POV-Ray : Newsgroups : povray.general : Photons and reflections - huh? Server Time
26 Dec 2025 16:30:31 EST (-0500)
  Photons and reflections - huh? (Message 1 to 6 of 6)
Subject: Photons and reflections - huh?
Date: 13 Sep 2004 08:23:04
Message: <41459128$1@news.povray.org>
Im probably missing something, but:
I have a red reflecting sphere and a white light source and a white
plane and many photons. Should the light reflecting from the sphere
(showing on the plane) be red, not white? Now it is white. I'd think
that the red sphere should absorb all the other components but red. Or
should it? So, is my thinking flawed or is this a feature/bug in
POV-Ray's photon mapping? Most likely I'm missing something very obvious
here so please correct me.
See the next scene:
     location  <1, 3, -2>
     look_at   <0, 0,  0>  }
light_source{<5,10,-5> rgb 1}
global_settings {photons { count 100000}}
plane {y,0 pigment {rgb 1} }
cylinder{0,y,1
     pigment {rgb x}
     finish {reflection 1}
     photons {target reflection on}
Severi S
Subject: Re: Photons and reflections - huh?
Date: 13 Sep 2004 08:48:03
Message: <41459703@news.povray.org>
I'm not quiet sure, but there is the possibility of adding a "metallic"
keyword inside the reflection-brackets. I guess that would take care of
photons being reflected with the correct color. You might want to look it up
in the Docs for further insight.
Tim
"Tim Nikias v2.0"
"Severi Salminen" <sev### [at] NOT_THISsibafi> schrieb im Newsbeitrag
news:41459128$1@news.povray.org...
Date: 13 Sep 2004 08:56:38
Message: <41459906$1@news.povray.org>
"Metallic" didn't work as it only affects specular highlights. But
thanks anyway!
Severi
Date: 13 Sep 2004 09:12:12
Message: <41459cac$1@news.povray.org>
>      pigment {rgb x}
Your sphere is red but reflects white light. If you want it to reflect red
light, use reflection <1,0,0>.
Or you can use finish {reflection {1 metallic}} (since "metallic" is inside
the "reflection" block, it will affect the reflection and not the specular
highlights).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 13 Sep 2004 09:20:51
Message: <41459eb3@news.povray.org>
> highlights).
Oh, now I understand and that did it! Never knew there is a reflection
block... :)
Severi
Date: 13 Sep 2004 09:21:30
Message: <41459eda$1@news.povray.org>
> thanks anyway!
And if I specify it in reflection block it does work. So thank you
again, anyway :)
Severi
