POV-Ray : Newsgroups : povray.general : HF's thickness in POV Server Time
21 Oct 2026 11:42:38 EDT (-0400)
  HF's thickness in POV (Message 1 to 8 of 8)
Subject: HF's thickness in POV
Date: 6 Aug 2004 18:04:48
Message: <41140080$1@news.povray.org>
Hi All,
Does anyone know how to get the "boxed-look" on HF's in povray?
My HF's are ultra thin...and I like to add some thickness to them. I
remember that with the DOS versions I always got that boxed look, but with
the win version I'm not able to get it right.
Thanks
CJ
Amsterdam
Subject: Re: HF's thickness in POV
Date: 6 Aug 2004 19:22:55
Message: <411412cf$1@news.povray.org>
"Cees" <cvd### [at] xs4allnl> wrote in message
news:41140080$1@news.povray.org...
Hmmmmm. Either my previous answer wasn't what you wanted to do, not working
right for you, or you somehow missed reading it? I noticed someone else (oh,
was Bonsai in p.b.s-f.) also answered similar as me. Anyway, here is that
again:
"You'll need to intersect or difference a box and the HF since they
are only a one unit square with an implied depth."
intersection {
    height_field {...} // could texture this here
    box {0,1} // could texture this here
// or both here
As long as you don't change the scale or move the HF before this is done you
should get a box shape for the lower portion. If you were to difference the
two, instead, you would need to add 'inverse' to the box for it to retain
the HF area.
I don't remember how earlier versions dealt with the HF shape. If this isn't
going right for you please ask for more help.
Bob H.
Date: 7 Aug 2004 05:13:26
Message: <41149d36$1@news.povray.org>
Thanks, will try that today!
Didn't get the previous answers, I also can't see my previous message. I've
just installed all of these groups in outlook..something went wrong with
those first messages I guess.
Thanks for reposting your answer!
Cees
"Hughes, B." <bob### [at] charternet> schreef in bericht
news:411412cf$1@news.povray.org...
with
working
(oh,
> again:
> intersection {
> // or both here
you
the
> the HF area.
isn't
> Bob H.
Date: 7 Aug 2004 05:31:17
Message: <4114a165$1@news.povray.org>
news:41149d36$1@news.povray.org...
I've
Be sure to look in Outlook's menu Tools|Options... then Maintenance. It will
remove messages unless you uncheck the two "Delete...messages" boxes. Okay
to "compact" them. Might be a good idea to see if 'mark all read' is
unchecked too, which you can find in the Read section there.
Bob H.
Date: 7 Aug 2004 05:52:17
Message: <4114a651$1@news.povray.org>
Thanks!
news:4114a165$1@news.povray.org...
> I've
will
> Bob H.
Date: 7 Aug 2004 22:40:41
Message: <411592a9$1@news.povray.org>
I've
Hello,
The reason you couldn't find your other messages is that somehow you
accidentally posted them as replies in other threads.  In this forum,
there's one in Zarniwoop's thread about mesh2 and CSG strange behaviour, and
another one is in povray.binaries.scene-files, in Zeger Knaepen's thread
about fast and easy clouds.  Mystery solved!
Cheers,
  Brian
Date: 7 Aug 2004 22:58:42
Message: <411596e2@news.povray.org>
and
Yeah, and I thought there was a reaction to my clouds :'(
cu!
ZK AKA SaD
http://www.povplace.be.tf
"The ships hang in the air in exactly the same way that bricks don't."
Date: 8 Aug 2004 04:01:40
Message: <4115dde4$1@news.povray.org>
Grin, mystery solved, thanks for solving it!
I'm just so accustomed to hit the reply when answering a message.
take care,
Cees.
"Brian Elliott" <NotForSpam@AskIfUWant> schreef in bericht
news:411592a9$1@news.povray.org...
> Hello,
and
> Cheers,
>   Brian
