I've only come up with limited information on what the final statistics
shown after a render really mean. Am I missing an obvious portion of the
documentation? I have found a few previous messages posted in regards to
this, yet I am still a bit puzzled.
After an eighteen-hour render of my image at 320x240 resolution, I am
interested in trying to determine where my inefficiency lies. My scene is
mostly full of cylinders... along with a small object made of
smooth_triangles that happens to be copied... er, a lot. I suspect this
could be the error of my ways, and perhaps I should replace them with some
more efficient primitives. However, I thought I was being responsible by
placing my triangles inside a union, and then simply referring to this
object repeatedly. Have I misunderstood previous discussions about
efficient triangle mesh handling?
I thought, perhaps, I could use the histogram output option to determine
where my image was slowing down. Unfortunately, the only information I
really got from the histogram was that the glass objects in my scene take
more time to render than the other objects. Alas, by removing the glass
objects, I do not see a huge increase of speed (as one might expect from
having a scene full of only cylinders... er, and some of those
aforementioned pesky smooth_triangles).
So, would someone be so kind as to give me a thorough explanation of my
statistics (as follow), or else point me to the right location so I might
read up on what they mean? Not a usual exciting question for the group, but
I'm at a loss of where to go to learn this. Blush.
Here's what I see:
Statistics for experimental_setup3.pov, Resolution 320 x 240
Pixels: 77120 Samples: 693400 Smpls/Pxl: 8.99
Rays: 719773 Saved: 3052 Max Level: 6/10
Ray->Shape Intersection Tests Succeeded Percentage
Box 407629001 9601576 2.36
Cone/Cylinder 1302284200 9226351 0.71
CSG Intersection 208771746 4865007 2.33
CSG Merge 919798 256294 27.86
CSG Union 3239336206 8895934 0.27
Plane 11367768 675690 5.94
Sphere 7357978 17042 0.23
Torus 294219586 1801162 0.61
Torus Bound 294219586 2160324 0.73
Triangle 157988919600 148549 0.00
Bounding Box 187611431 69542575 37.07
Light Buffer 8242761 3898242 47.29
Vista Buffer 5779806 4141312 71.65
Roots tested: 2160324 eliminated: 1003830
Calls to Noise: 23584421 Calls to DNoise: 24259518
Shadow Ray Tests: 23171879 Succeeded: 2160378
Reflected Rays: 14639 Total Internal: 208
Refracted Rays: 11734
Smallest Alloc: 25 bytes Largest: 24600
Peak memory used: 39956520 bytes
Time For Parse: 0 hours 0 minutes 1.0 seconds (1 seconds)
Time For Trace: 15 hours 8 minutes 27.0 seconds (54503 seconds)
Total Time: 15 hours 8 minutes 24.0 seconds (54504 seconds)
CPU time used: kernel 1.77 seconds, user 50408.08 seconds, total 50409.84
seconds
Render averaged 1.52 PPS over 76800 pixels
Alright, now, I understand what the first section seems to be telling me,
except for the 'Saved' value. Are we referring to saved rays? What did I
save them from doing?
Forgive me for being dense, but in the second section I see that some shapes
have much lower percentages than others. This is a ... Bad Thing? I
naively envision my scene only testing (and succeeding with) rays it really
'needs' to calculate, so the better the percentages, the fewer 'wasted' rays
were used? Thus, the better the percentages, the more efficient my scene
is? If this is true, then I appear to be horribly inefficient with my
Triangles.
The third category is even more puzzling. Is this simply for my
information, or can I somehow glean useful knowledge about whether my
objects are calling Noise vs. DNoise, and which should be a better thing.
The docs only mention DNoise in one place (6.7.12.6.4) and from my reading,
it's not that DNoise is any better/worse than Noise calls... just different.
Does the fact that DNoise returns a direction instead of just a value
somehow indicate that those calls were slower? Perhaps they really are
shown just for my information.
The fourth section seems to make more sense to me. If I have a lot of
reflected/refracted rays, my scene will take longer to render. What about
shadow ray tests vs. success? Again, just information, or can I use this to
my advantage?
I'm also puzzled by the Smallest and Largest memory allocation (the next
section). Er, call me obtuse, but if my largest memory allocation is 24KB,
how can my peak memory used be 40MB? Obviously I am woefully
misinterpreting these values. Blush.
Well, at least I understand the last few lines - I know it takes me a really
long time to render a scene that (I think) should be relatively simple.
Anyone care to take a stab at enlightening me? I would greatly appreciate
it.
- How
shapes
really
rays
> Triangles.
That caught my eye too. I don't look at statistics often, so those may be
typical percentages, but I dunno, they seem awfully low. Maybe you're doing
something that makes bounding boxes inefficient?
To determine if Noise is the cause of your slowdown, try rendering with
textures turned off (I believe there's a command line option that does this
easily; +Q? Search the docs for "quality"). I wouldn't worry about this too
much though.
You don't seem to have to many - and you said that taking out the glass
objects doesn't fix things anyway.
> What about
to
> my advantage?
Doesn't seem *that* bad, but shadow ray tests go in hand with what I said
about the other percentages.
24KB,
There can be (and usually are) multiple allocations as the program runs; the
sum of all of these allocations was 40MB. (Er, more precisely, 40MB was the
most allocated at any time, but it was made up of multiple smaller
allocations.)
So, anyway, the thing that worries me the most is the ray intersection
percentages. Are you using lots of intersections/differences, maybe? That,
among other things, can cause bounding boxes to be so large that they don't
help at all.
- Slime
[ http://www.slimeland.com/ ]
This line suggests to me that you're getting extremely bad bounds for
your triangle objects. Since there are 719773 rays, on average each ray
is being tested to see if it intersects 219498 but on average it only
hits 0.2 of them.
The fact that the rays miss most of the triangles suggests that the
triangles are very small, but the fact that many tests are being
performed suggests that the bounds are very large.
Could you possibly be doing something that prevents POV from
automatically bounding them efficiently, such as using them in a large
CSG intersection?
If you've still got the copy of the scene without the glass cylinders
you can get an idea of what the bounding slabs look like by running with
+UD on the command line. What you should be hoping to see is lots of
tight little boxes fitted around each of the small objects, and what you
don't want to see is one big box loosely fitted around the whole
structure.
Mike Williams
Gentleman of Leisure
> Triangles.
This part of the statistics should be pretty self-explanatory if you
know how a raytracer works. It tells you how many intersection tests
are done for each type of shape and how many of them hit the object.
Therefore a 'simple higher percentage = better' is of course not true
but a very low percentage indicates problems. You are horribly
inefficient with the triangles, the reason probably being you did not
use a mesh (no mesh is listed in your statistics).
The noise/dnoise calls are the number of calls to the basic functions of
procedural patterns. These numbers will be high when you use
complicated procedural textures or isosurfaces with noise based functions.
> my advantage?
The shadow ray stats are a bit like the shape stats above. If most of
the visible scene is in shadow (in respect to the used light sources)
most shadow ray tests will be successful. When you use area lights high
numbers also indicate they are taking a lot of time.
24k is the largest unit of memory allocated as a single piece. The
total amount of memory used by the scene is ~40 MB.
Last updated 07 Mar. 2004 _____./\/^>_*_<^\/\.______
Hash: SHA1
Like Christoph said, I believe that the problem comes from the fact
that you put your triangles in unions instead of meshes. Povray is able
to do a lot of optimizations on meshes that it can't do on unions, so if
you only have triangles, you're always much better off with meshes (of
course, if you have other objects in the union, you can always group
first your tringles in a mesh and then the other object in the union).
Jerome
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAWJpFqIYJdJhyixIRAsYWAJ9ZVAQ3N/ZjZp/1L70270Gk5hPS/ACfRXSg
uXz33xuor89OM0o8FUHTte8=
=T5XR
-----END PGP SIGNATURE-----
On Wed, 17 Mar 2004 02:00:27 -0500, "Slime" <fak### [at] email address>
>help at all.
Yep - as you and others pointed out, I rather screwed this up. So,
then, perhaps (well, er, obviously) I don't understand how bounding
boxes work:
Let's say I have two long cylinders perpendicular to one another - a
'+' shape of some sort.
Separately, the bounding boxes would be tight around each cylinder.
If I place them in a union together, I've got one large bounding box,
which I suppose could be less efficient than two tight bounding boxes
done separately. Er, am I right so far?
Now, how do I manually make my bounding boxes any better than a single
box surrounding my odd-shaped CSG? I always (incorrectly?) pictured a
large CSG bounding box to be the 'initial' test. If a ray hits it,
then all the individual bounding boxes inside the CSG would be
checked.
Can I 'turn off' my CSG bounding box, and just let the multiple (yet
tight) boxes suffice?
- How
On Wed, 17 Mar 2004 08:46:33 +0000, Mike Williams
>CSG intersection?
Yep, you're absolutely right. Thanks for pointing this out. See my
questions, however, in my reply to Slime.
- How
On Wed, 17 Mar 2004 09:48:38 +0100, Christoph Hormann
Ack, I screwed up. I added my triangles into a union of other objects
rather than first using a mesh. Blush.
Now, please be patient with me, Christoph, but I'm still not sure I
understand your above explanation. If the statistics are informing me
of how many intersections tests were performed, and of those how many
hit my object... then why *doesn't* that mean 'higher percentage =
better'? If 100 tests are performed inside a given bounding box, and
the bounding box perfectly matched my object in size and shape...
shouldn't I get a hit percentage of 100%?
You mention that low percentages indicate potential problems. Er, how
low is 'too low'? I realize there isn't a simple answer to this, but
is there a broad rule-of-thumb I could use to help me start paying
better attention?
- How
On Wed, 17 Mar 2004 19:34:45 +0100, "Jérôme M. Berger"
Yep, this is exactly what I did wrong. Somehow, I convinced myself
that they aaaall needed to go in the same union. Blush. Thanks,
Jérôme!
- How
>boxes work:
Not for *unions*. For unions and merges it's possible to bound
intelligently, and POV does so. It's possible to see the effect by
rendering a simple pair of crossed cylinders with the switches
+MB0 +UD
camera {location <0,0,-10> look_at <0,0,0> angle 20}
light_source {<-30, 100, -30> color rgb 1}
union {
cylinder {-x,x,0.01}
cylinder {-y,y,0.01}
pigment {rgb 1}
The +MB0 sets the bounding threshold to zero. POV would normally switch
bounding off on a scene with so few objects. +UD tells POV to display
the outlines of the Vista Buffers before tracing. Vista Buffers are
derived from the bounding slabs and (in most cases) give you a good 2D
representation of where the 3D bounding slabs are.
You'll see that there are two red rectangles which fit the cylinders
tightly. And you'll also see this in the stats (this is for a 320*240 no
AA rendering), showing that only a small number of cylinder tests were
performed.
Cone/Cylinder 2035 1162 57.10
If you render a scene with two separate cylinders you get exactly the
same red rectangles and exactly the same stats.
With intersections and differences, however, there can be situations
where POVs automatic bounding can't create such tight fits.
For example, see <http://www.econym.demon.co.uk/holetut/index.htm>.
A box with 1600 cylindrical holes in it took 26 minutes 25 seconds to
render, but after rewriting the scene so that POV could bound it better
it took 8 seconds.
Mike Williams
On Thu, 18 Mar 2004 03:54:47 +0000, Mike Williams
> +MB0 +UD
Ah, I see. Thanks for the example. So, unions are able to be 'bound
intelligently'.
Yes, and this is where my problem lies. I've got a lot of cylinders
being differenced with other cylinders.
>it took 8 seconds.
Aha! So, let me see if I've got this straight. I place a large
number of objects in a CSG Union, and I should see very little
difference in speed. However, if I place a large number of objects in
a CSG difference, my bounding boxes are not calculated very well, and
the render time may be quite poor.
Now, on your wonderful web page, you showed how to overcome this
problem - you broke your larger CSG difference into a bunch of small
CSG differences. As you point out, the best you can do is to have
1600 slabs, each with only a single CSG difference in them.
Thanks so much, Mike! And the rest of the responses I've recieved,
too -- this has been quite enlightening. Already, now that I've
corrected the whole 'union-of-triangles vs. mesh' fiasco, I've
decreased my render time dramatically.
I'll try applying this information as well!
- How
First of all the bounding box will of course never perfectly match the
object. Therefore if you have 100% hits this usually means the object
completely fills the view in which case it would be faster not to use
bounding for this object at all.
> better attention?
No, it depends on the type of object and how it is placed. Imagine for
example a torus with a very low minor radius - you will always get a low
hit rate for it.
On Thu, 18 Mar 2004 09:35:50 -0800, Darren New <dne### [at] san rr com>
wrote:
>As the manual explains {X inverted} is object X with the inside and
>outside reversed - a "negative" X. difference{X,Y} is the same as
>intersection{X, Y inverted}. So, by itself, Y fills your entire scene,
>other than where the cylinder or whatever actually is. *That* is what
>you have to bound for efficiency. In an intersection, POV knows that it
>can bound Y inverted by X. But if X is a union that's unnecessarily big,
>it can't really tell where Y needs to get cut off. POV can't
>automatically tell that in
> intersection ( union (A,B,C), X inverted )
>X really only affects C, So if A fills your whole screen, and X really
>only chops part of C out, rays hitting A still have to check against X.
Yes, I see it, now. So, using your example above:
intersection( union(A, B, C), X inverted)
How would I optimize the bounding boxes in this situation? The
problem lies with X's bounding box, and I need to shrink it down
considerably. Right?
>Maybe that helps? Or have I explained something wrong?
I think this helps greatly. Thanks!
- How
"How Camp" <kro### [at] hotmail com> wrote in message
news:u5qj50tm6ptd8vcvpuih4e0mk3afpleis1@4ax.com...
If X only affects C, wouldn't the following work?
union( A, B, intersection(C, ~X) )
(Using ~ for inversion)
...Chambers
http://www.geocities.com/bdchambers79
On Thu, 18 Mar 2004 13:02:46 -0800, Darren New <dne### [at] san rr com>
wrote:
>If the cylinder X only intersects C, then you need to have
> union (A, B, intersection (C, X inverted))
>aka
> union (A, B, difference(C, X))
>Then POV is smart enough to know that the bounding box for
> difference(C,X)
>can't be bigger than the bounding box for C.
Got it. Thanks, all, for finally getting this into me. I'll continue
to do some tests, here, but I've already seen clear evidence of this.
- How
On Thu, 18 Mar 2004 20:48:39 -0600, How Camp <kro### [at] hotmail com>
Well, this will come as no shock to all of you who've been so helpful
in this thread, but here's the results of all my playing around:
Pixels: 77120 Samples: 693144 Smpls/Pxl: 8.99
Rays: 718613 Saved: 2938 Max Level: 6/10
Box 50058173 24556324 49.06
Cone/Cylinder 177506624 7692921 4.33
CSG Intersection 37497796 5027965 13.41
CSG Merge 163 4 2.45
CSG Union 99867389 5542401 5.55
Mesh 552652924 76895 0.01
Plane 25780836 1600506 6.21
Sphere 163 0 0.00
Torus 12654305 1029520 8.14
Torus Bound 12654305 1151039 9.10
Bounding Object 17790727 12361787 69.48
Bounding Box 723628698 63750693 8.81
Light Buffer 5151394 3783732 73.45
Vista Buffer 8099377 6643164 82.02
Roots tested: 1151039 eliminated: 788253
Calls to Noise: 23582324 Calls to DNoise: 24198190
Shadow Ray Tests: 24593543 Succeeded: 2870814
Reflected Rays: 14186 Total Internal: 206
Refracted Rays: 11283
Radiosity samples calculated: 41753 (6.33 percent)
Radiosity samples reused: 617822
Peak memory used: 11611887 bytes
Time For Trace: 0 hours 5 minutes 35.0 seconds (335 seconds)
Total Time: 0 hours 5 minutes 36.0 seconds (336 seconds)
CPU time used: kernel 0.80 seconds, user 279.72 seconds, total 280.52
seconds
Render averaged 273.78 PPS over 76800 pixels
Quite a bit better than 18hrs! Thanks, again.
- How
On Sat, 20 Mar 2004 15:12:37 -0800, Darren New <dne### [at] san rr com>
wrote:
>Congrats! So post the image, already! ;-)
Hehe, well it's not terribly exciting... unless you're really really
interested in charge-transfer collisions. Let me get the exciting
part finished, and I'll post.
>Looks like it's still doing a bunch of compares on the mesh without
>hitting it. Not sure if you could easily improve that, or whether it's
>worth the effort to.
Yeah, I noticed that, too. I may rethink my use of these meshes in
the first place - they really don't add much to the scene, and the
detail is pretty much lost. I might try replacing them with some sort
of rough primitive shape and see how much of a difference it makes.
- How
