POV-Ray : Newsgroups : povray.general : Indent for POVRay code Server Time
21 Oct 2026 06:28:39 EDT (-0400)
  Indent for POVRay code (Message 1 to 5 of 5)
Subject: Indent for POVRay code
Date: 7 Dec 2004 12:51:11
Message: <41b5ed8f@news.povray.org>
Hi
is there something like http://www.gnu.org/software/indent/indent.html
available which takes POVRay code (SDL not the C++ sourcecode) and
reformats it to a given stlye?
Matthias Weißer
mat### [at] matweide
http://www.matwei.de
Subject: Re: Indent for POVRay code
Date: 7 Dec 2004 14:05:02
Message: <cp4ujo$56a$1@chho.imagico.de>
Matthias Weißer wrote:
> Hi
In Emacs you can indent a region according to the current mode (so also
for POV-Ray) with 'indent-region'.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 7 Dec 2004 15:44:54
Message: <41b61646$1@news.povray.org>
>> Hi
It should be a more automatic tool to reformat my electronic parts
library after creating it out of a database.
Reformating it by hand is not an option.
Maybe I'll give indent itself a try. The structure of the SDL is not
that far from C.
Matthias Weißer
Date: 7 Dec 2004 15:56:58
Message: <41b6191a$1@news.povray.org>
"Matthias Weißer" <mat### [at] matweide> wrote in message
news:41b61646$1@news.povray.org...
> >> Hi
> that far from C.
when you mentioned this earlier, I did find a program called Indent++ (i
think) that was written as a college project it seems. it's goal was to
rewrite GNU Indent for C++ syntax, and make is easily extensible to other
languages. The README text wasn't very promising though. Sounded like it had
memory leaks and performance problems. If you're a programmer though, it
might be a starting point for a new pov utility.
good luck in your hunt.
Date: 7 Dec 2004 16:08:59
Message: <41b61beb$1@news.povray.org>
	You may also look at http://astyle.sourceforge.net/ which
supports C, C++, and Java, so hopefully is designed well enough for
allowing other languages/syntaxes to be added.
	Never tested it though.
	- NC
