POV-Ray : Newsgroups : povray.general : U-bar bend - at any other angle than 90 Server Time
11 Jul 2026 02:46:47 EDT (-0400)
  U-bar bend - at any other angle than 90 (Message 1 to 4 of 4)
Subject: U-bar bend - at any other angle than 90
Date: 23 Jan 2005 17:18:21
Message: <41f422ad@news.povray.org>
I have developed the following macro for a U-bar. However I want to
develop it further to allow for any other angles on the corners.
	UBar( width, height, leftangle, rightangle,
		cross-section-radius, corner-radius )
This will allow for Ubars that look like this:
\___/
It's easy to get the right angle on everything ... slicing the corner
toruses (torii?) at the right angle and positioning the side bar at the
right angle ... however, I cant work out how to position the side bar.
Any help would be greatly appreciated.
Cheers!
__SCENE__
   location  <0.0, 0.5, -4.0>
   direction 1.5*z
   look_at   <0.0, 0.0,  0.0>
sky_sphere {
     gradient y
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
light_source {
   <0, 0, 0>            // light's position (translated below)
   color rgb <1, 1, 1>  // light's color
   translate <-30, 30, -30>
#macro ubar( Bwidth, Bheight, barradius, curveradius)
union {
         // Bar on the bottom of the U
         cylinder {
                 <(Bwidth * -0.5) + (barradius) + curveradius,
(barradius), 0>
                 <(Bwidth * +0.5) - (barradius) - curveradius,
(barradius), 0>
                 barradius
         // Left bar
         cylinder {
                 <(Bwidth * -0.5) + (barradius), (barradius) +
curveradius, 0>
                 <(Bwidth * -0.5) + (barradius), Bheight,
          0>
                 barradius
         // Left bar
         cylinder {
                 <(Bwidth * +0.5) - (barradius), (barradius) +
curveradius, 0>
                 <(Bwidth * +0.5) - (barradius), Bheight,
          0>
                 barradius
         // Lower left curve
         intersection {
                 torus {
                         curveradius
                         barradius
                         rotate <90, 0, 0>
                         translate < (Bwidth * -0.5) + (barradius) +
curveradius, (barradius) + curveradius, 0>
                 box {
                         <(Bwidth * -0.5) -0.1,
(barradius) + curveradius, barradius * -1 - 0.1>
-0.01, barradius * +1 + 0.1>
         // Lower right curve
         intersection {
                 torus {
                         curveradius
                         barradius
                         rotate <90, 0, 0>
                 box {
                 rotate <0, 180, 0>
object {
         ubar( 2, 1, 0.012, 0.12 )
                 pigment { White }
                 finish { reflection 0.25 }
Subject: Re: U-bar bend - at any other angle than 90
Date: 23 Jan 2005 17:21:51
Message: <41f4237f@news.povray.org>
Well, you could use vrotate(A,B), which rotates the vector A about the axis
B. Use it on the base and end point of the second cylinder. If you've got
the angle, the remaining bit is just trivial arithmetic.
Tim
"Tim Nikias v2.0"
Subject: Re: U-bar bend - Success (and my scene)
Date: 24 Jan 2005 00:39:21
Message: <41f48a09$1@news.povray.org>
Thanks Tim ... I did it another way though. However I might still look
into your idea. I moved the object so the torii were at <0,0,0> then put
the vertical pipe at <torus_radius,0,0>. As rotations apply to the
zero-point, the pipe rotates to the correct location.
Here's my shopping trolley (which is the purpose of writing this macro,
although I'll save it in an inc, ready for next time)
[BTW: Anyone who reads this, feel free to explain why rendering time
went through the roof once I put in the intersection to trim the top off
the vertical bars]
__SCENE__
#version 3.5;
#include "metals.inc"
global_settings {
   assumed_gamma 1.0
   location  <-20.0, 20, -10>
   direction 1.5*z
   look_at   <0.0, 4.5,  -3>
sky_sphere {
     gradient y
     color_map {
light_source {
plane {
   y, -1
   pigment { White * 2 }
#macro ubar( Bwidth, Bheight, lAngle, rAngle, barradius, curveradius)
union {
         union {
                 cylinder {
                         <(Bwidth * -1) + curveradius * 2, curveradius *
  1, 0>
                         <0,                               curveradius *
-1, 0>
                         barradius
                 // Right Torus
                 intersection {
                         torus {
                                 curveradius
                                 barradius
                                 rotate <90, 0, 0>
                         intersection {
                                 plane {
                                         y,
                                         0
                                         rotate <0,0,90>
                                 plane {
                                         y,
                                         0
                                         rotate <0,0,-90+rAngle>
                 // Bar on the right
                 cylinder {
                         <curveradius,0,0>
                         <curveradius,Bheight - curveradius,0>
                         barradius
                 translate <(Bwidth - curveradius * 2), 0, 0>
         // Left Torus
         intersection {
                 torus {
                         curveradius
                         barradius
                         rotate <90, 0, 0>
                 intersection {
                         plane {
                                 y,
                                 0
                                 rotate <0,0,-90>
                         plane {
                                 y,
                                 0
                                 rotate <0,0,90-lAngle>
         // Bar on the left
         cylinder {
                 <0-curveradius,0,0>
                 <0-curveradius,Bheight - curveradius,0>
                 barradius
         translate <(Bwidth - (curveradius * 2)) * -0.5, curveradius, 0>
#macro wheel( Wradius, Wthickness )
union {
         cylinder {
                 <Wthickness * -0.51, Wradius, 0>
                 <Wthickness * +0.51, Wradius, 0>
                 Wradius * 0.95
                         pigment { White }
                         finish { reflection 0.05 }
         cylinder {
                 <Wthickness * -0.50, Wradius, 0>
                 <Wthickness * +0.50, Wradius, 0>
                 Wradius
                         pigment { Black }
         torus {
                 Wradius * 0.9
                 Wradius / 10
                 rotate <0,0,90>
                 translate < Wthickness * -0.5, Wradius, 0>
                         pigment { Black }
         torus {
                 Wradius * 0.9
                 Wradius / 10
                 rotate <0,0,90>
                 translate < Wthickness * +0.5, Wradius, 0>
                         pigment { Black }
union {
         #declare barradius = 0.025;
         #declare basketangle = 5;
         union {
    // /*  Uncomment these comments to remove the intersection that
slows it down .. there's more below too. I think I've marked the right
places ;)
                 intersection {
                         union {
                                 #declare Index = 1;
                                 #while( Index <= 30 )
                                 object {
                                         ubar( 5, 6, 90, 90, barradius,
0.15 )
                                         rotate <-1*basketangle,0,0>
                                         translate <0, 0, Index * 0.25 -
(15 * 0.25)>
                                 #declare Index = Index + 1;
                                 #declare Index = -2.25;
                                 #while( Index <= 2.25 )
                                 object {
                                         ubar( 7.5 + 0.3, 6,
90+basketangle, 90-basketangle, barradius, 0.15 )
                                         rotate <0, 90, 0>
                                         translate <Index, barradius *
-1, 0>
                                 #declare Index = Index + 0.25;
                                 rotate <basketangle,0,0>
                         box {
                                 <-5, -1, -5>
                                 <5, 5, 5>
                 #declare Index = 0.5;
                 #while( Index < 5 )
                 object {
                         ubar( 5+barradius*2, 7.5+barradius+0.3, 90, 90,
barradius, 0.15 )
                         rotate <90, 0, 0>
                         translate <0, Index, -3.75-0.15-barradius>
                 #declare Index = Index + 0.5;
                 object {
barradius*2, 0.15 )
                         rotate <90, 0, 0>
                 translate <0, 3, -3.75-0.15-barradius>
         difference {
                 union {
                         object {
                                 ubar(7, 8, 90, 90, 0.2, 0.5)
                                 rotate <0, 90, 0>
                                 translate <-2.55, 0, -3.3>
                         object {
                                 rotate <0, 90, 0>
                                 translate <2.55, 0, -3.3>
                 box {
                         <-3.0, -0.1, -6.0>
                         <+3.0, 10.4, -7.7>
         //front bumper
         object {
                 ubar( 2.55*2, 2, 90, 90, 0.2, 0.5)
                 rotate <90, 0, 0>
                 translate <0, 0.0, -7.5>
         //handle
         object {
                 rotate <180, 0, 0>
                 translate <0, 9.0, barradius+0.15>
         translate <0, 1.6, 0>
                 T_Chrome_2A
                 finish { reflection 0.5 }
//handlebar
cylinder {
         <-2.0, 10.6, barradius+0.15>
         <+2.0, 10.6, barradius+0.15>
         0.25
                 pigment { Red }
object {
         wheel(0.8, 0.25)
         translate <-2.55, 0, -0.5>
object {
         wheel(0.8, 0.25)
         translate < 2.55, 0, -0.5>
object {
         wheel(0.8, 0.25)
         translate <-2.55, 0, -6.5>
object {
         wheel(0.8, 0.25)
         translate < 2.55, 0, -6.5>
__END__
Date: 24 Jan 2005 09:59:21
Message: <41f50d49$1@news.povray.org>
Don't know if it fits your problem, but there's a Round_Bent_Box macro
out there (shameless plug, I know :)
http://povray.tirnalong.com/ow.asp?MoreShapes
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
