POV-Ray : Newsgroups : povray.general : non-mesh meshes Server Time
1 Nov 2026 14:38:39 EST (-0500)
  non-mesh meshes (Message 1 to 18 of 18)
Subject: non-mesh meshes
Date: 18 Sep 2004 00:29:17
Message: <414bb99d$1@news.povray.org>
I've had this strange question going around in my head for awhile now, so I
thought I would finally ask:
My understanding of meshes is not complete, but in theory, it seems like it
would possible to take a mesh object, and convert each of the mesh triangles
(including normals) into dissected CSG spheres which are then scaled,
rotated, and translated into place.
Has anyone ever experimented with this?  Obviously, render time would be
much slower, especially if many difference operations are involved, and it
just might be impossible with today's hardware and todays' large meshes.
Additionally, I would guess that uv_mapping would be out of the question
without a specific patch that supports this.  Nevertheless, it could be a
useful tool in some, if not many, situations.
Jeremy
www.beantoad.com
Subject: Re: non-mesh meshes
Date: 18 Sep 2004 02:05:58
Message: <+7jzgKA4A9SBFw7N@econym.demon.co.uk>
A sphere only has 4 degrees of freedom, so you could place a sphere so
that it intersected the three vertices of the triangle, and matched ONE
of the vertex normals. That would then uniquely define the sphere. The
other two vertex normals would not match except in a few specific
situations.
Mike Williams
Gentleman of Leisure
Date: 18 Sep 2004 20:36:17
Message: <414cd481$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:+7jz### [at] econymdemoncouk...
> situations.
Ahhh...  I didn't realize that each vertex had a normal.  I guess I need to
learn more about smooth meshes/triangles.  Now I guess I'll have to start
thinking about using iso-surfaces, in which case, I think I'm going to stop
thinking.
Thanks for the answer.
Jeremy
www.beantoad.com
Date: 19 Sep 2004 07:40:33
Message: <414d7030@news.povray.org>
  You mean something like this?
http://www.geocities.com/ccolefax/images/createmesh.jpg
Date: 19 Sep 2004 10:26:43
Message: <414d9723@news.povray.org>
Not sure where you are heading with it.  It would seem that you could
take any three points and generate a triangular shape from planes and
use it to difference a sphere surface but the edges would still be
curved and not follow a straight line between the points. ( iso_csg has
a function for generating a triangle from three points btw which could
be used to clip the sphere surface )  Also I have been playing with
using complex clippings of sphere surfaces to use as hair.  Actually it
is kind of on the back burning right now but it seemed quite fast
rendering.  Don't know if any of that relates to your problem.
Date: 20 Sep 2004 09:53:29
Message: <414ee0d9$1@news.povray.org>
news:414d9723@news.povray.org...
>> I thought I would finally ask:
>> it would possible to take a mesh object, and convert each of the mesh
>> triangles (including normals) into dissected CSG spheres which are then
>> scaled, rotated, and translated into place.
>> it just might be impossible with today's hardware and todays' large
>> meshes. Additionally, I would guess that uv_mapping would be out of the
>> question without a specific patch that supports this.  Nevertheless, it
>> could be a useful tool in some, if not many, situations.
> Not sure where you are heading with it.  It would seem that you could take
> any three points and generate a triangular shape from planes and use it to
> difference a sphere surface but the edges would still be curved and not
> follow a straight line between the points. ( iso_csg has a function for
> generating a triangle from three points btw which could be used to clip
> the sphere surface )  Also I have been playing with using complex
> clippings of sphere surfaces to use as hair.  Actually it is kind of on
> the back burning right now but it seemed quite fast rendering.  Don't know
Mike actually answered my question, but thanks to you and Warp for the extra
information.
The IC_Triangle function (in ISOCSG.inc) is very close to what I would like.
What I'm thinking of, is a fairly simple way of replacing a mesh (smooth
triangles) with "real" surfaces.  If the IC_Triangle had the ability to pass
the vertex normals as well, and actually have the normals changed into a
real function-based surface, it would be, well, really cool.  In theory,
such a feature could allow someone to completely replace a smooth triangle
mesh with isosurfaces.
It sounds compelling to me, but I'm not sure I could pull-off something of
this magnitude.  In my ideal world, it could be a patch which uses a new
format (mesh3?), or alternately, it could read through a mesh2 object and
convert it into something else (isosurfaces, perhaps).
To back up a little bit, I'm often annoyed by the artifacts that come as a
result of the "smooth triangle" problem.  The problem becomes very visible
at times (e.g. http://www.oyonale.com/ldc/images/fermeture_detail2.jpg
[sorry Gilles]).  However, I see that the new PoseRay does surface
subdivision now, which may aid in alleviating this problem.  So anyway,
that's where I was going with this.
Jeremy
www.beantoad.com
Date: 21 Sep 2004 13:18:01
Message: <41506249$1@news.povray.org>
> come as a result of the "smooth triangle" problem.
http://www.slimeland.com/slimepov/
  -Shay
Date: 21 Sep 2004 13:35:05
Message: <41506649$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:41506249$1@news.povray.org...
Thanks for that.  When I brought up the problem awhile ago (in the
p.tools.poser ng), I had heard that Christophe Bouffartigue had a fix once,
but I couldn't find any mention of it in any of the recent compilations.
I wonder why Slime's patch for the smooth triangle (and shadow-line
artifact) problem never made it into MegaPov.  But I'm guessing it's the
fact that "there is no solution that works in every case".
I tried the new version of PoseRay, and did surface subdivision on the
Victoria 3 model, and it seemed to work for me.  I'm sure there are still
some artifacts, but I guess it becomes a question of degree at that point,
and if you have enough RAM (and patience), you could always subdivide it
more.  IMHO, that is an awesome feature to have.  It's makes a world of
difference for POV-Ray.  (Though I have to say that it took me a few minutes
to figure out how to get it to work.)
I still think it would be waaay cool to be able to turn a mesh into
isosurfaces, though.  I guess I'll have to get smarter.
Jeremy
www.beantoad.com
Date: 21 Sep 2004 16:00:59
Message: <4150887b$1@news.povray.org>
Well...
The smooth triangle bug *is* a bug and there are solutions which work in
every case. However, this bug is very difficult to fix given the way that
it's ingrained in the POV-Ray code. My bug fix was a hack and did not really
address the underlying issue. I hope (and basically expect) that the code
changes for POV-Ray 4.0 will address this issue and treat the smoothing of
triangles more like normal perturbation so that the bug does not occur.
I believe there are two reasons that my "fix" for this bug was not brought
into MegaPov: first, the best feature of SlimePOV (IMO and probably the
opinions of others as well) was the height field normal bugfix, and that and
other height field bug fixes were put into MegaPov and POV-Ray 3.6; these
were probably a distraction from the triangle normal bugfix. Second, the fix
was very messy and ugly, so there probably wasn't much of a desire for other
coders to put it in their patches.
The shadow line artifact is not a bug, however, and there is no real perfect
solution to it. My solution in SlimePOV is also kind of a hack, and it
doesn't really behave completely intuitively.
I was thinking recently, however, about a different possible solution to the
shadow line artifact: what if there were a keyword that prevented the
*inner* surface of an object from casting shadows? That is, an object with
this flag set would only intersect with shadow rays when the shadow rays hit
it on the outside. The shadow line artifact is caused by self-shadowing, but
that self shadowing is from the *inside* of a nearby part of the object. I
think that this would solve the problem for all objects which are completely
contained (no holes in the surface, either missing triangles in a mesh or
clipped_by). But that tends to be a property of 99% of objects in POV-Ray
anyway.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Sep 2004 16:23:02
Message: <41508da6$1@news.povray.org>
Yes I played with it a bit leaving the surfaces flat, the attraction being
that you could then apply a real displaced texture to
the surface.  It was very slow to render and first results were not
too exciting.
Date: 21 Sep 2004 17:42:55
Message: <4150a05f@news.povray.org>
> every case.
  I have to disagree with your definition.
  A bug is, by definition, a programming mistake. That is, a feature was
intended to work in a certain way but due to a programming mistake it
does not.
  Smooth triangles work exactly as they were intended to work and thus
it's not a bug. There's no programming mistake in the smooth triangle
code (with this regard, at least; of course there may be other undiscovered
bugs there... :P ).
  The thing is that the specification of triangle shadowing calculation
was flawed to begin with. It does not have a programming mistake (ie. bug)
but a design mistake.
  Originally (in POV-Ray 3.1 and earlier) smooth triangles were
double-illuminated by default. This is most probably because the
coder who coded the mesh code noticed the artifact too late and
thought making triangles double-illuminated would be the easiest
way around the problem. (It may of course be that he designed
triangles to work like this to begin with, but I would bet that
he did not realize about the normal inversion problem until it
was too late.)
  This is true. When I first figured out the reason for the lighting
artifact in smooth triangles (ie. due to wrongly inverted normals)
I tried looking at the code to see if there would be an easy way to
change this behaviour, and there really wasn't.
  Basically the decision whether or not to invert the normal vector
the primitive returns to the rendering engine should be done based
on the true normal vector at that point of the surface, not based
on the modified normal (which smooth triangles return).
  However, implementing this kind of check would have needed really
ugly kludges to the existing rendering engine, and may have actually
even perhaps slowed down rendering by some small factor (because the
check should be done only for smooth triangles, not every primitive).
  What kind of fix is it?
  This is one kind of solution which has been proposed:
  When testing self-shadowing, translate the starting point of the shadow
ray away from the surface by an amount equivalent to the perturbation
emulated by the normal pattern. (Shadowing from all other objects should
be performed normally, else you run the risk of the translated starting
point ending up inside another object. OTOH one could argue this is
what should happen in the first place, but I think it's a question of
opinion.)
  That would work in most cases, but if the surface of the object is
semitransparent, the shadowing would not be the same with the flag
(otoh, the shadows of semitransparent objects are not realistic in
either case, unless you use photons, which is the correct way to get the
correct shadow, and photons would probably be unaffected by this kind of
flag...)
  (And of course all kinds of pathological cases can be thought of:
For example, what if there's a slightly smaller object inside the
current object? It will cast a shadow to the outer object visible
from the outside... :) )
Date: 21 Sep 2004 18:31:12
Message: <4150abb0$1@news.povray.org>
> > every case.
I figured someone would. =)
> does not.
undiscovered
> bugs there... :P ).
But surely the artifacts caused by inverted normals around edges weren't
intended. I doubt anyone sat down and thought, "then we'll invert the
normals... and this will cause strange shadows along the edges of triangle
meshes, which we want..." It certainly (hopefully! =) ) wasn't a design
decision like this.
So it's kind of like this scenario: I sit down to write a program which
finds the intersection of a ray and a sphere. To do this, I use the cubic
formula. Lo and behold, when I compile and run my program, I discover that
the object I've rendered doesn't look like a sphere, because I should have
used the quadratic formula instead of the cubic. Nonetheless, the program
works as I designed it, and renders the shape that I told it to render - I
simply told it to render the wrong shape. Is that a bug? Well, the program
works as I intended it to work, but the result was not what I had originally
hoped for.
Obviously the case we have here is not such an extreme mistake, but the fact
is, the way POV-Ray was written failed to account for this small issue, and
since it produces a result that was not originally intended, I feel OK
calling it a bug. Smooth triangles *don't* work exactly as they were
intended to work because they were never intended to have this artifact.
But whatever, that's not the important thing. Just as long as no one tries
to call the artifacts a "feature." =)
perfect
> opinion.)
If I remember right, I essentially implemented that solution. I allowed the
user to specify the necessary distance before self-shadowing would occur.
This was kind of ugly because it wouldn't change if, say, you scaled the
object. It's also not a very clean solution to begin with, and it was hard
to find a distance value that worked all over an entire surface.
> flag...)
Yeah, I suppose it would only work well for solid, opaque objects.
True. However, those cases are pretty rare. Especially with the restriction
that the outer object has to be opaque, how often are you going to have an
object nested inside an object needing the fix? And how often is it going to
get into the (ideally small) area that could cause this problem? I think
this would work in most cases, and the real advantage is that its behavior
is predictable.
 - Slime
Date: 21 Sep 2004 23:06:44
Message: <4150ec44@news.povray.org>
I'm admitting that I'm way over my head in this discussion, so I won't be
offended if you inform me that I'm not making any sense. ;-)
To move forward a little and to generalize a little, one of the benefits of
POV-Ray is the fact that it uses function based surfaces (CSG), rather than
meshes.  i.e. A sphere is a sphere, not a bunch of triangles glued together
with normal interpolation.  Imagine placing a sphere inside a slightly
larger mesh-based sphere.  You'd see the smaller sphere poking through the
mesh in some places, even though the mesh-based sphere would actually appear
larger (this could be a neat illusion).  In the long-run, wouldn't it make
more sense to actually create function based, spline-type surfaces?  Is that
what NURBS are?  (If so, then this has probably been discussed before.)
Before you kill me, realize that I'm just making statements based on
something that I know very little about and would have almost no idea how to
implement, so be nice.  ;-)
Oh, also I've apparently been saying "smooth triangle problem" when I should
have really been saying "shadow line problem".  I assumed they were both the
same thing.
Jeremy
www.beantoad.com
Date: 21 Sep 2004 23:47:14
Message: <4150f5c2$1@news.povray.org>
that
Yes, that's what NURBS are AFAIK. However, even NURBS and some other smooth
objects (like bezier patches) which don't have a simple, predefined equation
governing them are approximated by triangles. The reason is that triangles
are a lot faster to render. Try rendering a parametric object in POV-Ray; I
don't believe it approximates the surface with triangles and it severely
impacts the speed.
Another difficulty is that triangle meshes, NURBS, etc all define a surface;
they don't define the "inside" of the object as well as x^2+y^2+z^2 - r^2
defines the inside of a sphere.
Function defined surfaces would certainly be more useful if these problems
didn't exist, but the speed of polygon-based surfaces is worth the
inconveniences.
should
the
> same thing.
They're different but since they both appear with smooth triangles they're
often grouped together.
The smooth triangle "normal flipping" bug (or not bug) occurs around the
edges of an object no matter where you look at the object from, creating a
black halo. The "shadow line" issue occurs at the points of an object with
smoothed triangles or perturbed normals which are along the line where the
light stops hitting the object. This creates a sharp transition from light
into shadow where one would want it to be smooth.
 - Slime
Date: 22 Sep 2004 09:17:16
Message: <41517b5c$1@news.povray.org>
news:41508da6$1@news.povray.org...
>> triangle mesh with isosurfaces.
> too exciting.
With enough surface subdivision, and an bunch of RAM, maybe it would look
pretty good.  After POVComp, I'll probably start messing around with that,
just for fun.  Or maybe not.  I don't like committing myself to anything...
Jeremy
www.beantoad.com
Date: 22 Sep 2004 13:49:54
Message: <4151bb42@news.povray.org>
> intended.
  But the artifacts are not caused by a programming mistake but a design
mistake. There's a difference.
> decision like this.
  Design mistake means that when they designed the engine they didn't
think of this problem. It doesn't have to be intentional.
  The program works exactly as designed (ie is bug-free), but the
design was flawed.
Date: 22 Sep 2004 13:55:00
Message: <4151bc74@news.povray.org>
  The shadow line problem is not exclusive to triangles, but it can happen
with all objects with perturbed normals.
  And for those who have no idea what we are talking about, see the
sections 2.4.8 and 2.4.9 of the 3.6 documentation, or these links
(which contain essentially the same thing):
http://tag.povray.org/povQandT/TheShadowLineArtifact/index.html
http://tag.povray.org/povQandT/SmoothTriangleArtifact/index.html
Date: 22 Sep 2004 17:41:39
Message: <4151f193$1@news.povray.org>
news:4151bb42@news.povray.org...
>> intended.
>> triangle
>> decision like this.
> design was flawed.
Design Flaw = Bug
Design Flaw != Bug
Design Flaw ~= Bug
I think this debate could go on for awhile...  I'm half-expecting a certain
someone to jump in about now and explain to us why this conversation is
pointless and unhelpful.  ;-)  Or does he only do that to me?  :-(
Jeremy
www.beantoad.com
