POV-Ray : Newsgroups : povray.general : color problem Server Time
22 Jul 2025 08:33:36 EDT (-0400)
  color problem (Message 1 to 6 of 6)
Subject: color problem
Date: 16 Dec 2003 11:51:25
Message: <3fdf380d$1@news.povray.org>
According to the docs (6.1.5.5), the following should be okay, but I get an
error...
#declare PigTest = pigment{color <1,1,0> + blue 1}
Any ideas?
Assuming I've done something stupid, will the correct syntax allow me to add a
filter component to a pigment map?
e.g.
#declare MyPig =
pigment{
    bozo
    pigment_map{
        [0 rgb<1,1,0>]
        [1 rgb<1,0,1>]
#declare MyPig2=pigment{MyPig filter 0.5}
#macro A(V,B,C,R)#while(B-256)#if(V-128/B>=0)sphere{0,.5translate<C-4R-1,9>
pigment{rgb<1-C/8R/2C/8>}}#local V=V-128/B;#end#local B=B*2;#local C=C+1;#
end#end A(234,1,0,2)A(85,1,0,1)A(81,1,0,0)light_source{-5 1}//Tom Melly
Subject: Re: color problem
Date: 16 Dec 2003 15:00:43
Message: <8o9H2CApQ23$EwYB@econym.demon.co.uk>
>error...
>Any ideas?
But you can do things like
#declare Blue = <0,0,1>;
#declare PigTest = pigment{color <1,1,0> + Blue}
>e.g.
>#declare MyPig =
>pigment{
>    bozo
>    pigment_map{
>        [0 rgb<1,1,0>]
>        [1 rgb<1,0,1>]
You can add a colour to a colour, like
#declare HalfFilter = <0,0,0,0.5>;
#declare PigTest = pigment{color <1,1,0> + HalfFilter}
But to add a colour to a more complicated pigment, I think you have to
use a more complicated syntax, like:
#declare Clear = rgbf 1;
  average pigment_map {
    [1.0 MyPig]
    [1.0 Clear]
Mike Williams
Gentleman of Leisure
Date: 16 Dec 2003 15:41:05
Message: <3fdf6de1$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3fdf380d$1@news.povray.org...
an
> error...
Interesting... yes, I thought that would have been valid. Can still use z or
<0,0,1> in place of blue 1. Like + z*0.5 if you only wanted half blue.
Curious thing though that color keywords aren't able to be used and yet show
it to be valid in the Doc. Something to check into.
add a
Seems like Mike Williams has a good solution anyway. I think once you are
dealing with a pattern it isn't going to accept color keywords directly.
Bob H.
Date: 16 Dec 2003 16:10:19
Message: <3fdf74bb@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:8o9H2CApQ23$EwYB@econym.demon.co.uk...
<snip>
Thanks Mike.
Date: 16 Dec 2003 16:11:32
Message: <3fdf7504$1@news.povray.org>
"Hughes, B." <omn### [at] charternet> wrote in message
news:3fdf6de1$1@news.povray.org...
I'll post in general to ask whether it's a bug in docs or a bug in pov.
Date: 17 Dec 2003 07:17:43
Message: <cjameshuff-A9C606.07174517122003@netplex.aussie.org>
In article <3fdf380d$1@news.povray.org>,
> error...
"blue" isn't a value you can add to a color vector, it is a keyword
specifying the blue color channel, in the same class as "rgb" or "rgbft".
No. However, you can use the average pattern to combine the old pigment
with a new, transparent one...just make sure you double the colors in
both pigments first.
http://tag.povray.org/
