POV-Ray : Newsgroups : povray.general : non-transparent SSS and interior texture with mesh2 Server Time
1 Nov 2026 20:37:36 EST (-0500)
  non-transparent SSS and interior texture with mesh2 (Message 1 to 16 of 16)
Subject: non-transparent SSS and interior texture with mesh2
Date: 6 May 2004 06:48:26
Message: <409a17fa@news.povray.org>
Probably old question :)
- I trying to do SSS with media on Mesh2 - it works, but I simply can't do
apsolute non-transparent SSS, even with tons of intervals - object have some
very thiny details, like a ears. Is there some workflow (for relative fast
rendering:), maybe with photons?
- How to apply interior_texture to mesh2? The same settings works perfectly
with POV solids, but with mesh2, nothing... Maybe I'm a stupid :) or I
didn't laying hands on POV in a few last years.... My mind is probably in
features of POV 3.1...
Thanks in advance....
Subject: Re: non-transparent SSS and interior texture with mesh2
Date: 6 May 2004 07:39:57
Message: <409a240d@news.povray.org>
  There are two types of primitives (ie. surfaces) in POV-Ray: Those with
a defined interior and those without.
  Their difference is that for a primitive with a defined interior for any
point in space you can ask whether it's inside that primitive or not
(and in fact the POV-Ray SDL has such a function: inside()).
  Meshes belong to the second category: They do not have a defined interior.
You can make a mesh to guess at its own interior by specifying an
inside_vector (the name of this keyword is admittedly confusing because
it describes its goal and not what the specified vector actually does).
  Curiously, however, interior_texture uses (AFAIK) a completely different
method for finding out which side of the surface is facing outside and
which is facing inside: Using the normal vector of the surface.
  All POV-Ray primitives have a normal vector (else lighting calculations
would be impossible), naturally also meshes.
  I just tried using interior_texture with a mesh with smooth triangles and
it worked ok. The side of the triangles opposite to the direction of the
normal vectors was textured with the interior_texture.
  With flat triangles the normal vector is automatically calculated by
POV-Ray. If I'm not mistaken, the order of the vertices decides which
side of the triangle is the side of the normal vector. I tested this
as well, and interior_texture worked with flat triangles ok.
  I haven't tested with mesh2, though, but there shouldn't be any difference
(after all, it's just an alternative syntax for the same primitive).
Unless there's something odd going on with the mesh2 syntax, perhaps
you are making some mistake in your code? Could you post a short
example?
Date: 6 May 2004 13:50:53
Message: <cjameshuff-CAC4EC.12501006052004@news.povray.org>
In article <409a17fa@news.povray.org>,
You aren't going to get opaque media by using "tons of intervals". You
need to increase the media density, and use a high extinction.
The interior_texture feature should work in exactly the same way with
mesh2 objects as with any other object.
http://tag.povray.org/
Date: 6 May 2004 18:34:50
Message: <409abd8a@news.povray.org>
difference
> example?
Probably i do mistake with code (it's a mesh 2 with UV-mapping and
image_maps, so I probably put textures on wrong place) - POV refused to work
with interior_texture in texture_list, also with transparent texture in
texture list with both exterior and interior texture at the end of inc file
of  mesh2.
Problem is solved by faking SSS in scanline program and compositing later -
because od deadline....
I will try to post example if this really doesn't work, when I prepare model
for rules of P.B.I.
(it contains nudity).
Thanks for help.
Date: 7 May 2004 05:50:05
Message: <409b5bcd@news.povray.org>
> for rules of P.B.I.
  Nudity means that the scene contains at least hundreds, if not thousands
of triangles.
  That was not what I meant. With a small example I meant a minimal scene
with a camera, a light source and a mesh2 with a couple of triangles which,
when rendered, clearly shows the effect you are talking about.
  It's much easier to study the code and suggest fixes with such scene,
and the issue can be kept in a single newsgroup (because no binary
attachments are needed).
Date: 7 May 2004 12:48:38
Message: <409bbde6$1@news.povray.org>
I guess that it's little bit too late for you (you mentioned deadline),
but for future note (and self-promotion :)  those, who feel adventerous
enough to try patched POV-Ray, could use POVMan for such purpose. See my
posting in p.binaries.images from 2003-05-18, titled 'FSSS'.
Of course it works only with POVMan (as there is shader for such
purpose) and it ain't perfect: it is faked (that's from where F comes)
with respect to light-source (main light source is given as parameter),
in some cases shadows get really messy (iirc it appears in cases, when
object has several 'intersections' toward light source) etc. But it is
relatively fast and totally non-transparent and in some limited cases
could provide satisfactory results with little tinkering.
Date: 7 May 2004 13:38:49
Message: <409bc9a9$1@news.povray.org>
Hash: SHA1
can't do
have some
relative fast
	Like Warp said, you need to increase density for SSS to work on small
details. You might also want to look at the "sample_spacing" keyword
in MegaPov 0.7 which might improve your render speed a lot especially
if you have a model with both lots of tiny details and thick areas.
Look at this page for a discussion (nobody called it subsurface
scattering at the time, but it's the same thing):
http://jeberger.free.fr/mpov/mpov.html#sample
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAm8moqIYJdJhyixIRAhh9AJ4j6nxizpZ5uYFgzE9iPNan9RrBbwCeMKB6
JAm+mVoPr4xJc4WgTJWnBY0=
=7bxG
-----END PGP SIGNATURE-----
Date: 7 May 2004 21:26:54
Message: <409c375e@news.povray.org>
>   ... means that the scene contains at least hundreds, if not thousands
> of triangles.
Actually, about 2000000 triangles :), optimizied as much is possible. I
choosed POV because this number can kill common scanline renderer, POV needs
about 500MB RAM, which is quite OK for machine with 1GB.
which,
There is an example at povray.binaries.scene-files - with single sphere-like
mesh ( 68 triangles)
Right question is, how I can apply interior_texture in texture_list, or I
need some other way?
When I uncoment interior_texture, about line 320, POV reports error.
Date: 8 May 2004 03:20:02
Message: <c7i1l3$1sc$1@chho.imagico.de>
What makes you think this is valid syntax?
Not that this has anything to do with scattering media and opacity...
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 8 May 2004 09:39:16
Message: <409ce304@news.povray.org>
> purpose)
Thanks!
I using POVMan before, because of 'skin' shader, later I used Ml POV,
because of similar effect of AOI, which official POV doesn't have. Even all
other renderers (Blender internal scanline, as example) can do something
with AOI.
'Faking' isn't problem, I can compose it as a layer. Speed is important :).
Date: 8 May 2004 16:27:40
Message: <409d42bc@news.povray.org>
sphere-like
I
Well, I asking is there *any* syntax for aplying exterior and interior
texture to UV-mapped mesh in POV-Ray - with thousands triangles converted
from 3d modeling program, not a few triangles made for hobby. This
inside-outside separated materials is common feature in many renderers,
including raytracers. I'm afraid that POV can't do that.
I will be very happy if some of next official version will support some
common things like Angle Of Incidence, motion blur, fast (even 'faked',
interpolated, anything...) SSS..., ambient occlusion (newest version of
freeware Blender have AO, works very good...) just because I'm afraid for
the future of raytracer which I was using for a years.
I posted two separated answers in one message.
Date: 8 May 2004 17:24:10
Message: <409d4ffa@news.povray.org>
  You can't specify the interior_texture of individual triangles in a mesh.
You can only specify one for the whole mesh (at the 'mesh2' block level).
Date: 8 May 2004 17:55:02
Message: <c7jkvi$aqp$1@chho.imagico.de>
I am pretty sure if you are more happy with using blender no one here
will feel urged to convince you not to use it.  On the other hand it
might be a good idea to actually understand what the words you are using
there mean.  Someone who really believes what you are writing surely has
to wonder why it is possible to create good looking images with POV-Ray
at all...
Unfortunately it has become a quite common attitude recently to demand a
new feature as soon as something does not work as expected.  POV-Ray is
not a program aimed to be as easy to use as possible at all costs.  If
you have seriously tried to use the existing features to achieve the
intended effect and can well demonstrate a limitation, someone familiar
with the POV-Ray internals and the technical aspects of raytracing might
decide to implement a new feature for this purpose.  Incidently most of
the patches that have been written in the last years have been created
this way, i don't remember any written because someone demanded a
certain headword from the advertisement repertoire of commercial CG
packages.
Date: 8 May 2004 18:51:53
Message: <opr7pdsrkwzjc5hb@news.povray.org>
On Sat, 8 May 2004 22:26:30 +0200, anto matkovic <ant### [at] matkoviccom> wrote:
Look at http://hem.bredband.net/b230591/povray/inside_outside.png.
That's a mesh2 with 10k triangles. It's uv-mapped and has a different
texture on the inside. Is that what you are trying to achieve?
I looked at your post in binaries.scene-files. Here's what I think you're
doing wrong:
- Trying to use 'interior_texture' in 'texture_list'. That's not what
'texture_list' is for.
- Using 'uv_mapping' as an object attribute. It's supposed to be a texture
attribute.
What you need to do is something like this (copied verbatim from the scene
shown in the link above):
object {
	#include "squared_torus3.inc"
	texture { OutsideTex }
	interior_texture { InsideTex }
	clipped_by { plane {-y, 0.5} }
	translate 0.25*z
The include file contains a 'mesh2', and nothing else. The clipping is
just to show the inside of what is otherwise a closed object.
I consider it fairly likely that AOI will appear in some future official
version, considering that it has already been implemented and tested in an
unofficial version.
Motion blur does not strictly require anything at all from the renderer.
It can be done "externally", by temporally supersampling the image. Slow,
perhaps, but it can be done.
Why should the POV team expend effort on implementing any kind of "fake"
SSS, when POV-Ray can already do "real" SSS? I would much rather they
spend time optimizing media rendering (and thus SSS) instead of trying to
add some new feature that isn't really needed.
If you really want something fake, check out "sss_macro.inc" by Samuel
Benge. Find it in
http://news.povray.org/povray.binaries.scene-files/thread/%3C3FC5387A.5080705%40hotmail.com%3E/.
You asked about "ambient occlusion" before, in povray.general. The answer
given then was that POV-Ray can achieve a similar effect (better even)
with it's 'radiosity'.
I am not the least bit afraid for the future of POV-Ray.
I guess I did too...
FE
Date: 8 May 2004 20:52:23
Message: <cjameshuff-F5EAB8.19522308052004@news.povray.org>
In article <409d42bc@news.povray.org>,
I am not very familiar with the specifics of how UV-mapping works, but
it shouldn't pose much of a problem. Meshes do work with the interior
texture feature, and the syntax is the same as for every other object.
However, you can't specify the interior texture for individual triangles.
Not in the next version, which won't have many new rendering features.
Perhaps in later versions, and likely in some unofficial versions.
> will support some common things like Angle Of Incidence,
Already exists in a pattern patch, and can be done using one of my
(currently unreleased) function patches. Probably won't make it into the
official version, though features that allow you to implement an AOI
pattern probably will eventually.
> motion blur,
Exists in an older version of MegaPOV, couldn't be updated in time for
the new version. You can do similar effects without the patch by using
multiple transparent copies of an object.
> fast (even 'faked', interpolated, anything...) SSS...,
This is a very complex feature, requiring much work before work on the
implementation even starts. There are many possible ways to do it, and
finding a good one will take some research and experimentation.
> ambient occlusion (newest version of freeware Blender have AO, works
> very good...)
POV doesn't *need* ambient occlusion. It's a cheap hack replacement for
radiosity, which POV already does quite well. This will most likely
never be implemented.
Date: 9 May 2004 10:36:09
Message: <409e41d9$1@news.povray.org>
anto matkovic nous apporta ses lumieres ainsi en ce 2004/05/08 16:26... :
>sphere-like
>I
Be carefull with the terms used, some times, the exact same term is used
by different programms for very different things, and different
programms use unrelated terms to refer to the exact same, or very
similar, thing.
Take "nurb" for example, Maya (ple) use it for "plastic" softly shapable
objects while other, like moray, use it for something similar to a
sphere sweep...(as far as I can tell from my experience)
Ambient occlusion looks like some faked radiosity.
