Subject: POV-Ray for Windows 64-bit edition now available as a release candidate
Date: 12 Jul 2004 01:58:44
Message: <40f22894@news.povray.org>
Subject says it all. See http://www.povray.org/beta/ for the details.
-- Chris
Subject: Re: POV-Ray for Windows 64-bit edition now available as a release candidate
Date: 12 Jul 2004 07:11:22
Message: <40f271da$1@news.povray.org>
Feel like I'm left behind in the dust with my current, and what I consider
to still be new, PC; having only the Intel Pentium IV with Hyperthreading
and my WinXP being only 32bit, too, I keep thinking I'm always making bad
computer buys.
I'm guessing this new and improved POV-Ray will be okay on a 64bit Intel
processor like the Nocona, or whatever it will be called...? But why bother,
since AMD seems to be staying ahead on that processing power stuff.
Although, having checked up on pricing they don't seem to be very different
in cost and Intel is boasting a lot of improvements.
Regardless, I'm bound to be a few steps behind the top-end system users out
there no matter what I try to do. Heh-heh-heh.
Bob H.
Date: 12 Jul 2004 07:40:01
Message: <cctt65$54q$1@chho.imagico.de>
> computer buys.
This 64bit version is mainly developed for the AMD 64bit processors
(Athlon 64/Opteron). Of course it should also run on whatever Intel
develops as compatible to the AMD64 extensions. It won't run on Intel's
Itanium systems but that's a different league anyway.
Since 64bit Windows versions are still in beta the whole 'Windows
64-bit' concept is not that important for the broad market yet, the
number of people running POV-Ray on 64bit Unix systems (including AMD64)
is probably going to be higher than on Windows for quite some time. If
you want to buy a relatively cheap and reliable 64bit system for use
with POV-Ray, AMD with Linux/FreeBSD is probably the way to go at the
moment.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 12 Jul 2004 11:40:02
Message: <ccub40$92g$1@chho.imagico.de>
BTW there just has been an article on slashdot on a comparison of AMD64
systems on Linux/Windows:
http://slashdot.org/articles/04/07/12/117254.shtml
The tests include POV-Ray, but only with the 32bit version on Windows.
The quite different numbers with the different Linux distributions
indicate that they used the POV-Ray versions coming with the distributions:
http://anandtech.com/linux/showdoc.aspx?i=2114&p=4
The sense of this test is of course extremely questionable (what are
they actually trying to compare there?).
> Christoph
Exactly what they state they are testing: the readiness of certain operating
systems for 64bitness "out of the box". That is, no recompiling, no
additional software to make things work. You can, of course get much
better performance under Linux by recompiling software to suit your tastes,
but that wasn't the point of the article.
....Chambers
Date: 12 Jul 2004 23:48:03
Message: <40f35b73$1@news.povray.org>
What kind of performance changes/gains can we expect from the 64-bit
release? Anyone running benchmarks yet?
Skip
Date: 13 Jul 2004 03:15:01
Message: <cd020u$2ik$1@chho.imagico.de>
>>Christoph
No, for that they would not need any benchmark results because they have
nothing to do with the 'readiness'. The only 'readiness' fact that you
can indirectly deduce from the results is the availability of 64bit
software on the different systems.
What you can conclude from the benchmark results they gave is: how the
official 32bit version on 64bit Windows compares to the 32bit version on
two specific 64bit Linux distributions - basing an OS/hardware decision
on that would be just insane. And you can see which of the two tested
Linux distributions ships a better optimized 64bit POV-Ray which also
does not have much to do with which of them is more 'ready'.
Date: 13 Jul 2004 04:21:12
Message: <40f39b77@news.povray.org>
The AMD64 processor has additional features (eg. additional registers)
only available in 64-bit mode which the compiler can use to generate
faster code than when compiling to 32 bits. Thus it is expected that
the 64-bit version will run faster in an AMD64 than the 32-bit version
(how much faster depends on the compiler used).
If you have an AMD64, it just doesn't make sense to use the 32-bit
version of POV-Ray because the 64-bit version should be faster.
(And by the way, the 64-bit version being faster does not mean that
64-bitness in itself brings magically some speed benefit. The speedup
is not related to the 64-bitness of the processor, but to the fact that
in 64-bit mode it has additional features not available in 32-bit mode.)
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Date: 13 Jul 2004 11:44:23
Message: <40f40357@news.povray.org>
"Warp" <war### [at] tag povray org> wrote in message news:40f39b77@news.povray.org...
Precisely. I saw a speedup of about 10%, and there'll be more to come as
the compiler I am using is still in beta.
Plus 64-bit mode also allows you to render insane scenes ;-). (I've rendered
one here which used 3.5 gigabytes of RAM).
-- Chris
Date: 13 Jul 2004 16:02:28
Message: <40f43fd4@news.povray.org>
Theoretically a 32-bit version could also do that, but it's very
possible that some OSs limit the maximum allocatable size to 2 GB.
(Well, if we go deeper into theory, AFAIK you can use up to 64 GB of
memory with a Pentium or newer 32-bit processor, but the application
would need to be specifically coded to do that. A standard C++ program
can't do it. Naturally the OS has to support that as well (unless the
program bypasses the OS, if it's possible).)
But I suppose that with a 64-bit binary the theoretical limits are
so immensely high that we don't need to worry about them in the next
several decades (hardware other than the CPU is and will be the limiting
factor for long time). Thus allocating 3.5 or 35 or even 350 gigabytes
of memory is not any problem in a 64-bit system (as long as the hardware
is up to those sizes)... :)
Date: 13 Jul 2004 17:01:30
Message: <40f44daa@news.povray.org>
Makes me wonder how they raytraced insane scenes in days of yore...
different computing paradigm, I suppose? '80s Cray vs. 2004 AMD/Intel
is more apples 'n' oranges than '80s Intel vs. 2004 AMD/Intel; the
'80s Cray is still 'more powerful' than today's consumer machines I
guess.
Yeah, where's my 100 gb sticks of RAM? :P
Tim Cook
Version: 3.12
Date: 22 Jul 2004 09:17:32
Message: <40FFC13F.D51EB4D8@gmx.de>
High!
What about the epsilon value? Will this version be able to do a
single-scene rendering of the whole Solar System with, let's say a space
station with detailed interior in the foreground at 1 unit = 1 meter?
(i.e. object sizes ranging from 0.0001 (100 µm) to 10.000.000.000.000 (10
billion km).
How deep will it be able to zoom into mandelbrot patterns?
And would a Linux portation of this code run with 2.6 kernel?
See you in Khyberspace!
Yadgar
Date: 22 Jul 2004 09:28:21
Message: <40ffc0f5@news.povray.org>
It hasn't changed as the floating-point precision remains the same.
the current official unix source release builds and runs OK on an AMD64
gentoo 2.6.3 system.
Date: 22 Jul 2004 09:57:09
Message: <40ffc7b5@news.povray.org>
> billion km).
A 64-bit CPU has 64-bit long integers and 64-bit pointers. That's about it.
The FPU has basically nothing to do with the CPU. It's practically its
own independent microprocessor. The bitness of the CPU has no effect
whatsoever on the FPU.
The 'double' type floating point numbers in practically all computers
has always been 64 bits long and this hasn't changed in any way.
The only advantage you will get from a 64-bit binary is that you will
be able to use scenes which use more than 4 gigabytes of memory. (With
the AMD64 processor there's also a slight speed advantage due to the
features the processor supports and which the compiler can use to
optimize the binary for speed.)
(Another theoretical advantage of a 64-bit system is that your scene
files can be larger than 4 gigabytes, as well as the result image,
although this is quite improbable in practice (a 4GB raw image would
have a resolution of about 43600x32700).)
> > computer buys.
> moment.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 06 Jul. 2004 _____.//^>_*_<^/.______
I have Windows XP and an AMD Athlon 64. But when I try to install it, it
says I have the wrong processor type. Do I have to "set" something yet or
what? And how do you install an *.msi file anyhow?!
:O)+<
Date: 2 Dec 2004 01:48:00
Message: <41aebaa0$1@news.povray.org>
"senji" <sen### [at] yahoo com> wrote in message
news:web.41ae6c5580b7b9baefbd978e0@news.povray.org...
consider
Hyperthreading
bad
> > > computer buys.
Intel
bother,
different
> > moment.
> > Christoph
First you need the *64-bit version* of Windows XP, called Windows XP
Professional x64, which you can download for free at:
https://microsoft.order-9.com/winxp64/product.asp?catalog%5Fname=MSTrialandEval&category%5Fname=winxp64&product%5Fid=winxp64&id=dl
The 64-bit version is currently a time-limited trial and hasn't been
released as a final version for purchase.
Once you're running Windows XP Pro x64, then you will be able to install the
64-bit version of POV-Ray for Windows. Installing a .msi should be as
simple as double-clicking on it - a .msi is a "Windows Installer" file.
Lance.
thezone - thezone.firewave.com.au
thehandle - www.thehandle.com
You need to create a dual boot system. You can download an evaluation
version of the 64 bit XP from M$. I'm sure you know that you should
install separate OS on different drives. My laptop has only one HD so
I had to partition it into 2.
Regards
