POV-Ray : Newsgroups : povray.general : Textures and slopes Server Time
21 Jul 2025 13:04:39 EDT (-0400)
  Textures and slopes (Message 1 to 6 of 6)
Subject: Textures and slopes
Date: 17 Mar 2004 04:25:00
Message: <4058196c$1@news.povray.org>
Hello !
I've been trying to render the same landscape in POV-Ray and Terragen,
and I found myself stuck in the texturing. I wonder, in fact, if there
is a way to do the same texturing in POV and Terragen.
As far as I understand, Terragen's textures are organized in several
layers, each with a specific color and amount of bumps. So far, layered
textures would do the trick. The point is that in Terragen, you can
control the visibility of a layer based on the slope of the underlying
layers. For example, you can have a rock layer, very bumpy, and a snow
layer over it, only in the less slopy areas, with its own bumps.
I tried to achieve such effect with a slope pattern in a layered
texture, but in this case the slope used is just that of the
height_field, not including the normal perturbation.
I can obtain something similar using slope-patterned pigments and only
one normal statement, but then I lose the control over the bumps of each
layer.
Has anyone got an idea about how to solve this problem ?
Vincent
Subject: Re: Textures and slopes
Date: 18 Mar 2004 01:12:47
Message: <40593ddf@news.povray.org>
Vincent LE CHEVALIER <lec### [at] ctiecpfr> wrote in message
news:4058196c$1@news.povray.org...
> Hello !
Been trying to do the same thing... Terragen textures really add a lot...
I'm pretty sure Terragen uses the height_field slope to determine it's
layering also. But I think Terragen interpolates its maps differently than
POV does.
> layer.
Still playing around with it, but I've had better results with texture maps
using a mix of slope & gradient than with layered textures (I still haven't
figured out how to get as much control over layers...), and I'm just
starting to play around with normal maps.  Terragen's texture editor layers
things by both slope & altitude, and I find the gradient pattern useful to
reproduce the altitude.
Date: 18 Mar 2004 09:47:12
Message: <4059b670@news.povray.org>
>>Hello !
Yes, and POV could add a lot to a Terragen texture. For example, a shiny
finish, and several different shapes for bumps. That's what gave me the
idea first.
> layering also.
Sure. But it seems that Terragen uses somehow the slopes simulated by
the normal perturbation as well. You can see that when you modify in
Terragen the amount of bumps in a parent layer.
> POV does.
I really don't know. But whithout bumps, Terragen terrains do look like
smooth height_fields in POV. Nevertheless, I tried to render the exact
same terrain without textures, atmosphere or ambient light, and I
noticed indeed a slight difference. The terrain does look smoother in
Terragen.
>>layer.
I believe you can take the altitude dependency into account when using
the slope pattern. The optionnal altitude keyword allows to add the
effect of a gradient into this pattern.
Thanks for your answer. I will keep trying...
Vincent
Date: 18 Mar 2004 15:45:43
Message: <405a0a77$1@news.povray.org>
"Vincent LE CHEVALIER" <lec### [at] ctiecpfr> wrote in message
> Hello !
> layer.
You could write a function for the texture to do this (6.7.11.15 in the
docs).  If you wanted access to the slope data, you could first draw the
heightfield from straight up using an orthogonal image and a b&w gradient in
the y-direction, and load this image as function image (6.7.11.16 in the
docs), and then check differences in the function at the exact point and
several points nearby to determine the change in altitude.  Combine the
dependancy on change in altitude with a dependancy on the altitude, and in
fact the x-z region where the point lies, and you've got great potential for
a vibrant image.
Sorry I can't give more specific info at the moment, if you have more
questions feel free to ask and I'll try as best I can to answer them a bit
later.
...Chambers
http://www.geocities.com/bdchambers79
Date: 19 Mar 2004 04:31:58
Message: <405abe0e$1@news.povray.org>
>>Hello !
>>layer.
> a vibrant image.
> later.
Yes, that's a good idea ! I'm not sure yet of how I will code this, but
anyway evaluating the slope myself is something I haven't thought of...
As for getting the altitude data in the form of a function, I guess I
can even use the same data as that of the heightfield :
#declare tgahf = function{pigment{image_map{tga "hf.tga" interpolate 2}
rotate x*90 }}
#declare altitudes =
function{(tgahf(x,y,z).red*255+tgahf(x,y,z).green)/256 * maxHeight}
Obviously, that's less precise than your method. But I think it's enough...
Well, I'm going to work on that. I'll post the results as soon as I get
something decent.
Thanks for your excellent suggestion !
Vincent
Date: 19 Mar 2004 12:39:34
Message: <405b3056@news.povray.org>
"Chambers" <bdc### [at] yahoocom> wrote in message
news:405a0a77$1@news.povray.org...
in
Doh!  It's already a heightfield, no need to redraw!
...Chambers
