POV-Ray : Newsgroups : povray.general : Creating 16-bit HFs from C++ Server Time
1 Nov 2026 08:28:49 EST (-0500)
  Creating 16-bit HFs from C++ (Message 1 to 18 of 18)
Subject: Creating 16-bit HFs from C++
Date: 21 Feb 2005 05:57:12
Message: <4219be88$1@news.povray.org>
I'm writing some code in C++ (on windows) to generate some 16-bit height
field data.  What is going to be the easiest way for me to export the
numbers to use in POV?  The PNG file format looks pretty complex (compared
to BMP which is what I'm used to).
Is there any way to make POV use red+256*green or something like that from a
BMP file?  Or some software that will make red+256*green into 16-bit grey
PNG?
Thanks
Scott
Subject: Re: Creating 16-bit HFs from C++
Date: 21 Feb 2005 07:18:38
Message: <4219d19e$1@news.povray.org>
> PNG?
> Thanks
> Scott
Hi Scott
You could use TARGA to export your data. There is an introduction to
this format here :
http://astronomy.swin.edu.au/~pbourke/dataformats/tga/
I did write a piece of C++ some years ago that handled the
reading/writing of TGA images, but I fear it's not terribly well
coded... And it is badly commented, and in french... I could give a try
at cleaning it up if you wish, but I think you'd be better off writing
it yourself ;-) Anyway the format is rather easy to understand.
Hope this helps
Vincent
Date: 21 Feb 2005 09:45:33
Message: <4219f40d@news.povray.org>
  The png format is not intended to be read/written directly (unless you
are a really hardcore programmer... :P ) but there are libraries for
that purpose. Of course at least the most common png library is pretty
hard to use all on itself, but that's another issue... ;)
> PNG?
  From http://povray.org/documentation/view/3.6.1/279/
"The TGA and PPM file formats may be used as a storage device for 16
bit numbers rather than an image file. These formats use the red and
green bytes of each pixel to store the high and low bytes of a height
value."
  The raw TGA file format is extremely simple. It has a 18-byte header
(which format is fixed) and then the raw image data.
Date: 21 Feb 2005 10:31:25
Message: <4219fecd@news.povray.org>
> value."
Thanks, raw TGA is exactly what I need.  Cheers.
Date: 21 Feb 2005 14:27:59
Message: <cjameshuff-F0941A.14280321022005@news.povray.org>
In article <4219be88$1@news.povray.org>, "scott" <sco### [at] spamcom>
PNG would be the best option. libpng is really not that hard to use,
just follow the examples in the documentation. You get lossless
compression and files that are widely supported.
Alternatively, you could encode the data as 16 or 24 bit fixed point
float values split into 8 bit chunks among the RGB channels, and either
use POV-Ray's built in red-green "16 bit grayscale TGA" feature or
combine the channels manually using a function to generate the height
field. I would suggest the latter...it seems most flexible.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 23 Feb 2005 01:13:19
Message: <421c1eff$1@news.povray.org>
Have you considered writing the data out as a mesh2?  Since you're
writing a C++ program anyway, it's probably a lot easier to write a few
floating point numbers out in text format than to write out a specific
image file format.  Plus you get to have a greater degree of precision
than with a 16 bit image file.  Also you can control the mesh smoothing
if you calculate a few normal vectors.
I wrote a C++ program (win32 command line) that takes a raw 32bit
floating point output file from World Machine, calculates the mesh, does
a non linear transform (cylindrical wrapping), calculates the normal
vectors, then spits out a mesh.  Email me if you'd like the source and
you can feel free to use it however you like.
Peter D.
> PNG?
> Thanks
> Scott
Date: 23 Feb 2005 05:53:01
Message: <421c608d@news.povray.org>
Peter Duthie <pd_### [at] warlordsofbeercom> wrote:
> does a non linear transform (cylindrical wrapping)
... to the vertex points, you mean?
  (Technically a mesh is more than just its vertex points, and performing
a transformation on the vertex points is not the same thing as performing
a transfromation on the mesh.)
Date: 23 Feb 2005 12:04:57
Message: <421cb7b9$1@news.povray.org>
Aha, me too, but linux is my choice.
As Christopher mentioned libpng is not that hard to use.
Just yesterday I took a look at the manpage (man libpng) and there are
several examples on how to write the image data.
I didn't try it yet, but it didn't look too complicated.
Maybe within the next week I'll have some C++ code.
Sebastian H.
Date: 23 Feb 2005 13:01:13
Message: <421cc4e9$1@news.povray.org>
I believe height fields trace considerably faster than their equivalent
meshes.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 23 Feb 2005 13:19:25
Message: <cjameshuff-99376F.13180923022005@news.povray.org>
In article <421cc4e9$1@news.povray.org>, "Slime" <fak### [at] emailaddress>
> meshes.
Have you tried it? (I haven't...I'm really wondering if there's much of
a difference.)
A mesh has other advantages as well. You could create overhangs and
other structures, make it higher resolution tessellation in areas that
are more important, use a tessellation that doesn't produce artifacts
that are as obvious, etc. You can also compute the normals more
precisely while you're generating the mesh, rather than estimating them
from the triangle data. Look at the height field macros to see the
difference this can make...they compute the normal by looking at the
slope of the height function.
On the other hand, an image-based height field is easier to
edit...though you really need something that can handle 16 bit images.
Date: 23 Feb 2005 13:19:56
Message: <cjameshuff-89640C.13200523022005@news.povray.org>
In article <421cb7b9$1@news.povray.org>, "Sebastian H." <van### [at] gmxde>
Both reading and writing are really pretty easy, though you have to
write a bit more code than is convenient. It would really be nice if
they made an ultra-simple convenience API available. There are wrappers
out there that simplify things, though you will probably need to modify
them to allow 16 bit images.
Date: 23 Feb 2005 14:06:50
Message: <421cd44a@news.povray.org>
> a difference.)
Yes, but it was a while ago.
 - Slime
Date: 23 Feb 2005 17:28:58
Message: <421d03a9@news.povray.org>
> > meshes.
> a difference.)
  The tracing of a heightfield takes advantage of its geometry for
speed so in theory it should be faster than a generic mesh.
  Also heightfields use reference counting in the same way as meshes.
Date: 24 Feb 2005 00:10:50
Message: <421D6089.3000605@joplin.com>
I have wrote a program with C++ and VIDE to make 8 or 16 bit height
feilds from contour lines. It for win98.
It's at http://leroywhetstone.s5.com/
I used PPM to save the 16 bit height feilds ,TGA for 8 bit height feilds
and BMP for the contour maps files . I hand coded the PPM & TGA file
functions and use windows functions for BMP.
If the program doesn't do what you need E-mail me and I can send you the
code. It might be a little messy and if you don't have VIDE you may
still be able to figure it out.
> PNG?
> Thanks
> Scott
Date: 28 Feb 2005 17:21:24
Message: <42239964$1@news.povray.org>
I mean to the mesh.  In that the mesh consists of verticies, edges,
faces, uv_vectors, and normals.  Transforming the verticies will
generally transform the edges and faces with which they are associated
unless my understanding of meshes is fundamentally flawed.  Normally, UV
coordinates will want to be preserved, not transformed, but then again I
didn't add uv_vectors in the first place so it wasn't relevant but I can
see how this might be to others in some cases.  This leaves normals,
which are transformed similarly to the verticies without any ill
effects, at least in the transforms I performed.  I'd be interested in
knowing specifically what problems you can foresee with this sort of
mesh transformation so that I can try to come up with a solution.
Thanks,
Peter D.
Date: 1 Mar 2005 05:25:14
Message: <42244309@news.povray.org>
  We are talking about non-linear transformation here.
  Moving the vertices around will only apply a linear transformation
to the edges and faces.
  Applying a true non-linear transformation to the mesh would bend the
edges of the triangles (and thus their surfaces). However, no renderer
I know of can do this (some renderers subdivide the triangles to get
more "bending", but it's still just an approximation, not a true
non-linear transformation).
  Usually a "non-linear" transformation of a mesh is performed by just
moving the vertices (and normals). The edges and faces keep straight
regardless (which means that only linear transformations are performed
to them in practice).
  The problem is that the "non-linear" transformation of a mesh is only
as good as the size of its triangles.
  If you have for example a box consisting of two triangles per side,
twisting the box is basically impossible (without subdividing the
triangles).
Date: 2 Mar 2005 02:10:44
Message: <422566f4$1@news.povray.org>
Ok, I see what you're talking about now.  Yes, as we're talking about
meshes, the non linear transformations occur on the verticies and
normals.  I agree that there is indeed no way to apply a non linear
transformation to edges and faces in conventional meshes as they are
represented as a relationship between verticies, not as independent
entities.  When you think about it, even subdividing meshes isn't
applying a non linear transformation to edges and faces, as what is
actually happening is a linear transformation plus one or more
additional edges and faces per original edge and face.  The only way to
do this would be to change the format of the mesh such that the edges
were represented as an algorithm rather than a relationship, and then it
would not be a mesh anymore, more like a collection of Bezier patches.
Peter D.
> triangles).
Date: 2 Mar 2005 06:10:36
Message: <42259f2c@news.povray.org>
> The only way to
  That's where NURBS kick in... :P
