POV-Ray : Newsgroups : povray.general : Stereoscopic camera theroy Server Time
21 Oct 2026 16:51:28 EDT (-0400)
  Stereoscopic camera theroy (Message 1 to 6 of 6)
Subject: Stereoscopic camera theroy
Date: 28 Mar 2004 12:06:28
Message: <40670613@news.povray.org>
Hi all,
I want to set up a nice stereoscopic camera for anaglyphs, cross-eyed
view and parallel view images. [Results will be made available publically
when I succeed...]
I know, there is StereoPOV but I need to look more precisely at the issue:
IIRC, StereoPOV uses a non-perpendicular camera which results when
simply doing:
  location = location +- eye_distance/2 * right;
  direction = direction -+ eye_distance/(2*stereo_win_distance) * right  (*)
(stereo_win_distance is the distance where the left and right rays
cross each other and hence the plane which seems to be at the depth of
the projection screen plane when viewed stereoscopically.)
I do not understand why it is correct to use such a non-perpendicular
camera.
According to my understanding, the camera actually is generally NOT
perpendicular but the angle between right and direction (=delta) depends
not only on the ratio of eye_distance to stereo_win_distance but also on
the actual eye ray crossing distance when viewing the image.
This means that
(a) cross-eyed view and parallel view require different delta-angles.
(b) the above description (*) is incorrect; e.g. for anaglyphs one would
    need to compensate for eye ray crossing at the image "center" (focal
    point) depth rather than at the stereoscopic window depth.
    My experiments, however, did not yet confirm that.
I hope anyone here has enough clue to point out exactly what is going on.
Wolfgang
Subject: Re: Stereoscopic camera theroy
Date: 29 Mar 2004 04:19:25
Message: <pdb_NOSPAM-BBFE3C.19192529032004@news.povray.org>
> when I succeed...]
High quality stereo is one of my main activities, I use OpenGL, POVray,
3dStudioMax, and a bunch of other rendering tools. I would be happy to
answer any specific questions you might have although only in regard
to creating stereo pairs that are to be presented to each eye
independently, that is, I don't deal in any of the cross eye business.
To you question about camera position, yes parallel cameras is correct,
toe in camera introduce vertical parallax and hence increased eye strain.
I have tools that implement the following is a range of packages that
don't have builtin stereoscopic support
    http://astronomy.swin.edu.au/~pbourke/povray/raystereo/
Paul Bourke
pdb_NOSPAMswin.edu.au
Date: 29 Mar 2004 11:59:33
Message: <406855f5$1@news.povray.org>
I agree with Paul Bourke, cameras should always be
parallel. Converging (what you refer to as cross-eyed
view) cameras introduce keystone distortion. Stereo
set ups based on converging cameras only work with
a short depth of field. Converging cameras do set the
stereo window at the convergence point, which is
convenient, but you can set the stereo window of
parallel views by trimming the excess.
Correctly rendered stereo pairs can be viewed by
the cross-eye method, but not created by toe-in of
the cameras.
"Wolfgang Wieser" <wwi### [at] gmxde> wrote in message
news:40670613@news.povray.org...
> Hi all,
> when I succeed...]
> simply doing:
> camera.
> This means that
> Regards,
> Wolfgang
Date: 31 Mar 2004 04:11:46
Message: <406a8b51@news.povray.org>
I am sorry for not answering more quickly.
Okay, your web page made things a bit clearer. But still...
It seems that creating left/right stereo pairs for independent
projection onto the eyes (using a stereo helmet with two screens
or whatever) can be done using for the camera:
location = primary_location +/- eye_distance/2*right
right, up and direction stay unchanged from primary parameters.
(where "primary" means: "of the corresponding non-stereoscopic camera")
Okay, this, however, requires you to cut off a certain part of
the left and right image. Now, if one uses a non-perpendicular
camera:
location = primary_location +/- eye_distance/2 * right
direction = primary_direction -/+ eye_distanc/(2*windepth) * right
right and up stay unchanged from primary parameters.
...it seems that one can create the required left/right image
pairs without cutting off parts of the image.
[Can anyone confirm that?]
But that is just the first half; in case the above was correct,
here comes my actual problem: If one views the stereo pairs using
the anaglyph method or cross-eyed, the eye directions are not
perpendicular to the projection screen because they cross
each other before (cross-eyed) or somewhere behind the screen.
Now, the problem is: How can one compensate for that?
(I.e. which direction and right vectors need to be chosen?)
Wolfgang
P.S: I like your homepage!
Date: 6 Apr 2004 16:57:19
Message: <407319af@news.povray.org>
This isn't theoretical.
When I want a pair of pictures
for a stereogram,
I render the scene and move the file
then rotate the objects or the camera
10 - 12 degrees on only one axis of
choice.
The picture pair can be viewed via
a viewer or the cross - eyed method.
Date: 7 Apr 2004 08:37:58
Message: <cjameshuff-8F6F2D.08384107042004@news.povray.org>
In article <407319af@news.povray.org>,
 "john.s<replacewithdot>grant"
> When I want a pair of pictures for a stereogram, I render the scene
> and move the file then rotate the objects or the camera 10 - 12
> degrees on only one axis of choice.
You might want to read some of the other messages in this thread. Though
the obvious method, this way has some problems. Basically, it leaves a
greater non-overlapping image area, making the stereo view of the scene
smaller, and can cause eye strain (the images are exactly what the eye
would see, but they are projected onto a flat surface in front of the
eye). If you compensate for that effect, it might be more useful...
http://tag.povray.org/
