POV-Ray : Newsgroups : povray.general : Lightsys Reflective Spectral data Server Time
10 Jul 2026 23:25:23 EDT (-0400)
  Lightsys Reflective Spectral data (Message 1 to 10 of 12)
Subject: Lightsys Reflective Spectral data
Date: 9 Mar 2005 13:37:28
Message: <422f4268$1@news.povray.org>
I'm still playing around with Lightsys, and the more I learn, the more
questions I have.  :-)
I did some tests with some of the demo scenes for Lightsys 4, where I
replaced the reflective spectral data rgb values with plain-old rgb values.
For the items I tested with, I didn't notice any big differences, but
perhaps there are small differences which are more subtle.
My question(s) at this point:
What are the benefits of using the reflective spectral data (e.g.
RS_White_Paint_1) over normal pigments?  Is it simply that the RS values
will look better under a much wider range of lighting?  Is it ok to mix
normal rgb pigments (e.g. rgb <1,0.8, 0.6>) along with the RS values?
Lightsys is an amazing set of includes/macros which everyone should probably
be using, but at this point, I don't understand it very well.  Some day, it
would be nice to have a good tutorial "Lightsys for Dummies" or something.
Perhaps I'll begin writing it up, if I ever get to the point that I truly
understand enough of it.
As always, any insight would be appreciated.
Jeremy
www.beantoad.com
Subject: Re: Lightsys Reflective Spectral data
Date: 9 Mar 2005 14:10:32
Message: <422f4a28$1@news.povray.org>
   You're not the only one! :) Seriously, I only had the initial idea and
zero knowledge about all the matters involved. Ive and others helped a
lot, and the set of macros can do a lot of things, but I really don't
understand all of them.
   Technically, the advantage is that you have sampled colors, wich
should look realistic per se. Also, you have "abstract" spectrums that
you can "visualize" under any color space and with any white point, so
you can comunicate colors accuratelly, but this is not of much use with
POV-Ray.
   Practically, the important point is that you don't have to bother
making colors for pigments of known materials. I find it specially
useful with colors wich are difficult to get right, like the green
pigments of plants. It accomplishes the same goal as sampling the colors
from a photo, but with the advantage that the colors are not "changed"
by the lighting on the photo, the camera white balance, etc...
   Mixing with non-sampled colors is not a problem, but you should
adjust them to look similar to the sampled ones in brightness and
saturation, so it's better to use one of both types only.
   Yeah... I've that tutorial on the to-do list, who know for how many
years... as I mentioned, the main problem is that I don not fully
understand all the functionality (appart from lazzines, that is).
   Hope that helped as a start...
Jaime
Date: 9 Mar 2005 18:01:01
Message: <422f802d@news.povray.org>
"jaime" <jai### [at] ignoranciaorg> wrote in message
news:422f4a28$1@news.povray.org...
<snip>
Ok, so there wasn't a lot that I wasn't understanding in this regard.  The
RS samples can be good to reference against, and they can be used to simply
avoid having to spend a lot of time figuring out a certain color.  That
makes sense to me.
I wasn't sure if I was really doing something "wrong" by using RGB values.
There are so many other things that we guess at (like diffuse, brilliance,
specular, etc.), that the RS is only one small piece.
>> probably be using, but at this point, I don't understand it very well.
>> Some day, it would be nice to have a good tutorial "Lightsys for Dummies"
>> or something. Perhaps I'll begin writing it up, if I ever get to the
>> point that I truly understand enough of it.
It might be something that we could get started on the wiki, also.  Just
another thought...
It does!  I'm having a lot of fun messing around with lemon walls
(demo_indoor1) among other things, like varying the Daylight/Sun
temperature.  I've also learned a few other tricks from that demo which are
quite useful, like putting media inside the window.
Thanks!  :-)
Jeremy M. Praay
www.beantoad.com
Date: 9 Mar 2005 19:22:06
Message: <cjameshuff-87CB6C.19220409032005@news.povray.org>
In article <422f4268$1@news.povray.org>,
I'm not sure what Lightsys uses, but it sounds like it simply uses a
greater number of samples for color. Real world color is a mess of
wavelengths from a continuous spectrum. Not all light sources emit
evenly through the entire visible spectrum, and most materials reflect
very unevenly, with complicated variations of reflection as a function
of wavelength. The same object can have very different appearances under
two lights that both appear to be "white". The effect is especially
important in highly monochromatic light, such as that from low-pressure
sodium street lights. 3 channels simply aren't enough to simulate this
kind of effect. The effects can be subtle or glaringly obvious,
depending on the situation.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 10 Mar 2005 11:14:42
Message: <42307272$1@news.povray.org>
"Christopher James Huff" <cja### [at] gmailcom> wrote in message
news:cjameshuff-87CB6C.19220409032005@news.povray.org...
Thanks.  That's along the lines of what I was thinking.  As a real-world
example, where I work, I sit under some strange yellow flourescent lights.
Some of the papers strewn around my desk look white, others look very yellow
or grey.  If I pick up those same papers and take them into my boss's office
(different type of flourescent lights), they all look white.
Like I said to Jaime, I would guess that the reflectance values in POV-Ray
probably are less significant than some of the other things we guess at in
the finish statement (or at least I guess at them), like specular, phong,
reflection, diffuse, brilliance, etc.  I think it would be nice if POV-Ray
had more materials predefined using more physically accurate data.  Lightsys
is a great step in that direction.  Does anyone know where to get
information on those finish values?
Jeremy
www.beantoad.com
Date: 12 Mar 2005 05:35:57
Message: <4232c60d$1@news.povray.org>
   That is metamerism, IIRC... and that's not possible without the
raytracer handling wavelengths internally (that is, Lightsys can't
simulate it).
   The only pointer I got is reflection+diffuse=1. I really don't know
where it comes from, but I've seen it mentioned several times by people
which seems to know what they are talking about... and indeed seems
logical and gives good results. For the rest, we still have to use the
good and old "trial & error", I suppose.
Jaime
Date: 12 Mar 2005 17:12:41
Message: <42336959$1@news.povray.org>
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:4232c60d$1@news.povray.org...
I don't think I've heard that before, or else if I did, I never paid
attention.  I've never quite been sure what to use for diffuse, so I've
generally just left it at the default.  I'm going to have to modify some of
my scenes/objects and re-render them with that in mind.
Thanks!  :-)
Jeremy M. Praay
www.beantoad.com
Date: 11 Apr 2005 01:15:01
Message: <web.425a076c78358dd8e8f022d90@news.povray.org>
I like what I've been able to do with lightsys so far, but that has only
been playing with the settings some and hacking .obj meshes into the demo
scenes. I'd like to at least understand what macros you do understand and
what they can do. :O)
Date: 11 Apr 2005 09:05:54
Message: <425a7632@news.povray.org>
   You're not alone... and I'm not kidding. I was going only for a
simple  automatic lighting system, but finally Ive implemented an entire
"color management" system, which Lightsys uses to convert spectrums into
rgb colors (which is only a little part of what the includes can do).
   I'm afraid that to use all the set of macros properly, you need to
have first some good knowledge about professional/scientific color
management (which I don't have). Anyhow, for regular scenes you can do
as me: just use the lightsys macros with the predefined spectrums, and
play a bit with the brightness and the white point to get the feel you want.
Jaime
Date: 11 Apr 2005 10:55:00
Message: <web.425a8f3f78358dd844a2d5f80@news.povray.org>
Ah, and how do you do that? :O) I'd be happy to write a tutorial on that
alone if I understood how. I set up a page with some figure meshes hacked
into the demos and the camera moved about.
http://www.geocities.com/fls13ec/PovTest-Lightsys4.html
For example, what do the .inc files actually include? I see in
lightsys_constants.inc file certain brands of light bulbs are assigned a
certain amount of lumens. Then there is a relationship with a spline that
is defined in either espd_cie_standard.inc or espd_lightsys.inc. At least I
think. How do you insert in a scene a GE 100 watt lightbulb in a particular
location, like a lamp? Or how about sunlight streaming through a window
into a room?
