POV-Ray : Newsgroups : povray.general : tracking simulation Server Time
11 Jul 2026 01:07:34 EDT (-0400)
  tracking simulation (Message 1 to 4 of 4)
Subject: tracking simulation
Date: 8 Feb 2005 14:31:24
Message: <4209138c@news.povray.org>
I've post my problem in here long time ago. But my problem haven't
solved yet. Here is the revision of my problem.
I'm doing position tracking with some marker base system (using computer
vision technique). This system is finished and I'm going to use it as a
base of an application which I'm going to develop. (It is about
augmented reality)
What I've done so far is the simulation tracking and the real world
tracking. The result of real world tracking is very accurate, with about
+/-3cm deviation. But for the simulation, though the planar position (x
and y) is very accurate, but the distance (z) is very inaccurate, with
the average deviation of about 40cm. Which is very unacceptable.
For now, I'm going to vary the focal length of the camera to see if it
is related, but seems it is not the source of error. I've read from this
newsgroup that the pov-ray unit is not related to the real world unit
(centimeter or meter). Would it be the source of the error?
And also, reply from the previous post suggest that I've distorded the
output image. I've double check it and I'm not distorting it.
So anyone has any clue on it?
Here is my camera definition, which is simulating the real camera in the
real world tracking:
camera
    location <61.5, 74.55, -200>
    direction <0, 0, 1.7526>
    look_at <61.5, 74.55, 0>
As this is a square pixel camera, and with normal 4/3 aspect ratio, so
the image is rendered with the dimension 384x288 (both resolution are
the same).
P.S.: markers are texture mapped into the virtual scene.
cheers
Colin
Subject: Re: tracking simulation
Date: 8 Feb 2005 15:29:17
Message: <4209211d$1@news.povray.org>
Though a POV-Unit is not "standardized" in any way to be either cm, or
meter, or mile, or whatever, this doesn't mean that the usual physics don't
apply (as in parallax effects, angles, distances, etc). It's just that you
can't tag unit = cm. Just think about it, even cm is just an arbitrary
dimension someone has thought up someday.
So it just depends on your scene-file if unit=cm or unit=meter or unit=?.
That just means you've got to multiply the distances with some factors.
As for the 40cm deviation: is that only happening on the POV-Ray images?
Could you post a comparison image of photo vs Pov-Ray image with markers to
p.b.i?
"Tim Nikias v2.0"
Date: 9 Feb 2005 06:59:30
Message: <4209fb22$1@news.povray.org>
> p.b.i?
Thanks for the comment on my problem. But just a silly question...
what's p.b.i???
Date: 9 Feb 2005 07:09:58
Message: <4209fd96$1@news.povray.org>
news:4209fb22$1@news.povray.org...
> what's p.b.i???
the newgroup povray.binaries.images on this server
Marc
