POV-Ray : Newsgroups : povray.general : clipped_by a textured object Server Time
21 Oct 2026 15:54:57 EDT (-0400)
  clipped_by a textured object (Message 1 to 4 of 4)
Subject: clipped_by a textured object
Date: 3 May 2004 15:30:06
Message: <40969dbe$1@news.povray.org>
I'd like to use a previously-declared object with clipped_by.
Unfortunately this object has a texture, so of course errors are raised
when using it for clipping. Is there a syntax that would allow me to
"remove" the texture from an object, or create a new object without a
texture that is otherwise a copy of another?
-Eamon
Subject: Re: clipped_by a textured object
Date: 3 May 2004 16:28:48
Message: <4096ab80@news.povray.org>
  Sorry, there's no currently a way of doing that.
  You'll have to modify the original object to easily remove its
texture (eg. enclose its texture definitions inside #ifdef blocks).
Date: 3 May 2004 22:58:18
Message: <409706ca$1@news.povray.org>
Thanks for the reply, even if it isn't what I wanted to hear.
Just out of curiosity (and feel free to not waste your time answering
this), why enforce the "no texture" rule for clipping objects anyway? I
can think of plenty of reasons to clip by an object that's also drawn,
and in my case (programically-created scene files), it would be pretty
convenient. I tried to think of a good reason to insist that clip
objects not be textured from POV-Ray's standpoint, but couldn't come up
with anything.
-Eamon
Date: 4 May 2004 10:25:28
Message: <cjameshuff-232C26.10244104052004@news.povray.org>
In article <409706ca$1@news.povray.org>,
> with anything.
No technical reason that it couldn't be done, but it would waste memory
to store the texture for an object that will never be visible.
Personally, I think it should let the memory be wasted for the time
being, it would be less likely to be a problem.
http://tag.povray.org/
