Hi Darren. There can be many different ways to do one single thing in
POV. You might want to look for these items in the POV-Ray documentation:
warp: repeat, offset
crackle: solid
pigment_map
Also, here's one way to do it using the brick pattern. Good luck.
plane{y,0
pigment{
pigment_pattern{brick}
pigment_map{
[.5 bumps]
[.5 crackle]
Darren New wrote:
> Is it possible to set up bricks with each brick being a slightly
> different color?
<snip>
> Obviously, I haven't been doing this long enough to understand the
> proper approach. I'm willing to work at it, but an idea of the proper
> approach to take would be appriciated. Thanks!
"Darren New" <dne### [at] san rr com> wrote in message
news:40525b34@news.povray.org...
> What I'm really trying for is something like a mortared
stone wall with
> slightly different stones in it, but I'll settle for the
above (and then
> maybe add turbulence or something).
There us an excellent tutorial on creating realistic brick
patterns by Jeff Lee at
http://www.shipbrook.com/jeff/raytrace/bricks.html
If you want something different, you can always build the
brinks individually. Gilles Tran ahs a couple of macros at
http://www.oyonale.com/ressources/english/sources02.htm that
could be useful.
Cheers,
Ian
