I want to do a strange effect with a normal looking person casing a demon
shadow on the walls as she walks past.
I was thinking one way to do this might be to have a series of dark
(negative) lights projecting 'through' the object (wings), without the
object (wings) being rendered.
Any other ideas?
== John ==
> Any other ideas?
Use no_image and no_reflection on the shadow-casting object. Wouldn't that
suffice?
"Tim Nikias v2.0"
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE>
<42dd3d68@news.povray.org> Tuesday 19 of July 2005 19:50
> suffice?
and perhaps also no_rediosity and photons passthrough?
Rafa� Maj
that
> > suffice?
With no_image and no_reflection, radiosity won't touch the object anyway,
but you're correct about the photons, they need to pass_through.
"Tim Nikias v2.0"
Thanks folks, even easier :)
== John ==
John D. Gwinner nous apporta ses lumieres en ce 2005-07-20 12:25:
> == John ==
Don't forget to put no_shadow on the visible object, or you get two shadows.
Among other things, Alain saw fit to write:
> shadows.
But no_shadow means no highlights either, doesn't it?
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Jellby nous apporta ses lumieres en ce 2005-07-21 10:26:
>>shadows.
Not at all. The highlights are a function of the brillance and the specular or phong
in the finish.
The only thing, is if the subject get self shadowed, it wont'cast shadow on itself. At
the same
time, the no_image one will cast shadows on the main subject.
>>> two shadows.
> specular or phong in the finish. The only thing, is if the subject
> get self shadowed, it wont'cast shadow on itself. At the same time,
The confusion may come from the fact that using shadowless in light_sources
does indeed mean no highlights.
Rune
rune|vision: http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Among othor thigs, Rune saw fit to write:
> light_sources does indeed mean no highlights.
Oh, yes... that was it!
no_shadow -> no shadow
shadowless -> no shadow, no highlights
