POV-Ray : Newsgroups : povray.general : Scope of identifiers in nested Macros Server Time
2 Nov 2026 01:04:36 EST (-0500)
  Scope of identifiers in nested Macros (Message 1 to 20 of 20)
Subject: Scope of identifiers in nested Macros
Date: 1 Jan 2004 15:08:46
Message: <3ff47e4e@news.povray.org>
When rendering the following code:
<POV>
#macro M1(Param)
     #local Param = Param - 1;
     #debug concat("Param = ",str(Param,0,0),"\n")
#macro M2(Param)
     #local a = 0;
     #while (a<10)
          M1(Param)
         #local a = a + 1;
M2(100)
</POV>
I would expect the line "Param = 99" being printed 10 times. Instead,
the output is
<Output>
Param = 99
Param = 98
Param = 97
Param = 96
Param = 95
Param = 94
Param = 93
Param = 92
Param = 91
Param = 90
</Output>
I think this does not match the behaviour described in the documentation
in section "6.2.2.3 Identifier Name Collisions".
Any Comments?
Happy new year everybody
Florian
Subject: Re: Scope of identifiers in nested Macros
Date: 1 Jan 2004 15:20:15
Message: <3ff480ff@news.povray.org>
Florian Brucker <tor### [at] torfboldcom> wrote:
>           M1(Param)
  I didn't test, but doing "M1((Param))" should do what you expect.
  The behaviour of the parser is interesting with regard to #local and
macro parameters. AFAIK if you give an identifier directly as a macro
parameter, any #local inside that macro will modify the original
identifier. If you give a *value* (instead if an identifier) as parameter,
the macro will get a copy of that value and will only modify this temporary
copy.
  Putting the identifier into parentheses will make it an expression
which resulting value will be given as parameter instead of the identifier
itself. That is, the difference between "Param" and "(Param)" is that
the first is an identifier (which is then modified in the macro) while
the second is a float expression (which result is the value of Param),
which value is temporarily copied to the macro.
  The difference is similar to doing "void foo(int& i)" or "void foo(int i)"
in C++, but the syntactical difference is more subtle (because you decide
whether the parameter is passed by reference or by value at the calling
place instead of the macro definition).
  If you want to be sure that your macro will not modify an identifier
given as parameter, you should make an explicit copy of it inside your
macro.
  I think this should be explained in the documentation if it's not already.
Date: 1 Jan 2004 15:57:55
Message: <3ff489d3$1@news.povray.org>
IMHO an implementation like the documentation is described would be
better that updating the documentation. I think the current behaviour is
not at all intuitive and can create errors which are very hard to spot.
Although I have to admit that I have never encountered this error before :)
BTW, any chance the POV-Syntax will be extended with a include-file-wide
identifier scope? Something like (In an include file):
#public SomeValue = 10; //Global scope, visible to all files & macros
#private AnotherOne = 1; //Include-File scope, only visible to the
			 //Include file and macros within the file
#local LastButNotLeast = 5; //Macro scope, visible only to the macro it
			    //is declared in
This way one would not have to carry along prefixes in include files to
prevent global scope identifiers from being overwritten.
Florian
Date: 1 Jan 2004 16:29:52
Message: <3ff49150@news.povray.org>
  But the current behaviour can be useful sometimes.
  If you make a #local in an include file, its scope will be only inside
that file.
Date: 1 Jan 2004 17:56:12
Message: <3ff4a58c$1@news.povray.org>
Do you mind to give an example?
> that file.
But you can't use it properly in macros:
<test.inc>
#local ID = 2;
#macro Test()
     #debug str(ID,0,0)
</test.inc>
<main.pov>
#include "test.inc"
Test()
</main.pov>
Render main.pov and see :)
Florian
Date: 2 Jan 2004 13:05:36
Message: <cjameshuff-A556CE.13053902012004@netplex.aussie.org>
In article <3ff489d3$1@news.povray.org>,
It is also very useful. Look at the Isect() and Extents() macros in
shapes.inc, which use this feature to return multiple values.
Things could be clarified quite a bit, though. This is what I would do:
#declare always declares a global variable. Actually, deprecate #declare
and use #global instead. #local always declares a local variable.
If either #declare or #local are used with an existing variable, a
warning is emitted. Existing variables are modified with a #set or #
directive, which require an existing variable:
#local J = 0;
#while(J < 10)
    #set J = J + 1;
or
    #J = J + 1;
#macro Foo(Param)
    #local Param = Param + 1;
Would produce a warning and replace the parameter Param with the local
version, leaving the original unaffected.
#macro Foo(Param)
    #declare Param = Param + 1;
Would only produce a warning if a global variable named Param already
existed. It would create that global variable and leave the parameter
unaffected.
#macro Foo(Param)
    #set Param = Param + 1;
Would modify the parameter itself.
This also avoids odd typo errors. This code would loop infinitely:
#local I = 0;
#while(I < 10)
    #local l = I + 1;
This version would give an immediate error:
#local I = 0;
#while(I < 10)
    #set l = I + 1;
The #set keyword is part of the MegaPOV patch collection, but the rest
of it would break backwards compatibility too much to be included.
Unless a new keyword were used for declaring local variables...hmm. How
does this sound?
#declare, #local: obsolete, deprecated, but unchanged in operation for
backwards compatibility.
#global, #def or #define, #set: as described above, with #def declaring
a local variable.
Well, I just wanted to say that the pass by reference is actually a
useful feature...guess I got carried away.
This already exists: variables defined as #local outside a macro are
local to the include file.
http://tag.povray.org/
Date: 2 Jan 2004 23:05:12
Message: <3ff63f78@news.povray.org>
> a local variable.
  How would #def be different from #local?
  What's wrong with #local? It's certainly a whole lot more descriptive
than #def.
  I think that a lot of the confusion-causing problems in the current
macro syntax would be avoided if you could specify if the macro takes
its parameter by value (which would be the default in the current syntax)
or by reference (with a special symbol or keyword).
  If the macro says that the parameter is taken by value then POV-Ray
will always make a temporary copy of the parameter. If it says that it
is taken by reference then it would work as it works currently (that is,
if an identifier was given (and not an expression), then any assignment
will be made to the original identifier).
  Example (the & syntax is just a proposition inspired by C++, not
to be taken too seriously):
#macro Foo(Param1, &Param2)
  #set Param1 += 1; // Yes, I want these operators as well :)
  #set Param2 += 2;
  do_something_with_the_params
#local A = 5;
#local B = 5;
Foo(A, B)
// At this point A will be 5, but B will be 7
Date: 3 Jan 2004 06:49:22
Message: <3ff6ac42$1@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
>     #J = J + 1;
I like this syntax for manipulating already declared variables.  It would be
easy to add to the parser (tokenize.cpp) as well...
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Jan 2004 07:20:13
Message: <Xns946587AD2C2EEseed7@netplex.aussie.org>
in news:3ff6ac42$1@news.povray.org Thorsten Froehlich wrote:
>>     #J = J + 1;
Why not throw the # away completely?
J = 0;
J = J + 1;
Everything is local, unless it is declared global,
#global J = "global"
Ingo
Date: 3 Jan 2004 08:23:50
Message: <3ff6c266@news.povray.org>
See my answer to Warp for what I mean.
Florian
Date: 3 Jan 2004 08:43:53
Message: <3ff6c719$1@news.povray.org>
In article <Xns### [at] netplexaussieorg> , ingo
Because then you could no longer distinguish parse-time processing from
render-time processing, which would close the door for many possible future
features.  And it would make parsing infinitly more complex (from a runtime
complexity perspective).
    Thorsten
Date: 3 Jan 2004 08:59:07
Message: <Xns94659871D5E46seed7@netplex.aussie.org>
> render-time processing, [...]
I do not understand, probably because I don't know what both are.
Parse-time processing, I guess, is all the stuff that has to done to get
the objects into memory. That would include doing the loops and macro's
and stuff.
Render-time processing, besides of shooting the rays I can only think of
functions.
Ingo
Date: 3 Jan 2004 09:57:58
Message: <3ff6d876$1@news.povray.org>
It is much like the difference between functions and declares.
    Thorsten
Date: 3 Jan 2004 10:02:05
Message: <cq1jc1-e5f.ln1@triton.imagico.de>
Not to mention the extreme obfuscation possible:
sphere {
   J J = J + K = 1 - J; 1; K
The version you suggested is only slightly better:
sphere {
   J #J = J + #K = 1 - J; 1; K
I'd really suggest to have a keyword (like #set) for this purpose.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 3 Jan 2004 10:16:33
Message: <cjameshuff-6EBAAF.10163203012004@news.povray.org>
In article <3ff63f78@news.povray.org>, Warp <war### [at] tagpovrayorg>
> > a local variable.
It would give a warning or error when used on an existing variable.
> than #def.
And it's used. Changing it would break backwards compatibility.
I don't like this idea. One thing about C++ that I've never liked was
the way you couldn't tell by reading the call whether you were passing
by reference or by value. If something like this were added, I would
prefer an explicit reference, something closer in usage (though not
syntax) to pointers.
Date: 3 Jan 2004 10:35:58
Message: <cjameshuff-D324DF.10355703012004@netplex.aussie.org>
In article <Xns### [at] netplexaussieorg>,
 ingo <ing### [at] tagpovrayorg> wrote:
> >>     #J = J + 1;
> J = 0;
> J = J + 1;
Ew. There's no way of telling a declaration apart from an assignment,
unless it's global. You just completely broke the main benefits of my
suggested method. Look at this code:
J = 0;
#while(J < 10)
    j = J + 1;
That's an infinite loop. This isn't, it's an error:
#def J = 0;
#while(J < 10)
    #j = J + 1;
This would also be harder to parse, and would break consistency with the
rest of the language. I'd actually prefer something like this:
def J = 0;
while(J < 10) {
    J = J + 1;
or at least:
def J = 0;
while(J < 10)
    J = J + 1;
end
But you'd have to redesign the language and completely redo the parser.
What I suggested only requires 3 small additions.
Date: 3 Jan 2004 12:11:21
Message: <cjameshuff-E8F7CE.12111903012004@netplex.aussie.org>
In article <3ff4a58c$1@news.povray.org>,
The Extents() and Isect() macros, which return multiple values through
their parameters.
> > that file.
You're talking about an entirely different kind of scope here. It would
be useful in some cases, but I think what you want would be done better
with object-oriented programming structures.
Date: 3 Jan 2004 18:31:01
Message: <3ff750b5@news.povray.org>
  Wasn't #set for that? I'm confused.
> > than #def.
  I don't understand what you are saying.
  Currently you have only one option: By reference. And this is causing
confusion.
Date: 3 Jan 2004 18:45:01
Message: <cjameshuff-E01717.18450003012004@netplex.aussie.org>
In article <3ff750b5@news.povray.org>, Warp <war### [at] tagpovrayorg>
#set or #IDENTIFIER would prevent you from accidentally defining a new
variable...it would give an error if you tried to modify a nonexistent
variable.
#def would prevent you from accidentally redefining an existing
variable. It would give an error or warning if the new variable would
replace the existing one.
> > > than #def.
Well, the warning wouldn't break backwards compatibility, but would slow
down the parsing of any old scene and drown out more legitimate
warnings. The error would break any old scene. Or maybe it could be made
to depend on the version directive...
> confusion.
Not really. It surprised someone, but it's certainly not a common source
of confusion, and it only happens when someone's doing something a
little strange anyway (modifying a parameter). It's easy to write the
macro to work with a local version, and that's what should be done if it
isn't returning something through the parameter.
Date: 3 Jan 2004 19:36:28
Message: <Xns9466105CACDBBseed7@netplex.aussie.org>
in news:cja### [at] netplexaussieorg Christopher
> suggested method.
Sorry Chris,
I more or less jumped in the middle of the thread by somehowe missing the
middle section of it. I'll try to pay more attention ... ;)
Ingo
