POV-Ray : Newsgroups : povray.general : Heightfield applied to mesh Server Time
15 Aug 2025 21:14:25 EDT (-0400)
  Heightfield applied to mesh (Message 1 to 7 of 7)
Subject: Heightfield applied to mesh
Date: 12 Dec 2003 15:08:37
Message: <3fda2045$1@news.povray.org>
Howdy,
I was wondering if there were any macros or techniques out there to wrap a
heightfield to a mesh.  I've got a model I'm exporting to POV-Ray and have a
bitmap decal I'd like raised on the surface.  Any ideas?
Skip
Subject: Re: Heightfield applied to mesh
Date: 12 Dec 2003 16:04:14
Message: <3fda2d4e@news.povray.org>
To my knowledge there are no POV-macros available to do the job on any kind
of mesh. It's relative easy to code one, provided you have - or can
calculate - the surface normals.
Bear in mind though, that your mesh needs to be very dense for "surface
displacement" to look good. This needs a lot of memory - sometimes wasted
memory, if your bitmap/pattern is not very bumpy then it will just waste
triangles.
That is why you will usually benefit A LOT from doing a "triangle
decimation" after the displacement has taken place. That means, redundant
triangles are removed and the resulting holes are nicely triangulated.
Currently the most efficient way to do all this, in my opinion, is a
commercial modeller like 3dsMAX. If you don't have access to that program,
it's going to be more complicated. You can use 3 small applications:
1) Poseray OBJ 2 POV converter (Freeware, and it has some kind of surface
displacement algoritm. I think your mesh needs UV vectors for this to work)
2) Wizup Optimiser (Free version only works with small meshes .. can do
triangle decimation)
3) A multi-converter will be handy. The "Wizup Optimiser" only works in VRML
format. I haven't found a freeware converter for this that *work*.
Hugo
Date: 12 Dec 2003 16:41:30
Message: <3fda360a$1@news.povray.org>
Thanks for the detailed explanation, Hugo.  Like you said, I'm going to try
and go through the modelor.
Skip
Date: 12 Dec 2003 17:33:56
Message: <3fda4254@news.povray.org>
"Hugo Asm" <hua### [at] post3teledk> wrote in message
news:3fda2d4e@news.povray.org...
Is this not the function of Warp's mesh compressor?
 -Shay
Date: 12 Dec 2003 19:23:26
Message: <3fda5bfe$1@news.povray.org>
Oh yea, now you mention it.. It has some features like this.. But I never
tried.
Hugo
Date: 12 Dec 2003 19:46:44
Message: <cjameshuff-699B69.19422312122003@netplex.aussie.org>
In article <3fda2d4e@news.povray.org>, "Hugo Asm" <hua### [at] post3teledk>
Unfortunately, it will be quite slow on high-res meshes. And you need
the vertex locations as well as normals, of course. And it just won't
work with some meshes...think of a mesh box, for example. Displacing
each face along its normal will completely destroy the edges...you will
end up with six displaced squares roughly aligned with the sides of a
box.
> triangles.
It is also possible to write a displacement algorithm that is smart
enough to subdivide areas with highly detailed or large amounts of
displacement.
http://tag.povray.org/
Date: 13 Dec 2003 15:05:18
Message: <3fdb70fe@news.povray.org>
  The compressor does not modify the number of triangles in the mesh.
It simply converts it from one format to another.
  (The name is more or less historical, even though I think a pcm file
will still be somewhat smaller than a mesh2 file...)
