POV-Ray : Newsgroups : povray.general : blummin Media headache again! Server Time
21 Oct 2026 12:27:05 EDT (-0400)
  blummin Media headache again! (Message 1 to 20 of 20)
Subject: blummin Media headache again!
Date: 1 Jul 2004 10:25:44
Message: <40e41ee8$1@news.povray.org>
Help before I climb the bell tower and start shooting!
please :-)
I have a simple radiosity scene, a cylinder with ambient 1 encased in a much
bigger cylinder filled with cylindrical media.  For some reason I cant
fathom, I cant see the media.  If there some setting that needs to be turned
on for radiosity and media to interact
Subject: Re: blummin Media headache again!
Date: 1 Jul 2004 10:31:08
Message: <40e4202c$1@news.povray.org>
> please :-)
Make sure the container cylinder is hollow.
Media on should be in the radiosity block.
Try a constant density to rule out the cylindrical pattern as being  the
cause.
Date: 1 Jul 2004 10:44:02
Message: <opsagq4xzuefp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 09:31:08 -0500, Mike Raiford
<mra### [at] hotmailcom> did spake, saying:
>>  please :-)
>> a much
>> turned
> cause.
I thought media would only function with a light_source producing a ray to
sample along as stated in 6.8, AFAIK ambient, like emission, doesn't
produce light in this way even using radiosity.
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 1 Jul 2004 10:45:01
Message: <web.40e422ab5304920a620840b30@news.povray.org>
> please :-)
For the radiosity to affect media, you need "media on" in the radiosity
block in the global_settings.
The cylindrical pattern have a radius of one (1), you have to scale it to
the radius of your big cylinder. Set your media as scattering and adjust
it's density if it's to light or dense. Also, the big cylinder need to have
the hollow attribute or no media will ever show inside of it.
Date: 1 Jul 2004 10:51:40
Message: <40e424fc$1@news.povray.org>
> to  sample along as stated in 6.8, AFAIK ambient, like emission,
> doesn't  produce light in this way even using radiosity.
D'oh. To think, I just got done meddling with the same stuff and came to
the conclusion that media *does* need a real light.
Hmm, for some reason the mention of an ambient 1 object escaped that
tiny little pea up there in my skull ;)
Date: 1 Jul 2004 10:56:17
Message: <40e42611$1@news.povray.org>
Erm.. Ambient does produce light, but the light does no react with the
media. Media affects radiosity, radiosity does not affect media.
Date: 1 Jul 2004 11:11:09
Message: <40e4298d@news.povray.org>
> cause.
"media on"  is showing my media ,thank you very much, I'll put the rifle
away for now...
Date: 1 Jul 2004 11:14:25
Message: <opsagsjia4efp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 09:56:17 -0500, Mike Raiford
*in this way* :)
3.7.5: "POV-Ray uses the ambient keyword to determine how much light
coming from the ambient light source is reflected by a surface" and
6.7.3.1 "Computing real ambient light would take far too much time, so we
simulate ambient light by adding a small amount of white light to each
texture whether or not a light is actually shining on that texture."
So if you think about it what is the location of the ambient light source
and how do you trace a ray along it it through the media to sample along?
Gods I've been fiddling with media to long :P
Phil Cook
Date: 1 Jul 2004 11:20:09
Message: <40e42ba9$1@news.povray.org>
> *in this way* :)
> we  simulate ambient light by adding a small amount of white light to
> each  texture whether or not a light is actually shining on that texture."
Doesn't radiosity attempt to approximate this?
Ambient has a totally different meaning in a radiosity scene. It emits
light, It will illuminate nearby objects...
> source  and how do you trace a ray along it it through the media to
> sample along?
Hmm.. Not sure how radiosity works, but ... that would be the means to
do it. I've lit entire scenes with an ambient sphere before. It's slow
as molasses, but it does work.
Heh. I just started messing around with media. I've picked it up a few
time before and prodded at it, but never really attempted to get the
hang of it. It's certainly more tricky than radiosity.
Date: 1 Jul 2004 11:26:42
Message: <opsags3z08efp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 16:12:44 +0100, Phil Cook
<phi### [at] nospamdeckingdealscouk> did spake, saying:
> *in this way* :)
> sample along?
And it's driving me nuts :)
In theory I suppose you could back-track for ambient light from the camera
to the surface and use that as a ray to sample along I don't know if
that's how ambient light interacts with media in povray
//simple code
global_settings{
radiosity{media on}}
//switch these round for comparision
//light_source{z*12 rgb 1}
cylinder{0,z*5 1 pigment{rgb 1} finish{ambient 1} translate z*10}
cylinder{0,z*7 8 pigment{rgbt 1} translate z*8 hollow
interior{media{scattering{3, rgb 0.1}}}}
//end code
note that if you lower the scattering rgb the ambient cylinder appears
brighter and vice versa, which indicates something is being altered by the
media, but you don't get the spread light effect as with the light-source.
Anyone know?
Phil Cook
Date: 1 Jul 2004 11:32:00
Message: <opsagtcrzaefp2ch@news.povray.org>
And lo on Thu, 1 Jul 2004 16:12:45 +0100, Josh <som### [at] microsoftcom> did
spake, saying:
>> cause.
> away for now...
Hey I might be needing that, have you got a light_source in your scene or
is the media showing up only with the ambient cylinder?
Phil Cook
Date: 1 Jul 2004 11:38:00
Message: <40e42fd8$1@news.povray.org>
just radiosity but it looks rubbish at the moment...what follows is not a
full scene but shows you what i've been on about
global_settings {
        max_trace_level 50
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.04
      count 35
      media on
      nearest_count 5
      error_bound 1.8
      recursion_limit 3
      low_error_factor 0.5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 10
      adc_bailout 0.01/2
cylinder        {
                <0,0,-10000>,
                <0,0,200000000>,
                2100
                hollow
                texture { pigment { Blue } finish { ambient 0 } }
// Light Source
cylinder {
  <0,0,-1000>,
  <0,0,20000000>,
  20
                  gradient z
                  pigment_map     {
                                  [0 White]
                                  [.1 White*.8]
                                  [.9 White*1.2]
                                  [1 White]
                                scale 10
                        finish  {
                                ambient 3
cylinder        {
                <0,-1000,0>,
                <0,2000000000,0>,
                500
                hollow
                                Clear
                        finish { ambient 1 }
                interior{
                        media   {
                                samples 10
                                emission 1
                                density {
                                        cylindrical scale 400
                                        density_map     {
                                                        [0 rgb 0]
                                                        [1 White*.3]
                                        warp { turbulence 10 }
                        media   {
                                absorption .02
                rotate <90,0,0>
Date: 1 Jul 2004 12:40:04
Message: <opsagwh3r2efp2ch@news.povray.org>
And lo on Thu, 1 Jul 2004 16:39:37 +0100, Josh <som### [at] microsoftcom> did
spake, saying:
>> or
<snip code>
Hmmm interesting, from your code.
with:
camera{
location z*-5000
I note if I remove your cylinder 'light source' the picture remains
unchanged if I then also remove the media{emission...} and add
light_source{z*((20000000+1000)/2) rgb 1} that produces the fuzzy
qualities I'd expect from media.
I'll ponder.
Phil Cook
Date: 1 Jul 2004 13:16:31
Message: <40e446ee@news.povray.org>
  You thought wrong.
  Media does not need light sources to show up. Radiosity doesn't check
light sources, only the brightness of things. (Whether or not radiosity
takes media into account at all is another issue I haven't studied.
However, that's unrelated to light sources anyways.)
Date: 1 Jul 2004 13:18:30
Message: <40e44766@news.povray.org>
  AFAIK media does not take radiosity samples (that would be prohibitively
slow).
  You can make media to affect the illumination of surfaces (using
radiosity) but not the other way around.
Date: 1 Jul 2004 19:14:15
Message: <40e49ac7$1@news.povray.org>
If I'm right the radiosity doesn't affect the media. Media affects the
radiosity instead.
If radiosity would affect media, things like light-bleeding would be very
easy to do. Unfortunately this would take ages to render of course..... but
it would be so cool!!!
Date: 5 Jul 2004 06:21:37
Message: <opsantk8dcefp2ch@news.povray.org>
And lo on 1 Jul 2004 13:16:31 -0400, Warp <war### [at] tagpovrayorg> did spake,
saying:
>> to
>   You thought wrong.
As usual
So what does it use to sample along if their are no light_source's? Does
radiosity mean that ambient objects produce traceable light rays that
media can use, really interested as I've never had media show up without a
light_source regardless of radiosity or not and it would be useful to know.
//code
#declare Radiosity=on;
#declare Emission=off;
global_settings
#if (Radiosity)
radiosity{
media on
camera{
location <10,15,10.5>
look_at <10,10,11>
box{0,<20,20,12> pigment{rgb 1} finish{ambient 0
#if (Radiosity)
diffuse 1
} hollow
interior{media{scattering{3 rgb 0.001}
density{spotted
color_map{
[0 red 0]
[0.1 red 5]}
warp{turbulence 10}
light_source{10 rgb 1}
#if (Radiosity)
#if (Emission)
sphere{10,1 pigment{rgbt 1} finish{diffuse 1} hollow
interior{media{emission rgb 1}}
#else
sphere{10,1 pigment{rgb 1} finish{ambient 1}}
#else
#if (Emission)
#else
light_source{10 rgb 0.5}
sphere{<7,10,10>,1 pigment{rgb 1} finish{diffuse 1}}
//end code
Altering the Radiosity and Emission variables the only time I get a hint
of red from the media is when the light_source is present.
Neither the wall nor second sphere displays any redness without the
light_source present, neither does the emission.
I would be really really curious as to getting ambient and media working
in this way.
Phil Cook
Date: 7 Jul 2004 10:57:30
Message: <40ec0f5a@news.povray.org>
  I didn't say light sources do not affect media. I just said light
sources are not needed for media to show up (that is, they are not
the only thing that affect them).
  In fact, light sources do not have any effect whatsoever on emitting
media. In absorptive media light sources only affect the shadow of
the media. Scattering media fully takes into account light sources,
but can still be seen even if there are none.
  If you are lighting your scene using emitting media and radiosity,
light sources will not affect the brightness of the media.
Date: 7 Jul 2004 12:30:30
Message: <opsarz4stqefp2ch@news.povray.org>
And lo on 7 Jul 2004 10:57:30 -0400, Warp <war### [at] tagpovrayorg> did spake,
saying:
Might be bad phrasing on my part I'm not arguing with you I'm am genuinely
trying to understand this, the ambient light_source has no point source
how does Povray calculate the angle of the light ray from the surface in
order to sample along it? lets put it another way. I shine a parallel
light into a scattering media box that has a hole cut in it, the result is
a 'light beam' through the media, I now substitute the parallel
light_source for an ambient 1 plane will this still produce the 'light
beam' with radiosity enabled. Hmm just tried it,seems to be a no.
> media.
Yup
> the media.
Yup
Ah here we are, what are they seen with? All I can assume is that with
radiosity a ray is being produced as a reflection from the surface from
the ambient light_source to any surrounding surfaces and that the media
affects this or uses this to sample along. I saw this when I altered a
scattering media in front of an ambient 1 object and saw the apparent
brightness drop, however the media was not illuminated around the object.
In the code previously the media was red scattering with an white ambient,
if the radiosity was being affected by the media why did the object
continue to appear white when it should have been red?
I'm not sure what you mean by the brightness of the media, the only way I
can take this is that the media affects the ambient/emission but the media
*itself* is not affected which is why it does not show up. Ah I sort of
see, perhaps, if you have a media with a density/colour map then an
ambient object will shine through those areas that are 'clear' but be
blocked by the 'dense' parts and show up as black rather than as a colour.
Have I got that right?
Phil Cook
Date: 7 Jul 2004 13:23:09
Message: <cjameshuff-A69229.12232607072004@news.povray.org>
In article <opsarz4stqefp2ch@news.povray.org>,
It doesn't. Ambient light does not come from any direction, that's why
it makes things flat colored instead of shaded.
No, it won't. Radiosity does not affect media, doing so would be either
extremely slow or memory consuming. However, media can optionally affect
radiosity. This is slow, but workable.
They block light. Scattering media without direct light is essentially
absorbing media.
This assumption is wrong. It can't work this way...at least, not in a
reasonable period of time. What you describe would be how a forward
raytracer would do it. Global photon mapping could do the job, but the
memory requirements would be huge.
http://tag.povray.org/
