POV-Ray : Newsgroups : povray.general : um... Server Time
21 Oct 2026 04:44:05 EDT (-0400)
  um... (Message 1 to 7 of 7)
Subject: um...
Date: 27 Jan 2005 14:24:58
Message: <41f9400a$1@news.povray.org>
the following scene
#include "math.inc"
#declare r=1;
#declare d=0.1;
#declare ridges=24;
isosurface{
   function{ sqrt(x*x+y*y)-r - (cos(atan(y/x)*ridges)*d) }
   threshold 0
   max_gradient 2
   contained_by {box{<-1,-1,0>, <1,1,1>}}
   texture{pigment{color rgb 1 transmit 0.5}}
gives the following error
File: C:\Data\3D\bumpycyl.inc  Line: 5
Fatal Error: Floating-point exception detected in function ''. Your
function either attempted a division by zero, used a function outside
its domain or called an internal function with invalid parameters.
but only if antialiasing is turned on, and then not at all camera angles.
Tim Cook
Version: 3.12
Subject: Re: um...
Date: 27 Jan 2005 14:55:09
Message: <uchiv0d1iq26r069oi5htepeasqhiokd92@4ax.com>
On Thu, 27 Jan 2005 14:24:57 -0500, Tim Cook <z99### [at] bellsouthnet> wrote:
> #include "math.inc"
> #declare r=1;
> #declare d=0.1;
> #declare ridges=24;
> isosurface{
>    threshold 0
>    max_gradient 2
Some answers I can imagine are:
1) you have librarypath set with some math.inc different than the one from
POV-Ray
2) you have some ini setting which cause inclusion of other file (+HI)
3) memory corruption
try to exclude any of them to find real problem.
Can you duplicate this exactly the same after rest(art) of your computer?
ABX
Subject: Re: um...
Date: 27 Jan 2005 15:54:57
Message: <41f95521$1@news.povray.org>
Hash: SHA1
	I'm guessing that at some camera angles you'll have a ray where POV
attempts to evaluate the function for x==0 which will produce the error.
	When using AA, you shoot more rays which increases the probability
that one will encounter the problem, but it should be possible to
find a camera position that will cause it too...
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFB+VUfqIYJdJhyixIRAsp3AKCMQpQsiJqoQ/lGOCxGeTPXx2taNACeMeSn
QNloxYof/t1iEwKEWIXaPwc=
=gaJ4
-----END PGP SIGNATURE-----
Subject: Re: um...
Date: 27 Jan 2005 16:14:01
Message: <41f95999$1@news.povray.org>
You can try replacing atan(y/x) by atan2(y,x) which avoids the division by
zero and also avoids the problem that 1/2 is equal to -1/-2 and thereby
gives more useful results for all values of x and y.
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: um...
Date: 27 Jan 2005 18:58:55
Message: <41f9803f$1@news.povray.org>
Whee, that fixed it.  Thanks!
Tim Cook
Version: 3.12
Subject: Re: um...
Date: 28 Jan 2005 07:29:52
Message: <vsbkv09v6cpojcgrmfppj5448pceo5l8jl@4ax.com>
Oups. Forget my guessing. I'm so used to the ".pov" extension of the rendered
scene that I was mistaken by ".inc" that you refering inclusion of unknown
file and did not carefully readed rest of the message. Of course others were
smarter than me.
ABX
Subject: Re: um...
Date: 31 Jan 2005 20:22:42
Message: <41fed9e2@news.povray.org>
I like this
