Hi guys
Megapov 0.7 (I heard) had $ instead of #declare...
What is the reason why this wasn't implemented in official Pov 3.1 or 3.5?
Seems like a very nice feature to just go $variablename instead of #declare
all over in a .pov file. Quicker to type, easier to read, and so on.
Any team guys? Christoph?
Stefan Viljoen
Software Support Technician
Polar Design Solutions
Stefan Viljoen <rylan@ wrote:
> Hi guys
It leads to awfully obfuscated code. When designing a new language the
idea to leave away the #declare (or whatever else) completely is
reasonable. But if it is required replacing it with a single character
is not a good idea. With the same arguments you could replace every
other keyword with the shortest unique abbreviation - but no one could
read the code any more then.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
chr### [at] gmx de news:cfjc1l$vh2$1@chho.imagico.de
Btw, how about adding some shorten forms for long and often used keywords,
it could spedd up typing and comforable level of hand-typing .pov code,
like
light { y*10 rgb 1 }
diff {
box { -5, +5 }
sphere { 0 10 }
text {
pig { bozo cmap{0:<1,0,0> .5:<1,1,0> 1:1} }
norm{ bozo .5 }
fin { refl .5 phong 0.5,70 spec 0.1,0.06 }
Aliasing keyword is probably easy, another format of for example color_map
perhaps not so much.
Just an idea.
http://www.raf256.com/3d/
Computer Graphics
> like
Better yet, why not have the ability to make new #aliases for keywords.
Something like this:
#alias sphere=sph;
sph{ <0,0,0>, 10 pigment{White} }
-Sam
Rafal 'Raf256' Maj nous apporta ses lumieres ainsi en ce 13/08/2004
18:17... :
>like
>diff {
> box { -5, +5 }
> sphere { 0 10 }
> text {
> norm{ bozo .5 }
>Just an idea.
You can create a shorthand.inc include that define those abreviations as
equivalant to whatever keyword you want. You even can translate every
keyword to another language if you feel like it. If you then publish
your scene, don't forget to also publish the include file(s).
aze### [at] qwerty gov news:411d49c0$1@news.povray.org
Uhm? How exacly does it work? Sounds very interesting... something simmilar
to what Samuel was talking about?
Computer Graphics
19:48... :
Something like:
#declare sph=sphere; //Abreviate sphere to sph
#declare boite=box; //Translate box to boite (french)
Cool idea!
- Nicolas Alvarez
nicoalvar0 [at] hotmail [dot] com
"Samuel Benge" <stb### [at] hotmail com> escribió en el mensaje
news:411### [at] hotmail com...
keywords,
> > like
> #alias sphere=sph;
> -Sam
The idea of using #alias is better so that you don't mix #declares with
abbreviations.
- Nicolas Alvarez
"Alain" <aze### [at] qwerty gov> escribió en el mensaje
news:411d60c9$1@news.povray.org...
> 19:48... :
as
simmilar
> Something like:
> Alain
Alain wrote:
> Something like:
> Alain
Well, that's good to know!
-Sam
Erm, this doesn't work. Were you saying it does or suggesting it as a
feature?
- Slime
[ http://www.slimeland.com/ ]
"Slime" <fak### [at] email address> wrote in message
news:411dab30@news.povray.org...
> feature?
You're quite right. I tried it, and to alias it, you'd have to write:
#macro sph() sphere #end
sph() { <sphere and texture options> }
And the parentheses would have to be included with every invocation, adding
two more characters and obfuscation to otherwise straight code. It would
hardly be a worthwhile "abbreviation"
Brian :-)
NotForSpam@AskIfUWant news:411dcc08@news.povray.org
> adding two more characters and obfuscation to otherwise straight code.
> It would hardly be a worthwhile "abbreviation"
so we just need an #macro that can be called without "()"... I think that
#alias sph sphere
is a good idea. Perhaps it is not hard to implement?
Computer Graphics
"Samuel Benge" <stb### [at] hotmail com> wrote in message
keywords,
> > like
> #alias sphere=sph;
> -Sam
Hello all,
Some cautionary words.
Aliasing sounds really beguiling, because being IT/Comp/Sci/Tech types,
we're all lazy when it comes to typing and repetition, and we tend to like
using the shortest sequence of keystrokes to create our code. :-)
But on reflection (argh a RT pun), I believe it could unleash a bad genie on
the PoV-Ray community. The genie's curse will be reduced legibility and
portability of the SDL.
Human nature being what it is, what'll happen is that the single PoV-Ray
language we have now will be replaced by a multitude of personal dialects,
as people make up whatever words they personally enjoy. Instead of
"sphere", some will use "sph"; or "sp"; and there will be those who
particularly enjoy terse and dense code, who will condense it to a mere "s".
Authors from non-English origins might customise the SDL for their own
convenience, and use, eg., "esfera" instead!
This is perfectly fine if it is confined to one's own bedroom or study, but
there's an intensely active and diverse community around PoV-Ray and, let's
face it, this code will be shared on the Internet!
When reading someone else's aliased code, to ensure you understand their
typography, you must first seek and refer to their dictionary before you can
to understand the SDL body -eg. When this author writes "sp" on line 145 of
"myscene.pov" or "includefile3.inc", does it mean a "sphere" or a "spline"
or a locally-declared object type?
Also, consider portability: Incorporating aliased segments of another
author's code into your work, which is either not aliased or uses different
conventions, will no longer be a simple drop-in operation -- it will be much
harder to port.
Imagine using code from three sources, created with three different
conventions. What will you have to do to get it to work in your designs?
Especially if their "dictionary" is tucked away in a minor include file
somewhere, or it's spread across multiple files of hundreds of lines. If
one of your sources aliased "sphere" with "sp" while another had aliased
"spline" with "sp", and you are trying to merge the two into a new scene or
into your whole code library, you have a real mess to sort out!!!
The end effect: I think there are many people who would discard such code
rather then face the extra time and frustration of translating it. Great
ideas could be discarded or not even looked at, because the author used
idiosyncratic language. The free community exchange of ideas that happens
now would probably be reduced if aliasing were common, and I think that
would be a great pity if it happened.
Alternately, if you had aliased code and wanted to offer your creation into
the public community, you might have to convert it bact to standard syntax
first, nullifying any gains you originally got from it, either in time-saved
or visuals.
My sense of it is that the disadvantages eventually outweigh the advantages.
$0.02
Cheers,
Brian
"Rafal 'Raf256' Maj" <spa### [at] raf256 com> wrote in message
news:Xns95456D5662A7raf256com@203.29.75.35...
> #alias sph sphere
Whilst promoting the case for aliasing, please do consider *what and how
much*, really, is the material gain to be gotten by implementing it - eg.
typing "sph" instead of "sphere"? Is "sphere" so inconvenient for an able
person to write, or such a major percentage of your entire SDL file? Most
people I know who use computers a lot, and that includes programmers, are
usually very fast typists already.
I did a little experiment just now, and I succeded in typing "sphere " (with
trailing space) 19 times in 30 seconds, and that was WITH correcting several
mistakes. But I spend a lot of "think time" when I am not actually typing
anything. So aliasing will not save me much time!
Also, though this doesn't help those on open-source ports of PoV-Ray, the
Windows users of PoV-Ray have that lovely in-built editor. All one need do
on WinPov is type "sph" then press Tab, and you have your complete word.
Try it with "pig" as well!
Meanwhile, I put some thoughts about aliasing in reply to Sam's message.
The implications are not immediately obvious behind the immediate personal
convenience, which is usually as far as people look when they decide on
something. But potentially major consequential disadvantages do lie behind
aliasing, which I think should be considered carefully before the community
decides we really want this convenience feature. If a solution is presented
that avoids the disadvantages, then good.
Cheers,
Brian
> mistakes.
I did 30 "sphere"s/30secs after a few practice runs. So, what is the
POV-Ray community unofficial record? Only correctly typed words count.
I also think that there is little to gain by using aliasing. Also, how
many people knows how to use TAB (at least in windows version) to use
autocomplete feature? It also speeds up writing.
Severi
NotForSpam@AskIfUWant news:411de774@news.povray.org
So I after all sugest _one_, oficial, additional short-alias set.
It can be used in addition to normal keywords so both forms will be valid -
short and full.
It will ne used only if it is needed for given keyword.
The aliases I sugest like:
1) alias
cylinder cylind
superellipsoid superel
isosurface isosurf
light_source light
area_light areal
adaptive adapt
reflection refl
2) alias for several keywors used usually
oriented circular bulll // [light]bull light
oriented circular parallel sunl // sun light
3) alias + another syntax, or only alias
specular x roughness y spec x,y
phong x,phong_size y phong2 x,y // "phong2" because "phong" is reserved
rotate A scale B translate C position A,B,C // this is most usual order
// of transorms - rotate and scale, the
// translate somewhere in scene
color_map {[0 rgb <1,0,0>][1 rgb <1,0,1>]} // replece this one with
cmap{[0 <1,0,0>][1 <1,0,1>} // this one
cmap{0:<1,0,0> 1:<1,0,1>} // ..or this one
4) perhaps this aliases (or maybe not)
pigment pigm
finish fin
normal norm
sugestions?
Computer Graphics
Shorter words are not easier to read, only slightly faster to type. But you
can already save that typing in POV-Ray (for Windows anyway).
Try to type the following (where *TAB* means pressing TAB):
light*TAB**TAB*
dif*TAB*
pig*TAB*
norm*TAB*
fini*TAB*
spec*TAB*
refl*TAB*
Rune
rune|vision: http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
> light*TAB**TAB*
> dif*TAB*
> pig*TAB*
> norm*TAB*
> fini*TAB*
> spec*TAB*
> refl*TAB*
Thank you very much for this tip, I realy didn't know it!
#declare
I agree with you, on both points (typing and reading). I suggest
implementing only this feature, besides giving the TAB-trick a more
prominent place in the FAQ/manual.
Greetings,
JWV
"Rune" <run### [at] runevision com> wrote in message
news:411e20a7$1@news.povray.org...
you
> light*TAB**TAB*
> dif*TAB*
> pig*TAB*
> norm*TAB*
> fini*TAB*
> spec*TAB*
> refl*TAB*
> Rune
> 3D images and anims, include files, tutorials and more:
run### [at] runevision com news:411e20a7$1@news.povray.org
> light*TAB**TAB*
Oh, I thought that You where talking about this ctlr+space thingy, this
definetely should be in FAQ, help and Tip of the day.
But I still suggest shortucts for most long expressions, for example
reflection -> refl
specular .5 roughness 0.01 -> spec .5, 0.01
etc... why not?
Computer Graphics
Brian Elliott wrote:
<snip>
<clip>
I've been using the Tab shortcut for quite sometime now. I can't
remember if I found it accidentally or not... it doesn't matter. What
matters is that it WORKS. I save a lot of time using it.
The more I thought about my 'aliasing' idea last night, the closer to
your opinion I found myself..... and then there was your reply. We don't
need to confuse the code and make it unreadable. It's not so hard to
type out the keywords, especially if we have the Tab feature built into
the editor. Perhaps those working on other operating systems can push to
have this functionality placed into their editor?
-Sam
Dunno about povmode for emacs etc., but if you're using QtPOVEditor
(qtpoveditor.sf.net), you have that auto-complete-thingy for both
keywords and custom identifiers.
I normally don't like full-quotes, but I got the impression that if
everyone anticipating in this discussion right now would reread
Christoph's post, there would not be much to discuss anymore:
"It leads to awfully obfuscated code. [...] With the same arguments you
could replace every other keyword with the shortest unique abbreviation
- but no one could read the code any more then."
So, think again - how much time do you really spend with typing only
when you're creating a POV scene? IMHO POV SDL allows some pretty
cryptic stuff already (and yes, I'm using that, too ;) so there's no
need to make it even more complicated.
While talking about SDL changes, the only thing that one would IMHO
benefit from is the #set keyword from former MegaPOV, combined with an
error/warning when trying to re-declare already declared identifiers.
Florian (who would like to have references in POV-SDL, too ;)
>>light*TAB**TAB*
> reflection -> refl
> etc... why not?
Because the full English words are standard and self-documenting
Because it adds unnecessary complication to every aspect of the endeavour
Because it would in no way result in better pictures
Because it is a bloat-feature based in a bloat mentality
In article <411e6a9c$1@news.povray.org> , Jim Charter <jrc### [at] msn com>
wrote:
>> etc... why not?
Very well said!
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
jrc### [at] msn com news:411e6a9c$1@news.povray.org
cone { begin_point x*4 end_point 5*x radius 10 }
this is self-documented
I dont know what endeavour is, but as for implementation the basic aliases
are very easy to implement
More comfortable work = more time to concentrate on picture itself.
Computer Graphics
spa### [at] raf256 com news:Xns9545ED4602E3Craf256com@203.29.75.35
but anyway I do not insist so hard about aliases, since Tab future is
greate, if only it would be implemented also in linux-editors...
Computer Graphics
agreed.
"Jim Charter" <jrc### [at] msn com> wrote in message
news:411e6a9c$1@news.povray.org...
> >>light*TAB**TAB*
> > reflection -> refl
> > etc... why not?
this is only true for short term work. though I'm not a POV-Ray expert, my
experience with other languages in which shorthand syntax exists makes me
say that it's only "comfortable work" for 2 or 3 lines worth of code in
every 500. The code with dense shorthand easily becomes cluttered and
impossible to read.
Giving an example of how bad short hand can be in Mathematica code (and I
tried using this sort of code for serious programming -- to give up
reasonably soon afterwards):
Compare:
f[x_]=x^2;
list=Map[f,{1,2,3,4}];
Apply[Plus,list];
list
With:
Plus@@((#^2)&/@{1,2,3,4})
they both get the list {1, 2, 3, 4}, square all entries, and sum all the
entries. Which code segment do you think you'd understand for what it is 2
months after you'd written it? I had to rtfm to get the second one right to
make this point (though I wrote fluently like it when I used it), whereas
the first one came naturally.
it's a non-feature. It's not necessary, hardly useful, and it makes (as
illustrated) for more hard than good.
So it's not so good idea. I AM lazy but you are right.
- Nicolas Alvarez
"Brian Elliott" <NotForSpam@AskIfUWant> escribió en el mensaje
news:411de774@news.povray.org...
> keywords,
code,
> > > like
> > #alias sphere=sph;
> > -Sam
> Hello all,
like
on
dialects,
"s".
but
let's
can
of
"spline"
different
much
> harder to port.
or
code
happens
into
syntax
time-saved
> or visuals.
advantages.
> $0.02
> Cheers,
> Brian
I'm working on a typing test (in HTML and Javascript). It's a modification
of one found in http://javascriptsource.com.
If you are interested, mail me.
- Nicolas Alvarez
"Severi Salminen" <sev### [at] NOT_THISsiba fi> escribió en el mensaje
news:411df175$1@news.povray.org...
(with
several
> > mistakes.
> Severi
I agree that what a language needs is legibility. From my point of view, C++
lost that long time ago ... but this is a different history.
Talking about legibility, I would like to know why the directives sitll need
the simbol #. I know that they are interpreted during parsing time and so on
but I think that many of our scenes have more lines beginning with # than
the opposite. Belive me, with some keyboards, it is a difficult symbol.
Why not writing:
declare i=0;
while (i<10)
sphere {(0,0,i) i/2}
i=i+1;
end
There should be many problems for the interpreter?
Thx,
Groucho
"Doppelganger" <ped### [at] netcabo pt> wrote in message
news:411ed9f8$1@news.povray.org...
> impossible to read.
> Compare:
> f[x_]=x^2;
> Apply[Plus,list];
> list
> With:
to
news:Xns954536876C74raf256com@203.29.75.35...
> like
> diff {
> box { -5, +5 }
> sphere { 0 10 }
> text {
> norm{ bozo .5 }
> Just an idea.
How about using a text editor that supports word completion. something like
what the tab key does in bash or a myriad of other programs. It' smuch
simpler and doesn't subject other people to your whims of what a language
should be.
-r
news:Xns9545EDC67E010raf256com@203.29.75.35...
> Rafal Maj 'Raf256', home page - http://www.raf256.com/me/
> Computer Graphics
emacs has symbol completion. one just needs to tell it what the symbols are
for the major mode you are in. i havn't even noticed if it works by default
in povmode for emacs. povmode definately has all the keywords needed,
because it performs syntax highlighting properly.
> -Sam
Vim and Emacs have the ability to have this functionality in general. What
other editors are there? ;)
What about the new qtpoveditor? does it have symbol completion?
"Ross" <rli### [at] everestkc net> wrote in message
news:4120cc25@news.povray.org...
> > -Sam
According to Florian, yes it does also!
Cheers,
Brian
Some suggestions:
-file starts with a #development [code]
-the [code] is in an ini file in pov-ray's directory, along with custom code
prefs (sphere=sp,...) (you may have several [codes])
-> on the computer with the [code], you'd see sp{0,1}, but on a computer
without the proper [code], or without the #development state, or in a text
editor, you'd see standard code.
So the translation would be done in pov.
A better interface!
1- customisable button bar (you would add links to files from insert menu:
add something in one click)
2- at least, a return on screen option (or have i missed it?)
3- an enhanced insert menu interface to the left of the screen (i wonder if
many on us use that part of the screen)
-see the right menu in 3ds/gmax/hamapatch? Like that, but to expand the
menus, you may use shortcut keys.
Example:
(initial menu, A,B=things like "light", "shape":)
[A - alt+a]
[B - alt+b]
(do alt+a:)
[A - alt+a]
[sphere - ctrl+shift+s]
[cylinder - ...]
[B - alt+b]
So if you can customise the shortcuts, the text editing will be MUCH faster,
and not so hard to use since you don't have to remember the shortcut keys.
Faster? you won't use the mouse anymore, won't have to use the arrows to
navigate in the insert menu
selsek
selsek nous apporta ses lumieres ainsi en ce 20/08/2004 20:11... :
>Some suggestions:
>A better interface!
>Example:
>[A - alt+a]
>[B - alt+b]
>(do alt+a:)
>[A - alt+a]
> [cylinder - ...]
>[B - alt+b]
>selsek
OK. You propose a _display_ user defined substitution of selected
keywords. That way, you can use whatever personal shorthand you want,
while still outputing normal code. The support for that will make the
editor biger and more prone to bugs. Maybe somebody can make a patched
version to test it...
