POV-Ray : Newsgroups : povray.general : Sphere/polyherdon question Server Time
1 Nov 2026 20:39:03 EST (-0500)
  Sphere/polyherdon question (Message 1 to 21 of 21)
Subject: Sphere/polyherdon question
Date: 1 May 2004 18:06:33
Message: <40941f69@news.povray.org>
I need to approximate a sphere with 60,000 points.  How can I generate such
a polyhedron with equivalent points on the sphere?  Perhaps a C algorithm is
posted some place on this web site but I can't find it.
Thanks,
Ilia
Subject: Re: Sphere/polyherdon question
Date: 1 May 2004 23:01:36
Message: <40946490$1@news.povray.org>
If you can cope with a number close to 60000, start with an octahedron (or
possibly an icosahedron), then subdivide each triangle into four (by drawing
a new triangle with its vertices the midpoints of the edges of the original
triangle), then rescale the position of these midpoints onto the sphere
surface. This subdivision is then repeated.
If you need exactly 60,000 points, there are ways that I can see of doing
it, but they're not very nice.
-Chris
Date: 2 May 2004 00:24:12
Message: <pdb_NOSPAM-ABFA9D.14241102052004@news.povray.org>
if you can live with other numbers around 60,000 (whos going to count
them anyway?!) then see this
   http://astronomy.swin.edu.au/~pbourke/modelling/sphere/
Paul Bourke
pdb_NOSPAMswin.edu.au
Date: 2 May 2004 02:31:24
Message: <409495bc@news.povray.org>
I have done that, but the distribution is not even as the four triangles
resulting from division of each original one are not equilateral.  The final
distribution is somewhat skewed with higher "point density" about the
original vertices.
Mersenne twister can probably produce a random enough (as in "uniform")
distribution but I'd rather do it exactly if possible.  I need to do it once
to generate an input table for an application, so time and algorithm
efficiency is irrelevant.
The exact number of points does not matter as long as it is large enough.
Best regards,
Ilia
"Chris Johnson" <chris(at)chris-j(dot)co(dot)uk> wrote in message
news:40946490$1@news.povray.org...
drawing
original
> -Chris
Date: 2 May 2004 03:59:01
Message: <4094aa45@news.povray.org>
> the four triangles resulting from division of each
> original one are not equilateral.  The final distrib-
> about the original vertices.
This will not be the case if you start with an icosahedron
> it is large enough.
60k is simple to generate exactly. I don't have the vocabulary to explain
how, but I can generate this array in a few minutes and email it to you if
you would like.
Let me know.
 -Shay
Date: 2 May 2004 04:48:22
Message: <4094b5d6@news.povray.org>
Very interesting, thank you for the link.
Sebastian H.
Date: 2 May 2004 05:01:11
Message: <4094b8d7@news.povray.org>
Sebastian H. wrote:
>>> generate such
>>> algorithm is
Wow I think I'll spend some time on your site!
Sebastian H.
Date: 2 May 2004 07:30:42
Message: <4094dbe2$1@news.povray.org>
The polar method isn't going to help here in its current form if the
subdivision method generates a distribution that is too uneven: as you say,
the polar method generates very small triangles at the poles. It could
perhaps be modified to generate fewer triangles at each "line of latitude"
closer to the poles, but this might be tricky.
-Chris
Date: 2 May 2004 07:38:34
Message: <4094ddba$1@news.povray.org>
-[The final distribution is somewhat skewed with higher "point density"
about the original vertices]-
Once you have a mesh of the points, if you model electrostatic repulsion
between the points, while keeping them bounded on the sphere, after a few
iterations of the repulsion algorithm, the will have rearranged themselves
into an even distribution. Alternatively, it might be a good idea to model
the edges as springs pulling the modal together - this might avoid the
potential problem of the points reshuffling so much that they form very
non-iscosceles triangles. If you start with an icosahedron, I think this
method might work.
One could start with 60000 random points on a sphere and apply the
electrostatic repulsion method to get a near-even distribution, but the
difficulty then is finding the best way to form the edges. This problem of
finding the "best" edges given a set of points is quite hard I think.
-Chris
Date: 2 May 2004 09:22:10
Message: <4094f602@news.povray.org>
Unfortunately, it is the case.  Just to prove it, take a look at a triangle
with the following apical positions A=1 0 0 , B=0 1 0, C=0 0 1.
Let's divide sides AB and AC in half and normalize the resulting points.
AB/2 = D = {cos(45), cos(45), 0}  and  AC/2 = E = {cos(45), 0, cos(45)}.
The resulting triangle  ADC  is not equiltateral :
AD = AE = sqrt (pow(1-cos(45),2)+pow(cos(45),2)) = 0.76
DE = sqrt(0+ 1/2 + 1/2) = 1.
It's the same story with icosahedron.
> > it is large enough.
> you would like.
If you could send me your algorithm I would most certainly appreciate it.  I
want to be able to generate any number of points to model the sphere, I am
not sure what number will satisfy my task but the more the better.
Ilia
Date: 2 May 2004 09:26:00
Message: <4094f6e8@news.povray.org>
Generating the edges is irrelevant to me.  I just want the vertices.  The
ultimate task for me is to determine the "solid angle" of a certain
projection on the sphere and analytical techniques have not been accurate
enough.
Could you please refer me to  an "electrostatic repulsion" algorithm - this
sounds like  a winner.
Many thanks,
Ilia
news:4094ddba$1@news.povray.org...
> method might work.
> -Chris
Date: 2 May 2004 10:29:38
Message: <409505d2$1@news.povray.org>
"Ilia Guzei" <igu### [at] fozziechemwiscedu> schrieb im Newsbeitrag
news:40941f69@news.povray.org...
such
is
I would use a golden-section-based "Sunflower"-Distribution.
I've made a small POV-Scene which demonstrates this.
I think you won't have problems writing a similar C-program
off the POV-Source.
Source:
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <1.3, 3.5, -1.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <-20, 30, -60>
  color rgb <0.9, 0.7, 0.3>
light_source {
  <70, 40, 80>
  color rgb <0.1, 0.3, 0.9>
#declare N  =  6000; // Number of Spheres
#declare M  =  N;
#declare sr = 1 * 2/sqrt(N);  // sphereradius
#declare phi= 0;
#declare gsa= 360*((sqrt(5)-1)/2);  // golden section angle
#declare py = -1;
#declare dy = 2/(N-1);
#while(M>0)
  sphere {
    py*y, sr
    translate sqrt(1-py*py)*x
    rotate phi*y
      pigment{color rgb 1}
      finish{ambient 0 diffuse 0.5 reflection{0.6}}
  #declare py=-1+2*(M-1)/(N-1);
  #declare phi=phi+gsa;
  #declare M=M-1;
> Thanks,
> Ilia
Thies
Date: 2 May 2004 13:17:27
Message: <40952d27@news.povray.org>
Ilia Guzei wrote:
> Shay:
> icosahedron
> Ilia:
> a look at a triangle with the following apical positions
> <snip>
Yes, I see that you are correct. It seems that producing this with this type
of subdivision is impossible. Still, I made a distribution of 60k and
another at around 164k which were very close. Springs would not help
either, as topologically equal length sides of the subdivided shape are not
possible.
Probably the best way to start, however. On a subdivided mesh with all
points lying on a unit length sphere, the differences were around .0015, so
some repulsion correction would decrease that difference to beyond
measurable in a few steps.
 -Shay
Date: 2 May 2004 13:20:00
Message: <web.40952d74ab47deadb705e7640@news.povray.org>
Here is an idea for fixing the vertex hoping:
http://www.geocities.com/fcmodelview/edgefix.jpg (copy and paste to browser)
To implement this, I think the easiest way would be to create a sub-routine
that connects an n-gon to an n/2-gon, and then call this routine for the
last "facets" of every slice. (Ie the "facets" closest to the vertex.)
Date: 2 May 2004 13:50:26
Message: <cjameshuff-4F7C4C.13493402052004@news.povray.org>
In article <40941f69@news.povray.org>,
A recursively divided polyhedron will not give you fine control over the
number of points. Each recursion multiplies the number of triangles by 4.
A more useful tessellation I've found is to use the tessellation of a
cube projected onto the sphere. In other words, tessellate the sphere as
six rectangular patches. This gives you far finer control over the
actual resolution you want, rather than restricting you to powers of 4,
but still gives a fairly even distribution of triangles.
http://tag.povray.org/
Date: 2 May 2004 14:02:19
Message: <cjameshuff-F3FCDE.14012902052004@news.povray.org>
In article <409495bc@news.povray.org>,
It is not possible to do so for large numbers of points. As I recall,
the largest number of points that can be perfectly evenly distributed is
20, the triangles of an icosahedron or vertices of a dodecahedron.
If you need points with overall even spacing, and the spacing given by
polyhedron subdivision is too uneven, the electrostatic repulsion method
mentioned can help you minimize the unevenness. You basically model each
point as a particle that repels the other particles by the 1/r^2 law.
Figure out which direction the surrounding particles are pushing each
particle, move it slightly in that direction and project it's new
position onto the sphere, and repeat until the particles settle down
enough.
Subject: Thanks to all.
Date: 2 May 2004 18:20:53
Message: <40957445@news.povray.org>
Thanks to all who contributed to this discussion.  Paul Bourke's site was
interesting.  Ultimately, implementation of the "electrostatic repulsion"
suggestion did the trick.
I generated a desired number of points on the sphere in a random fashion and
then minimized the repulsion between the points.
While testing, a polyhedron with 8 vertices was inevitably a square prizm
rather than a cube...
Ilia
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-F3FCDE.14012902052004@news.povray.org...
once
> enough.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
Date: 2 May 2004 21:30:33
Message: <4095a0b9@news.povray.org>
Christopher James Huff wrote:
> A more useful tessellation I've found is to...
This is how I produced my 60,000 vertices array.
 -Shay
Date: 3 May 2004 15:46:20
Message: <4096a18c@news.povray.org>
I haven't seen an algorithm for it specifically, though an example was on
p.binaries.animations a while ago.
Heres some C code - I've typed this straight into the post so there could
well be typos, but I think the overall idea is right:
typedef struct
   float x,y,z;
} point;
int maxPoints=60000;
point *points;
points=(point *)malloc(maxPoints*sizeof(point));
float repulseCoeff = 0.1;
int maxIterations = 50;
float dd;
// Initially distribute points randomly on sphere
for (int n=0; n<maxPoints; n++)
    do
        points[n].x = frnd(2)-1;   // frnd(float max) generates random
number between 0 and max
        points[n].y = frnd(2)-1;
        points[n].z = frnd(2)-1;
    while (sq(points[n].x)+sq(points[n].y)+sq(points[n].z)>1)
for (int i=0; i<maxIterations; i++) // Iterate this bit a few times
        for (int m=n+1; m<maxPoints; m++) // for each pair of points...
            // make them repulse each other, without a restriction that they
stay on the sphere
dd=sq(points[n].x-points[m].x)+sq(points[n].y-points[m].y)+sq(points[n].z-po
ints[m].z);
            points[n].x += (points[n].x-points[m].x)*repulseCoeff/dd;
            points[n].y += (points[n].y-points[m].y)*repulseCoeff/dd;
            points[n].z += (points[n].z-points[m].z)*repulseCoeff/dd;
            points[m].x -= (points[n].x-points[m].x)*repulseCoeff/dd;
            points[m].y -= (points[n].y-points[m].y)*repulseCoeff/dd;
            points[m].z -= (points[n].z-points[m].z)*repulseCoeff/dd;
    for (int n=0; n<maxPoints; n++) // for each point
        // stick it back onto the sphere
        dd = sqrt(sq(points[n].x)+sq(points[n].y)+sq(points[n].z));
        points[n].x/=dd;
        points[n].y/=dd;
        points[n].z/=dd;
-Chris
Date: 3 May 2004 16:44:28
Message: <4096af2c$1@news.povray.org>
Chris Johnson nous apporta ses lumieres ainsi en ce 2004/05/03 15:44... :
>typedef struct
>   float x,y,z;
>} point;
>point *points;
>====> points=(point *)malloc(maxPoints*sizeof(point));
>float dd;
>    do
>stay on the sphere
>ints[m].z);
>        points[n].x/=dd;
>        points[n].y/=dd;
>        points[n].z/=dd;
>-Chris
There is a bug, using "malloc" and never freeing the allocated memory =
memory leak.
Subject: Re: Thanks to all.
Date: 4 May 2004 13:04:40
Message: <cjameshuff-7FB9BC.13035304052004@news.povray.org>
In article <40957445@news.povray.org>,
It's not a prism either, but something called a "square antiprism":
http://mathworld.wolfram.com/SphericalCode.html
http://mathworld.wolfram.com/SquareAntiprism.html
