POV-Ray : Newsgroups : povray.general : Possible bug with "frequency" in maps Server Time
21 Oct 2026 05:50:31 EDT (-0400)
  Possible bug with "frequency" in maps (Message 1 to 6 of 6)
Subject: Possible bug with "frequency" in maps
Date: 5 Jan 2005 13:36:26
Message: <41dc33a9@news.povray.org>
Has this been already discussed? I didn't find anything relevant.
When using non-integer "frequency" value in "color_map" (or "pigment_map" or
whatever) with "gradient", there's a behavior change at the origin.
Consider this almost minimal example:
camera { location -10*z look_at 0 }
light_source { 20*<-1, 1, -1>, color rgb 1.5 }
box { -4, 4
  pigment { gradient y
    color_map {
      [0.0 color rgb <1, 0, 1>]
      [1.0 color rgb <0, 1, 1>]
    // see the difference between the positive and negative zones
    // it looks fine with integer values
    // it looks "funny" with non-integer values
    frequency 0.5
  scale 0.8
Below the y=0 plane, the gradient looks OK, with a period twice as large as
normal. Above the plane, the period is still 1 unit, but the colour range
has been stretched and clipped. A similar things happens with other
non-integer values, try 1.5, for example. It looks like the positive part
is forced to have a period of 1 unit "superimposed" on whatever other
period there might be.
I've only tested this with "gradient" (only with "gradient y", to be true),
but it happens with all waveforms (sine_wave, triangle_wave...)
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Subject: Re: Possible bug with "frequency" in maps
Date: 8 Jan 2005 08:26:12
Message: <41dfdf73@news.povray.org>
That's exactly what's happening. In the source file pattern.cpp we find this
piece of code:
static DBL gradient_pattern (VECTOR EPoint, TPATTERN *TPat)
  DBL Result;
  VDot( Result, EPoint, TPat->Vals.Gradient );
  /* Mod to keep within [0.0,1.0] range */
  return ((Result > 1.0) ? fmod(Result, 1.0) : Result);
Replacing the last line with "return Result;" fixes the bug with my scene
file.
What's the purpose of this restriction to [0.0 1.0]? Isn't that the job of
the Evaluate_TPat routine (which has another fmod instruction)?
If this further enforcing is needed, shouldn't it be applied to negative
numbers too?
From my limited knowledge of povray innards, this looks to me like a genuine
bug. Is it?
Date: 9 Jan 2005 09:32:47
Message: <41e1408f@news.povray.org>
> genuine bug. Is it?
Comments? Confirmations? Should I post this to p.bugreports?
Date: 12 Jan 2005 19:22:22
Message: <cjameshuff-DA6A58.19222912012005@news.povray.org>
> > genuine bug. Is it?
I think this is a bug. I "fixed" it in a patch which I've just moved
over to MegaPOV, however, I haven't verified that it works properly.
I'm kind of busy starting school again now, but I'll hopefully have my
patches documented and released in a couple weeks. Included are a "no
waveform" patch (which fixes this issue and allows direct use of the
pattern values), crackle optimizatons, 2D crackle, the voronoi pattern,
a faster proximity pattern, blob2 object, and few other updates and new
patches.
http://tag.povray.org/
Date: 19 Jan 2005 09:40:29
Message: <41ee715d@news.povray.org>
Among other things, Christopher James Huff saw fit to write:
Great. Does that mean a post to bugreports is not needed?
Date: 23 Jan 2005 16:48:48
Message: <cjameshuff-DC855B.16484823012005@news.povray.org>
No. If you can come up with a good example, post it. This is just a
third party patch.
