POV-Ray : Newsgroups : povray.general : Can you please help me with the following posts that i have sent to chieftalk? /// Thanks. Server Time
12 Oct 2026 23:46:08 EDT (-0400)
  Can you please help me with the following posts that i have sent to chieftalk? /// Thanks. (Message 1 to 4 of 4)
Subject: Can you please help me with the following posts that i have sent to chieftalk? /// Thanks.
Date: 19 Apr 2005 18:14:36
Message: <426582cc$1@news.povray.org>
http://www.chiefarchitect.com/chieftalk/showthread.php?s=&postid=62881#post62881
Subject: Re: Can you please help me with the following posts that i have sent to chieftalk? /// Thanks.
Date: 19 Apr 2005 20:29:07
Message: <4265a253$1@news.povray.org>
As the response you got on Chieftalk said, the ambient settings are very
high on your textures, whether or not you are using radiosity. Ambient
settings that high are usually used for a object that is supposed to be
glowing or actually radiating light, like an LED.  The high setting
might make sense for the background sky texture but not the others.
The roughness/specualr settings could also be a little intense
depending, but you need to reduce the ambient to zero and see how the
scene renders first.
Date: 19 Apr 2005 23:13:03
Message: <4265c8bf$1@news.povray.org>
Well, as noted above, ambient settings are very high.  But from your
original question it sounds like the picture was ok on the first
machine, but got brighter when you moved it to the second machine?
If so I'd question your "assumed_gamma 2.0" especially since you don't
have a display_gamma setting in your ini file.   Look up display_gamma
and assumed_gamma in the docs.
RG
Date: 20 Apr 2005 00:49:51
Message: <4265df6f$1@news.povray.org>
Thank you all for your answers.
"gonzo" <rgo### [at] lansetcom> wrote in message
news:4265c8bf$1@news.povray.org...
> original question it sounds like the picture was ok on the first machine,
> have a display_gamma setting in your ini file.   Look up display_gamma and
> RG
