POV-Ray : Newsgroups : povray.general : BENCHMARK: Itanium, Opteron, Xeon, Athlon (GCC, ICC) Server Time
21 Oct 2026 10:46:20 EDT (-0400)
  BENCHMARK: Itanium, Opteron, Xeon, Athlon (GCC, ICC) (Message 1 to 4 of 4)
Subject: BENCHMARK: Itanium, Opteron, Xeon, Athlon (GCC, ICC)
Date: 10 Aug 2004 06:55:56
Message: <4118a9bc$1@news.povray.org>
Hi!
   I have had the chance to compile and run POV3.6 on various platforms
  using Gnu C/C++ Compiler and Intel C/C++ Compiler.
  I have run tests on these Linux-Machines (further specs see below):
  * INTEL Itanium, 0.8 GHz,
  * AMD Athlon TB, 0.8 GHz,
  * AMD Opteron 244, 1.8 GHz,
  * INTEL Pentium IV Xeon, 2.4 GHz
  Of course, it's not particularly fair to compare a 1.8GHz Opteron machine
  with a 0.8 GHz Athlon --keep that in mind, please!
Benchmark for var. archs and compilers:
using POV-Rays official benchmark.pov script
with suggested options -w384 -h384 +a0.3 +v -d -f -x
numbers = processor time [seconds]
LOWER NUMBERS = BETTER
                ICC8.0   GCC3.x.x
ITANIUM (64)   10880     8715
OPTERON (64)     n.a.    1580
XEON    (32)    2458     3757
ATHLON  (32)     n.a.    5012
(64=64bit arch, 32=32bit arch)
* AMD Opteron 244, 1.8 GHz, 4 GByte RAM
   (dual processor boards in cluster)
   RedHat Linux
* INTEL Pentium IV Xeon, 2.4 GHz, 2 GByte RAM
   RedHat Linux
* INTEL Itanium, 0.8 GHz, 2 GByte Ram
   (dual processor board)
   Debian Linux
* AMD Athlon TB, 0.8 GHz, 256 kB Ram
   (single processor board)
   Debian Linux
  Obviously, you won't make use of an Itanium machine
because of it's speed ;-) I was wondering why the Intel Compiler
produced a code that performed ~20% slower than the one produced
by GCC, so I randomly chose some of POVs example-scene files for
render with both codes, and here is what I got:
SCRIPT               ICC8.0     GCC3.x
box.pov                5.87       5.80
mesh2.pov             45.14      40.06
glassthing.pov       299.09     320.25
parallel_lights.pov   19.37      21.69
circular.pov         143.74     175.14
shadows.pov           67.86      89.82
fog_ft.pov            10.30       9.21
atten2.pov            30.70      34.06
caustic2.pov          22.60      19.50
skysph2.pov           32.85      21.26
radiosity2.pov       187.19     207.37
cornell.pov           71.10      81.8
shear.pov              0.03       0.03
perspective.pov        0.02       0.03
panoramic.pov          0.03       0.03
focalblur.pov          0.03       0.03
abyss.pov            486.54     536.31
gaussianblob.pov     213.71     230.85
MEAN                  91.00      99.70
  So here is what I expected. Overall-performance codes produced by
the Intel-Compiler is ~10% better than GCC-Codes. It seems, that calculation
of simple objects with no further options like fog etc perform better with
GCC-POV Code. However, scripts like 'circular.pov', 'abyss.pov' or
'shadows.pov' show drastical improovement with ICC-POV-Code.
  I run the same scripts on the Xeon Machine and noticed an overall
improovement of approx. 12% using ICC (ICC: 28.9s, GCC: 33.0s).
  Comments and suggestions welcome...
Sincerely
S. Tayefeh
Subject: Re: BENCHMARK: Itanium, Opteron, Xeon, Athlon (GCC, ICC)
Date: 10 Aug 2004 07:10:02
Message: <cfaac1$crb$1@chho.imagico.de>
S Tayefeh wrote:
>  Hi!
Please use the benchmark.ini coming with POV-Ray.  This makes sure the
results are comparable with those made by others, using the above
options does not!
>                ICC8.0   GCC3.x.x
> XEON    (32)    2458     3757
>   RedHat Linux
>   RedHat Linux
>   Debian Linux
>   Debian Linux
Without telling about the compiler options used this is pretty useless -
you did not even mention if the Opteron/Itanium tests use a 64bit
compile or not.  Also 'GCC3.x.x' is a somewhat incomplete information.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 10 Aug 2004 07:55:56
Message: <4118b7cc$1@news.povray.org>
> options does not!
  I'm afraid I didn't notice that .ini. Next time, I'll do!
  You're right. This was supposed to be a quick test, however, here are
the most important spec. for all but Athlon (coming later):
*** ITANIUM:
 > uname -a
 > Linux xxxxx 2.4.26-1-itanium-smp #1 SMP Tue Jun 8 20:39:36 MDT 2004
ia64 GNU/Linux
* GCC: gcc (GCC) 3.3.4 (Debian 1:3.3.4-6sarge1) (64-Bit, I suppose)
* ICC: icc 8.0 (64-Bit)
GCC-OPTIONS:
CFLAGS =
CPP = gcc -E
CPPFLAGS =  -I/usr/X11R6/include
CXXCPP = g++ -E
CXXFLAGS =  -pipe -Wno-multichar -O3
LDFLAGS =  -L/usr/X11R6/lib
LIBS = -ltiff -ljpeg -lpng12 -lz -lXpm   -lSM -lICE -lX11 -lm
X_CFLAGS =  -I/usr/X11R6/include
X_LIBS =  -L/usr/X11R6/lib
X_PRE_LIBS =  -lSM -lICE
ICC-options:
CFLAGS =  -g
CPP = /<path>/icc -E
CXX = /<path>/icc
CXXCPP = /<path>/icc -E
CXXDEPMODE = depmode=gcc3
CXXFLAGS =  -O3
**** XEON:
 > uname -a
 > Linux xxxxx 2.4.24 #2 SMP Mon Jan 12 13:39:44 CET 2004 i686 unknown
* gcc 2.96 (32-Bit)
* icc 7.1 (32-Bit)
GCC-OPTIONS:
CFLAGS =  -pipe -O3 -msse -malign-double -minline-all-stringops
CPP = gcc -E
CXX = g++
CXXCPP = g++ -E
CXXFLAGS =  -pipe -Wno-multichar -O3 -msse -march=i686 -malign-double
LIBS = -ljpeg  -lXpm -lSM -lICE -lX11 -lm
X_EXTRA_LIBS =
ICC-OPTIONS:
CFLAGS =  -O3 -ip -march=pentium4 -mcpu=pentium4
CPP = icc -E
CXX = icc
CXXCPP = icc -E
CXXDEPMODE = depmode=icc
CXXFLAGS =  -O3 -ip -march=pentium4 -mcpu=pentium4
**** OPTERON:
 > uname -a
 > Linux xxxxx 2.4.21-15.ELsmp #1 SMP Thu Apr 22 00:09:01 EDT 2004
x86_64 x86_64 x86_64 GNU/Linux
* gcc (GCC) 3.2.3 20030502 (Red Hat Linux 3.2.3-34) (64-Bit)
GCC-Options:
CFLAGS =  -pipe -O3 -msse -mfpmath=sse -msse2 -march=k8 -mcpu=k8
CPP = gcc -E
CXX = g++
CXXCPP = g++ -E
CXXFLAGS =  -pipe -Wno-multichar -O3 -msse -mfpmath=sse -msse2 -march=k8
-mcpu=k8 -minline-all-stringops
LDFLAGS =  -L/usr/X11R6/lib64
X_LIBS =  -L/usr/X11R6/lib64
ST
Date: 10 Aug 2004 08:30:02
Message: <cfaevs$djq$1@chho.imagico.de>
>> - you did not even mention if the Opteron/Itanium tests use a 64bit
Thanks.  The Xeon test is not very representative when not using
-march=pentium4 (which gcc 2.96 probably does not support).  Can't say
much about the Itanium and ICC compiles.
For a really useful comparison you should use the same compiler version
  and same options except the -march and other processor specific flags
on all machines.
