POV-Ray : Newsgroups : povray.general : Render a Mask ? Server Time
21 Jul 2025 17:30:38 EDT (-0400)
  Render a Mask ? (Message 1 to 2 of 2)
Subject: Render a Mask ?
Date: 29 Feb 2004 22:26:12
Message: <4042ad54@news.povray.org>
I'm rendering something as a preview for building it.  So, I
plan to combine it with a photograph of my back yard and
compose the ray-traced gazebo into it.  I can get the angles
and perspective and shadow angle to match OK, just by taking
enough measurements and keying off of a flat template of the
octogon shape in the real photo.
My question is: wasn't there talk of some feature, a long
time ago, about rendering a "mask" from a scene?  Basically,
I could use that to punch out the location in the photo.  I
get pretty close by using a constant background color and
selecting that in PhotoShop. But I seem to remember talk
about generating a mask layer directly.
The interesting part, that I need some help with, is dealing
with the shadows.  Assuming I put my object into a scene
that has props for the real objects the shadows will fall
on, how can I copy those in Photoshop to darken the photo?
--John
Subject: Re: Render a Mask ?
Date: 29 Feb 2004 22:59:55
Message: <4042b53b$1@news.povray.org>
Well you can use the +ua command line switch to get pov to output an alpha
channel (so that your background will be transparent).
What I would suggest is render a second image with all the textures set to pure
white, and all the finishes set to have brilliance 0. This should mean you end
up with a flat white image where only the areas in shadow are darker (it won't
cope well with coloured lights but you can probably get round that with some
tweaking in photoshop).
Then, put that into photoshop and make it multiply the colours in your
photograph (it has to multiply because that's what shadows do).
That should get the effect you're after.
Tek
www.evilsuperbrain.com
