I'm working on a macro, and I get the idea that:
#declare SphereA = sphere{<0,0,0>,5 pigment{Green}}
#declare Count = 0;
union{
#while (Count<5)
object{SphereA translate x*2*Count}
#declare Count = Count + 1;
uses a lot more memory then:
union{
sphere{<0,0,0>,5 pigment{Green} translate x*2}
sphere{<0,0,0>,5 pigment{Green} translate x*4}
sphere{<0,0,0>,5 pigment{Green} translate x*6}
sphere{<0,0,0>,5 pigment{Green} translate x*8}
sphere{<0,0,0>,5 pigment{Green} translate x*10}
Can somebody tell me this is true? I find this strange for some reason.
I found exaltly the same memory usage.
ZeSly
http://perso.wanadoo.fr/zesly/
"emkaah" <emkaah@yahoodotcom> a écrit dans le message de
news:412fec1d@news.povray.org...
> #declare Count = 0;
> union{
> #while (Count<5)
> #end
> union{
> #declare Count = 0;
> union{
> #while (Count<5)
> #end
> union{
The spheres in the union all use the same texture. The separately-
declared spheres all use separate textures (since you gave them
separate ones).
So, if you're going to texture a bunch of things the same way, see if
they can go into a union together, and give the union the texture. This
works very well if the texture is not patterened.
John
Thanks, but that was not the point I am trying to make. But to clear
things up I refrase the question;
#declare SphereA = sphere{<0,0,0>,5}
#declare Count = 0;
union{
#while (Count<5)
pigment{Green}
union{
sphere{<0,0,0>,5 translate x*2}
sphere{<0,0,0>,5 translate x*4}
sphere{<0,0,0>,5 translate x*6}
sphere{<0,0,0>,5 translate x*8}
sphere{<0,0,0>,5 translate x*10}
pigment{Green}
I solve this problem by writing it to a .inc file with the #write
function. I just didn't expect a big difference in memory usage with the
two methods.
>> #declare Count = 0;
>> union{
>> #while (Count<5)
>> #end
>> union{
> separate ones).
> Regards,
> John
emkaah nous apporta ses lumieres ainsi en ce 28-08-2004 15:07... :
> #declare Count = 0;
> union{
> #while (Count<5)
> #end
> pigment{Green}
> union{
> pigment{Green}
> the two methods.
They should use about the same amount of memory. Case 1 use a little
memory for the variable, case 2 use some more memory for the source. If
you increase the count to 500, then case 2 will use more memory: the 500
individualy defined spheres source code. The alocated memory during
parse will be the same, to one variable.
