the documentation. there are no workaround necessary, just
reading the documentation is sufficient :-)
In order to use look_at to determine the orientation of the camera, POV-Ray
needs to compute cross product with the "sky" vector. The default direction
of the "sky" vector is the y-axis. Consequently, if look_at - location
yields a direction vectors also on the y-axis, there is no valid cross
product and thus look_at will not work as expected.
As said, this is all in much more detail explained in the documentation.
Thus, for the proper use of the "sky" vector, please consult the POV-Ray
user reference, online for example at "2.3.1.1.2 The Sky Vector"
<http://www.povray.org/documentation/view/3.6.1/246/>.
Thorsten
Thorsten Froehlich wrote:
> POV-Ray does not get confused at all! ... Consequently, if
> look_at - location yields a direction vectors also on the y-axis, there
> is no valid cross product and thus look_at will not work as expected.
Doesn't that constitute confusion, even if the confusion itself is
completely expected? If there is no valid cross product, and the
look_at isn't working as expected, the end result will be the software
not knowing exactly what to do, i.e. being confused.
Tim Cook
Version: 3.12
If the software is given invalid input, it is the user that is confused.
"And what if I assign a hundred programmers to it?" The master
programmer shrugged. "Then the design will never be completed," he said.
http://www.google.com/search?q=%22pgp+singing%22 <-- childish but funny
http://surreal.istic.org/ <-- It's like a DEATH CIRCUS! | keyid 885b170d
Very well said. In future versions the software will attempt to warn the
user that he/she is confused.
Thorsten
> the user that he/she is confused.
> Thorsten
Well, I'm still confused, after reading the section about the sky-Vector.
I introduced a few lines in my camera-statement, but still, the black
borders appear:
up <0,0,490> // this changed, to get the right view, before the camera
// is rotated due to look_at
direction <0,-1,0> // to get the right direction first
sky <0,0,1> // this should be "up" in my case...
So I still don't get any solution without adding a tiny delta to the
cameras location or look_at...
> borders appear:
If you the look_at and location as in you original post and the sky you
provide here, note that your "up" vector will face down. Using up together
with look_at, again as documented, POV-Ray only considers the *length* of
the up and right vector (similar for direction of look_at is used). So, a
negative direction vector still has a length of one, and does not change the
look_at direction sign as you seem to want it to. Depending on what you
want to do, swapping your look_at and location vectors will be sufficient
(that certainly turns the camera around).
I would strongly recommend you carefully read the camera tutorial in the
documentation if you still have problems. It is well written, and if you
start from the beginning (rather than in the middle), you will learn
everything you need to know about handling the camera.
Thorsten
