Subject: Re: Indent for POVRay code
Date: 7 Dec 2004 14:05:02
Message: <cp4ujo$56a$1@chho.imagico.de>
Matthias Weißer wrote:
> Hi> > is there something like http://www.gnu.org/software/indent/indent.html> available which takes POVRay code (SDL not the C++ sourcecode) and > reformats it to a given stlye?>
In Emacs you can indent a region according to the current mode (so also
for POV-Ray) with 'indent-region'.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 7 Dec 2004 15:44:54
Message: <41b61646$1@news.povray.org>
Christoph Hormann schrieb:
> Matthias Weißer wrote:>> Hi>> >> is there something like http://www.gnu.org/software/indent/indent.html>> available which takes POVRay code (SDL not the C++ sourcecode) and >> reformats it to a given stlye?>> > > In Emacs you can indent a region according to the current mode (so also > for POV-Ray) with 'indent-region'.
It should be a more automatic tool to reformat my electronic parts
library after creating it out of a database.
Reformating it by hand is not an option.
Maybe I'll give indent itself a try. The structure of the SDL is not
that far from C.
Matthias Weißer
mat### [at] matweide
http://www.matwei.de
"Matthias Weißer" <mat### [at] matweide> wrote in message
news:41b61646$1@news.povray.org...
> Christoph Hormann schrieb:> > Matthias Weißer wrote:> >> Hi> >>> >> is there something like http://www.gnu.org/software/indent/indent.html> >> available which takes POVRay code (SDL not the C++ sourcecode) and> >> reformats it to a given stlye?> >>> >> > In Emacs you can indent a region according to the current mode (so also> > for POV-Ray) with 'indent-region'.>> It should be a more automatic tool to reformat my electronic parts> library after creating it out of a database.>> Reformating it by hand is not an option.>> Maybe I'll give indent itself a try. The structure of the SDL is not> that far from C.>
when you mentioned this earlier, I did find a program called Indent++ (i
think) that was written as a college project it seems. it's goal was to
rewrite GNU Indent for C++ syntax, and make is easily extensible to other
languages. The README text wasn't very promising though. Sounded like it had
memory leaks and performance problems. If you're a programmer though, it
might be a starting point for a new pov utility.
good luck in your hunt.
Date: 7 Dec 2004 16:08:59
Message: <41b61beb$1@news.povray.org>
You may also look at http://astyle.sourceforge.net/ which
supports C, C++, and Java, so hopefully is designed well enough for
allowing other languages/syntaxes to be added.
Never tested it though.
- NC
