POV-Ray : Newsgroups : povray.general : Heat haze... Server Time
21 Oct 2026 15:10:01 EDT (-0400)
  Heat haze... (Message 1 to 20 of 20)
Subject: Heat haze...
Date: 18 May 2004 14:32:23
Message: <40aa56b7@news.povray.org>
Can this be done with Pov? I would imagine that focal_blur could/would
be used, but how would you produce that undulating, blurred, wavy
effect behind your scene?
 Any ideas?
 ~Steve~
Subject: Re: Heat haze...
Date: 18 May 2004 15:14:30
Message: <40aa6096@news.povray.org>
"St." <dot### [at] dotcom> a écrit dans le message de
news:40aa56b7@news.povray.org...
Untried, but in some circumstances I guess that a smart normal in the
camera{} could do the trick.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 18 May 2004 15:34:49
Message: <Xns94EDDB865CB5Dseed7@news.povray.org>
Or a transparant non reflective plane with a normal and ior, about halfway
the depth of the scene. A gradient could be used to control the density
from the normal towards the sky.
Ingo
Date: 18 May 2004 17:48:51
Message: <40aa84c3$1@news.povray.org>
> smart normal in the camera{} could do the trick.
There probably are cases where it suffices, but in general this solution
is not suitable, since it is not dependent on distance. This creates two
related problems:
- The turbulence is equally strong for close and distant parts of the
scene. (I.e. it does not add up.)
- The turbulence pattern does not follow the perspective - that is, it
doesn't become smaller with distance.
In effect, using a normal in the camera will simulate heat that is
located right where the camera is and not in the rest of the scene.
For a suggestion that IMHO will often create more useful results, see
Ingo's reply.
Rune
rune|vision:  http://runevision.com **updated Apr 27**
POV-Ray Ring: http://webring.povray.co.uk
Date: 18 May 2004 17:58:42
Message: <40aa8712$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:40aa56b7@news.povray.org...
The details would have to be worked out, but the basics of my idea would
be to first make a distance-information render where every surface is
colored according to it's distance from the camera, then to use this
information in combination with a heat-wave looking pigment function to
blur surrounding pixels of a full-color render in a heat-wave style
pattern. Something like: blur=distance*heat-wavefunc.
 -Shay
Date: 18 May 2004 18:32:53
Message: <40aa8f15@news.povray.org>
  But fluctuations in air temperature doesn't cause blur, it causes
variations in the IOR of the air which is completely different thing.
Date: 18 May 2004 19:11:10
Message: <40aa980e$1@news.povray.org>
St. nous apporta ses lumieres ainsi en ce 2004/05/18 14:32... :
> Any ideas?
> ~Steve~
I tought of a trick:
Use a serie of invisible refractive boxes with small normal variations
and low iors (1.001 to 1.1) set at a scale that increase with the
distance from the camera. Increase max_trace_level by double the number
of boxes. That way, distent objects will get more distortion than close
ones. It's obvious that it will also increase render time. The boxes
have to be large enough to cover all the visible area and hollow if you
have any media like some fog.
I never tested it.
Date: 18 May 2004 20:19:38
Message: <40aaa81a$1@news.povray.org>
On a related note, how do you get distance information from a regular
povray scene?
Date: 18 May 2004 21:21:37
Message: <40aab6a1@news.povray.org>
"Rune" <run### [at] runevisioncom> a écrit dans le message de
news:40aa84c3$1@news.povray.org...
> related problems:
I know, I know, but it's cheap (to create) and fast (to render), and cheap
and fast solutions should always be tried before more expensive and slower
ones... Hey, even in big budget movies they use sock puppets instead of CGI
sometimes :)
G.
- Posters
Date: 19 May 2004 02:49:29
Message: <40ab0379@news.povray.org>
Gilles Tran wrote:
>> in general this solution is not suitable, since
> fast (to render), and cheap and fast solutions
> slower ones...
True. :)
Rune
Date: 19 May 2004 06:01:48
Message: <40ab308c$1@news.povray.org>
Sally nous apporta ses lumieres ainsi en ce 2004/05/18 20:17... :
>povray scene?
Remove all lights, all textures.
Remove any radiosity, photons and focal blur.
Bind everything in a single union.
Apply a gradient z texture, black on the far end, white on the near end,
ambient 1.
Extra: use the hf_gray_16 option and you are set to do stereogram or
hight_field.
It renders prety fast.
Date: 19 May 2004 12:08:30
Message: <40ab867e@news.povray.org>
"Gilles Tran" <gitran_nospam_@wanadoo.fr> wrote in message
news:40aa6096@news.povray.org...
Is there something up with your clock or is it OE at my end? (I'm seeing a
9/5/2004 post in reply to a post on 18/5/2004)
Date: 19 May 2004 16:27:17
Message: <40abc325@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> a écrit dans le message de
news:40ab867e@news.povray.org...
What happened is that the last beta expired last night, so I had to set the
clock back to have it work again, and I forgot to change it back before
posting... I guess it's going to happen a few times until a new version is
out...
G.
- Posters
Date: 19 May 2004 17:20:42
Message: <cjameshuff-0C8BE3.16210019052004@news.povray.org>
In article <40ab308c$1@news.povray.org>, Alain <aze### [at] qwertygov>
> ambient 1.
Only if you are using an orthographic camera. For most other camera
types, use a spherical pattern centered on the camera. You could also
use an entirely white texture and black fog...this should work
regardless of the camera type, but won't give a linear mapping.
http://tag.povray.org/
Date: 20 May 2004 13:58:45
Message: <40acf1d5@news.povray.org>
Hey, thanks guys, and sorry for the late reply. I'm hopefully going to
use a mixture of Ingos and Alains methods.
 I'm starting to get some half decent results with my test image, but
it's not quite right yet. I'll post something in p.b.i as soon as I
can.
 I ended up trying:
  texture{
  pigment {rgbt 1}
  normal {wrinkles warp {turbulence .8 omega .7}}
  finish {roughness 0.8 }}
 for my clear model, but the model is not good at the moment. I'll
keep trying. Is there
anything in the above that I should change though?
 I've read the docs but still don't understand 'omega'.
  ~Steve~
Date: 20 May 2004 16:48:47
Message: <40ad19af$2@news.povray.org>
St. nous apporta ses lumieres ainsi en ce 2004/05/20 13:58... :
>can.
> I ended up trying:
>  texture{
>  pigment {rgbt 1}
>  ~Steve~
Turbulence is repeated a few times controled by the octaves value
The omega value reduce the effective effect of the subsequent moves.
Supose that the first move was 1 unit long and omega is set to 0.5
(default), then move 2 is 0.5 unit, move 3 is 0.25 unit, move 4 is 0.125
unit,...
Increasing the omega value will increase the disturbance caused by
higher octaves ranks.
In your case, the effects are: 1, 0.7, 0.49, 0.343, 0.2401, and 0.16807
time the base one.
Date: 26 May 2004 17:46:04
Message: <40b5101c$1@news.povray.org>
There's a couple of examples in povray.binaries.animations - look for "Heat
Waves".
There's also a post of mine in povray.animations called "Heat Shimmer" that
sort of started the other posts.
The best IMHO is:
----- Original Message -----
Newsgroups: povray.binaries.animations
Sent: Tuesday, July 16, 2002 06:22
Subject: Heatwaves #3 [divX]
but there wasn't a reply on how Jan did it
        == John ==
>  Any ideas?
>  ~Steve~
Date: 26 May 2004 17:46:05
Message: <40b5101d@news.povray.org>
Actually, I take back what I said, here's how Jan did it:
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3d30c80a@news.povray.org...
> this is only a quick hack I did, when I saw the post of Tom A.
> I don't know, how fast his ISO solution renders, but I used
> a version, that uses transparent spheres around the camera,
> "only" with a normalmap.
> The MPG is killig a lot details here, I've to admit this
> version isn't yet, what I'm after.
> But I've currently a version running, with better params, that will
> be ready in some hours, so I can post it tomorrow.
Date: 29 May 2004 07:04:42
Message: <40b86e4a@news.povray.org>
"John D. Gwinner" <joh### [at] cornelledu> wrote in message
news:40b5101c$1@news.povray.org...
for "Heat
> Waves".
Shimmer" that
     Hi John, thanks very much for that - I don't usually check the
animations group. It lead me to Tom Aust's piece of isosurface code
which I'm playing with now, (thanks Tom). It needs a lot of tweaking
to get it right for what I want to do, but it's looking very
promising.  :)
       ~Steve~
>         == John ==
Date: 30 Jun 2004 00:35:32
Message: <40e24314@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:40b86e4a@news.povray.org...
> promising.  :)
No problem, I'd be interested in what you come up with.
What I was trying to do was vehicle exhaust, and I never solved it.  This
particular exhaust was pointed straight up (more of a cooling tower than
vehicle exhaust, actually).  I made some fitfull attempts with 'liquid
spray' pointed straight up, to make the cone shape, but it never look right,
but I didn't mess with it that much.
Ironically my vehicles ended up on Mars, so now I don't have to worry about
exhaust.  But it would be nice to relocated them someday, I'm sure the crews
would like to go home!
        == John ==
