I would try this, maybe in a macro:
First cut out the hole like you did
> ___ __
> |____|
Then cut out a hole not so deep but with a bigger radius
__ __
|_ _|
|____|
The last thing is placing a torus that way, that it fills the edges. The
major radius for the torus is the radius for the bigger hole and the
minor radius is the radius for the first hole you made.
___ _ _ ___
| |_\ /_| |
\___| |___/<-- this is the torus
|____|
I hope this is clear enough.
I also could post some code if you wish...
So long,
Bonsai
___ __ __ _ ___ ___ _
| _ ) \ \( ) _) _ )( )
| _ \() |\ \ |\ \/ _ \| |
|___/__/_)\__)___)/ \_)_)
www.b0n541.net
Bonsai wrote:
Something thats incorrect because he had not enough coffee, yet. ;-)
The radius for the minor radius is the difference between the radii of
the two holes.
Here is a short example scene:
#default {
texture { pigment {color rgb 1}}
// create a regular point light source
light_source {
<20, 40, -20>
color rgb <1,1,1> // light's color
// perspective (default) camera
location <10, 10, 0>
look_at <0.0, 5.0, 0.0>
merge {
difference {
box { <-5, -5, -5>, < 5, 5, 5>}
cylinder { <0, 0, 0>, <0, 6, 0>, 2 }
cylinder { <0, 4, 0>, <0, 6, 0>, 3 }
torus { 3, 1 translate <0, 4, 0>}
Hope that helps...
So long,
Bonsai
www.b0n541.net
