POV-Ray : Newsgroups : povray.general : uv mapping for isosurfaces - when? Server Time
21 Oct 2026 02:58:28 EDT (-0400)
  uv mapping for isosurfaces - when? (Message 1 to 12 of 12)
Subject: uv mapping for isosurfaces - when?
Date: 21 Feb 2005 10:21:14
Message: <4219fc6a@news.povray.org>
Subject: Re: uv mapping for isosurfaces - how?
Date: 21 Feb 2005 14:53:38
Message: <421a3c42$1@news.povray.org>
Subject: Re: uv mapping for isosurfaces - when?
Date: 21 Feb 2005 20:12:51
Message: <cjameshuff-64B309.20125721022005@news.povray.org>
In article <4219fc6a@news.povray.org>,
 "William Peska" <wil### [at] yahoocom> wrote:
It'd help if you gave a little more detail...for instance, maybe
describing what you think such a feature would do. As it is, you're
essentially asking for "magic".
There's nothing particularly special about UV coordinates, you pick a
system that fits your purpose. For instance, for UV-mapping a sphere,
you usually pick spherical coordinates...that would not work well for a
torus. It could work for a box, but you'd probably pick a mapping
designed specifically for boxes instead. The shape of an isosurface is
very arbitrary, it could be a sphere, a torus, or something far more
complex. There is simply no way for POV to guess what you might want.
One possibility that does come to mind would be to allow the user to
specify a pair of functions mapping XYZ coordinates to UV coordinates.
It would not be particularly easy to use, though. It is in fact already
possible, though you have to jump through a few hoops...you need to use
a function pattern that implements the desired mapping. For example
(untested!):
#declare basePattern = function {pattern {checker scale 0.1}};
#declare uFn = function (x, y, z) {
    atan(x, z)/(2*pi) + 0.5
#declare vFn = function (x, y, z) {
    atan(y, sqrt(x*x + z*z))/(2*pi) + 0.5
isosurface {
    pigment {function {basePattern(uFn(x, y, z), vFn(x, y, z), 0)}
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 22 Feb 2005 01:40:56
Message: <MK3AtAA6NtGCFwy$@econym.demon.co.uk>
>(untested!):
>isosurface {
I was wondering if something like that could be achieved.
For a sensible result you'd really want to find a set of functions that
had the property that uFn, vFn and the surface function be orthogonal
everywhere. That would be the 3d equivalent to what are called
"orthogonal trajectories" of a family of curves in 2d. In the 2d case,
there's a method for finding orthogonal trajectories if you can find a
differential equation that describes the family of curves and then solve
the inverse of that differential equation. Consider the family of
surfaces produced by using different values of "threshold", then find
two other families of surfaces that are the 3d orthogonal trajectories.
The 3d case is likely to be a bit more awkward to calculate, if for no
other reason than the fact that there isn't a unique solution like there
is in the 2d case.
In a really simple case, I happen to know that f_sphere(), f_th() and
f_ph() are orthogonal everywhere, so that gives us something we can
check. Here's a complete scene using the technique (in this case the
scale needs to be a fraction of pi to prevent a discontinuity).
camera { location  <0, 0, -2.5> look_at <0, 0, 0>}
light_source {<-100,200,-100> colour rgb 1}
#include "functions.inc"
#declare basePattern = function {pattern {checker scale pi/20}};
#declare uFn = function{f_th(x,y,z)}
#declare vFn = function{f_ph(x,y,z)}
#declare Surface = function {f_sphere(x,y,z,1)}
isosurface {
  function { Surface(x,y,z) }
        max_gradient 2.2
        contained_by{sphere{0,1.1}}
        pigment {function {basePattern(uFn(x, y, z), vFn(x, y, z), 0)}}
All we need to do now is derive such orthogonal functions in the general
case.
Mike Williams
Gentleman of Leisure
Date: 22 Feb 2005 09:41:08
Message: <421b4484$1@news.povray.org>
"Christopher James Huff" <cja### [at] gmailcom> wrote in message
news:cjameshuff-64B309.20125721022005@news.povray.org...
1. A ray hits isosurface at point A = (x, y, z)
2. f(A) = (u, v, 0) = w
3. pigment(w)
For 2: To calculate u and v it is necessary to know the basis point (u = v =
0) on the surface of the isosurface and in which directions u, v are + or -.
This method is theoretically applicable for isosurfaces with 1 surface.
A more advanced algorithm can keep record of each separate surface
(iso-object) of the isosurface in database-like extensible structure. Every
iso-object will have its own basis point and directions for u, v(manually or
automatically set) and therefore own function for co-ordinates
transformation.
> As it is, you're essentially asking for "magic".
Is the above algorithm mathematically impossible(analytically and
numerically)?
Thank you,
William
Date: 22 Feb 2005 09:44:46
Message: <q6hm11pngrnnpr328aa6ifd3dak5oh2oov@4ax.com>
On Tue, 22 Feb 2005 06:38:50 +0000, Mike Williams <nos### [at] econymdemoncouk>
Yes, the tutorial is in the tutorial group since about 4 years. IIRC it was
title with "isomaze tutorial". I do not rember what was the last POV-Ray
version I tried it with.
ABX
Date: 22 Feb 2005 10:22:05
Message: <cjameshuff-53CA25.10221222022005@news.povray.org>
In article <421b4484$1@news.povray.org>,
> numerically)?
Yes. You could come up with a numeric method for finding separate
surfaces, but only with great difficulty and it would be either very
unreliable or very slow. (One method that comes to mind would be
building a voxel map and searching for disconnected regions of voxels.
Another would require tessellating the isosurface and searching for
unconnected groups of triangles. Neither would succeed if you have a
contiguous surface enclosing multiple separate volumes.)
Once you have that, you've still got the first "magic" step of finding a
sensible mapping between spatial coordinates and surface coordinates. So
you pick an origin point and two basis vectors...where do you go from
there? As far as I can tell, that's only enough for "height field" type
isosurfaces, a simple sheet displaced vertically without any overhangs.
There are many surfaces that simply can't be seamlessly mapped to a 2D
plane. The sphere is the simplest example. How would your hypothetical
algorithm UV map a sphere?
And assuming you finally figure out how to automatically define a
mapping, you'll just get something that doesn't make any sense to a
human. If the mapping is unpredictable, it's useless. The only practical
option is to design the mapping specifically for the object and intended
purpose, and doing so is impossible for something as flexible as an
isosurface.
Date: 22 Feb 2005 12:36:47
Message: <421b6daf@news.povray.org>
news:cjameshuff-53CA25.10221222022005@news.povray.org...
I'm confused, uv-mapping a sphere isn't difficult, is it?
cu!
Date: 22 Feb 2005 15:37:44
Message: <cjameshuff-B7F0FA.15374922022005@news.povray.org>
In article <421b6daf@news.povray.org>,
It's very easy, there are several ways to do it, but none are seamless,
and I see no reasonable way for a general algorithm to automatically UV
map a sphere. You need to specifically specify that you want to use a
sphere mapping.
The basic problem is this...given a point where u and v coordinates are
zero, and basis vectors for the u and v axii at that point, what are the
UV coordinates at some other point? That's all the information you have,
unless you somehow collect other information beforehand. You don't have
the sphere center or radius, because you don't know it's a sphere. You
could probably do some analysis of the surface to determine if it's
close enough to spherical and find the approximate center, but that's
slow, complicated, unreliable, and you'll need to make additional
special cases for other basic shapes.
The only reasonable solution is to require the user to specify what he
wants. That's only slightly awkward to do with function patterns...it's
worse with things like image_maps though. A general (not specific to
isosurfaces) user-defined UV mapping using functions could be useful,
but it's hardly a critical feature.
Date: 1 Mar 2005 16:30:54
Message: <4224df0e$1@news.povray.org>
> human.
I agree that many mappings one might pick would be unintuitive, but that
does not mean that it's impossible to define a good mapping.  For
example, having the u and v coordinates follow the lines of principal
curvature I imagine would often give pretty good results (provided one
takes care of the ambiguities in this definition, like where to put the
origin, what to do with planar regions, etc).
That said, I wholeheartedly agree that it would be difficult to
implement such a system, and that it would probably render unreasonably
slowly anyway.  This is probably the sort of thing that would be better
solved by having a scripting language for materials, so that ambitious
users could program in their curvature-based uv mapping or whatever
suites their needs for the object they wish to model.
Date: 2 Mar 2005 13:10:46
Message: <cjameshuff-90B1C8.13104602032005@news.povray.org>
In article <4224df0e$1@news.povray.org>,
I honestly don't see much of a difference between this and my suggestion
of using user-defined functions as a general-purpose UV mapping option
available for *all* objects.
Date: 2 Mar 2005 13:57:14
Message: <42260c8a$1@news.povray.org>
It's not, I just missed that part of your post -- sorry about that!
