POV-Ray : Newsgroups : povray.general : Is there an alternative for jitter? Server Time
17 Jul 2025 10:12:10 EDT (-0400)
  Is there an alternative for jitter? (Message 1 to 4 of 4)
Subject: Is there an alternative for jitter?
Date: 7 Jul 2004 08:26:43
Message: <40ebec03@news.povray.org>
I want to use area-light in an animation, but I understand that jitter
should be avoided when animating, so I was wondering: is there a good
(not so random) alternative of using jitter in area-light to avoid
shadow bands? Too many lights in the grit makes rendering to slow.
Subject: Re: Is there an alternative for jitter?
Date: 7 Jul 2004 08:50:42
Message: <40ebf1a2$1@news.povray.org>
emkaah nous apporta ses lumieres ainsi en ce 07/07/2004 08:26... :
Not realy. Add adaptive <value> to your area_light, it can realy speedup
things. I never tried it but adding some turbulence to your light may
help if it's possible. Using spotlights instead of regular light, use
high light counts in close light and sparce ones in far away ones.
Date: 7 Jul 2004 13:09:33
Message: <40ec2e4d$1@news.povray.org>
I have tested it in combination with focal blur. And with good/high focal
blur settings, there will be no jittering. Even with adaptive 0. See
http://imp.3dhost.net/33.mpg (2,431,794 bytes) at the IMP website if you
want to see an example. Sources of this animation can be found at
http://www.imp.org/impfarm/jobs/33.zip.
Date: 7 Jul 2004 21:24:43
Message: <40eca25b@news.povray.org>
> things.
I've found that "adaptive 1" with an area light as large as 17x17 creates
very nice shadows without taking long to render - the 17x17 sampling is only
used in the soft shadowed areas.
 - Slime
 [ http://www.slimeland.com/ ]
