Subject: Beta test version of the new mesh compressor program
Date: 20 Nov 2003 18:37:50
Message: <3fbd504e@news.povray.org>
Finally, after so many years of laziness, I decided to enhance the
mesh compressor program to the POV-Ray 3.5 era. That is, it should
now have full support for mesh2's (reading and writing), as well
as uv-mapping in regular meshes.
Chris Colefax is still working on the PCM macros and they are not
yet available, so you will only be able to test pov-pov and pov-pcm-pov
conversion. However, I think that most bugs should be possible to find
this way.
Only Windows-version of the beta, sorry.
(Oh dear, I would have never thought I would ever say something like
that, but... I'm not quite willing to publish the source before all the
most obvious bugs are fixed... Rest assured, however, that the
command-line version is extremely system-independent. :) )
You can download the Windows beta version here:
http://www.cs.tut.fi/~warp/WinMeshcomp30_beta.zip
(In case you don't have the slightest idea what this is all about, see
http://www.geocities.com/ccolefax/pcm.html )
Subject: Re: Beta test version of the new mesh compressor program
Date: 20 Nov 2003 19:12:57
Message: <3fbd5889$1@news.povray.org>
Yee hah! Very cool indeed.
Date: 21 Nov 2003 06:11:02
Message: <3fbdf2c6@news.povray.org>
"Warp" <war### [at] tag povray org> wrote in message news:3fbd504e@news.povray.org...
Excuses, excuses...
http://tinyurl.com/vykx
On Fri, 21 Nov 2003 11:11:01 -0000, "Tom Melly" <tom### [at] tomandlu co uk> wrote:
LOL
Regards
Date: 21 Nov 2003 17:23:46
Message: <3fbe9072@news.povray.org>
> Excuses, excuses...
Oh my goodness... that's hilarious. I want one.
Jonathan.
Date: 6 Dec 2003 08:37:20
Message: <3fd1db90@news.povray.org>
Apparently the program is either completely bugless, or doesn't really
interest anyone...
I hope it's the former. ;)
Date: 6 Dec 2003 09:29:17
Message: <3fd1e7bd$1@news.povray.org>
> interest anyone...
It worked nicely as far as I was able to make use of it. Unfortunately
I think I need to have the color carry through for my application
(hair). So, so far I am just using the plain mesh. But the mesh2 would
give me more memory to work with so the jury is still out on which way I
will comprimise as I increase the number of triangles.
I don't suppose .obj to pcm would be possible?
The thing is that Greg Johnson wrote some interesting macros adapting
the pcm hair macros to give Maya options that might be interesting to
try. But any modelling I do is exported in .obj among others.
Crossroads works just fine for this so it's hardly a big deal, but it
would shorten the workflow.
-Jim
Date: 6 Dec 2003 18:19:47
Message: <3fd26413@news.povray.org>
Currently you will need to convert the .obj file to a mesh or mesh2
with some converter and then convert it to pcm with my program.
I don't have the slightest idea what kind of format .obj is, but if
it's simple enough, I might add support for it...
Date: 6 Dec 2003 19:03:36
Message: <3fd26e58$1@news.povray.org>
I don't think so, you don't read Mesh2 just Mesh. That is why the need
for Crossroads. It can read .obj and output Mesh.
I think it is originally a Alias/Wavefront format. I actually wondered
if Mesh2 was modelled after .obj in part. The prob with .obj is that it
comes in a couple of flavors I think. Something about different line
endings, newline or carriage return. Since I first tried mesh modelling
in a Maya course it was the format I got used to and have confidence in.
But it is really a matter of which button to push. Personally I like
to produce mesh models with Wings3D which exports in a number of formats.
Anyway, as I said there is a way to manage the situation. Support for
.obj or other commom mesh format would give your app more of a
one-stop-shopping place in the workflow. But the reward would have to
come from the doing I expect.
Btw my present endeavor is trying to apply hair to a mesh such that the
direction it lies in can be controlled more closely. Have you ever
applied youself to that problem?
In article <3fd26413@news.povray.org>, Warp <war### [at] tag povray org>
http://astronomy.swin.edu.au/~pbourke/geomformats/obj/
(more formats at http://astronomy.swin.edu.au/~pbourke/geomformats/)
http://pipin.tmd.ns.ac.yu/extra/fileformat/3d/index.htm
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
Date: 7 Dec 2003 07:54:04
Message: <3fd322ec@news.povray.org>
Then there's a serious bug in the program. I am able to read mesh2 (with
uv-mapping and textures) ok.
Please make a proper bug report.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Date: 7 Dec 2003 09:52:16
Message: <3fd33ea0$1@news.povray.org>
Now I'm confused.
On the interface the selections for input include:
1. POV-Ray file with triangle meshes
2. POV-Ray file with cubic patches
3. PCM file
The selections for output include:
1. PCM file
2. POV-Ray file
3. UV-Pov mesh2
I did try selection #1 with "Ignore keywork mesh" checked
but got:
"no objects found"
Forgive me, I don't know how to do that
Date: 7 Dec 2003 12:04:35
Message: <3fd35da2@news.povray.org>
> Now I'm confused.
Try reading the first post in this thread.
Date: 7 Dec 2003 15:30:12
Message: <3fd38dd4$1@news.povray.org>
Okay, a bit cryptic but I think I gotcha.
To be able to read it,
it matters which utility generates the mesh/mesh2.
Here is what I was able to test:
Can the mesh be read?
If generated by PoseRay v.0.1
Mesh - No
Mesh2 - No
If generated by CrossRoads v1
Mesh - Yes
Mesh2 - N/A
If generated by Win3D v4.3
Mesh - N/A
Mesh2 - No
If generated by MeshComp v3
Mesh - Yes
Mesh2 - Yes
If generated by POV-Ray v3.5
Mesh - Yes
Mesh2 - N/A
Not sure if it is a bug, but it means to me that
the only way I can get from a commercial format, such
as .obj, to PCM is via generating plain mesh in CrossRoads.
Date: 7 Dec 2003 20:41:46
Message: <3fd3d6da@news.povray.org>
> Mesh2 - No
> Mesh2 - No
Can you post a small example of those which the compressor can't read?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
Date: 7 Dec 2003 22:31:21
Message: <3fd3f089$1@news.povray.org>
>>Mesh2 - No
>>Mesh2 - No
In p.b.s-f
Date: 8 Dec 2003 08:24:28
Message: <3fd47b8c@news.povray.org>
> In p.b.s-f
This is exactly what I was looking for when I made the beta release.
There indeed is a bug in the program, and a rather simple one (or perhaps
more precisely a memory lapse): I forgot to make the parser to take
comments into account.
For instance "mesh2 // comment" causes it to choke because it doesn't
skip the comment.
I'll have to fix that.
I fixed the problem with comments. Please test it.
http://www.cs.tut.fi/~warp/WinMeshcomp30_beta2.zip
Date: 9 Dec 2003 15:43:40
Message: <3fd633fc@news.povray.org>
Have you tried with the beta2 version of the program yet?
Date: 9 Dec 2003 16:14:08
Message: <3fd63b20$1@news.povray.org>
Nothing too extensive. I quickly ran it against about a dozen mesh2
files I had laying around from both poseray and 3dwin4. Largest was
132572 triangles. It worked fine. Give me a day. I investigated the
"transforms" tab and I see that its functions could have some
application for me too. I also remember that povtree also generates
some kind of mesh. So I can try that too. Maybe make a furry tree?
Date: 14 Dec 2003 17:31:40
Message: <3fdce4cc$2@news.povray.org>
I have done some further testing of the program and there seems to be a
further problem.
The pcm files generated do not seem to parse properly in POV
If I wrap the pcm mesh as an object:
#include "pcm.mcr"
object { read_mesh ( filename.pcm ) texture... }
it will not parse
" } found, object expected "
If I wrap the pcm mesh as an union:
#include "pcm.mcr"
union { read_mesh ( filename.pcm ) texture... }
It will parse but will not display
The test files are in p.b.s-f.
Date: 14 Dec 2003 21:16:38
Message: <3fdd1986@news.povray.org>
If it starts with "PCM4" then it shouldn't. Chris hasn't updated the
macros to support the new format yet.
I didn't realize the normal_indices and uv_indices blocks are optional.
I fixed that.
I also fixed a problem with the option "ignore keyword 'mesh'" not
being reset between runs.
http://www.cs.tut.fi/~warp/WinMeshcomp30_beta3.zip
Using WinMeshcomp30_beta3.zip
Something that looks similar is if I make a selection in the
Transformations tab(Print boundaries), Optimizing is not done (as explained
in the text file). If I clear the Transformations, Optimizing is still not
done, I have to restart the program.
Or is there another way to do this?
That's probably something I forgot to reset as well. I'll look into it.
I updated the zip file.
It was indeed so that transformations weren't reset between runs. (It's
so much easier with the command-line version because it's run once and
that's it... :) )
When the program is working on a large file(Optimizing), I can't go to
another program (POV-Ray) and back to check if it's done. The WinMeshcomp
window is unresponsive.
As a reference file I'm using:
Ingo's 'Meshmerizing Mesh Maker Macros package'
mesh_demo\p_sphere.pov
changing line 27
to: 200,100,"test.inc"
This produces a mesh2, the begining of the file looks like this.
#declare Surface = mesh2 {
vertex_vectors {
20301
<8.9916e-013,0.899161,0>....
If I select this file for input and select 'go', no problem.
If I select 'Optimize normal vectors with error tolerance 0.001'
and select 'go'
I get 'Optimizing...' this is taking a while so I go to do other things.
Select another program, POV-Ray.
Try to go back to Winmeshcomp, no responce.
Another observation:
Original file(20301 vertices, 40000 triangles)
test.inc 2 392 097 bytes
WinMeshcomp (no options selected)
meshcomp -y C:\Program Files\POV-Ray for Windows
v3.5\include\mesh_demo\test.inc C:\Program Files\POV-Ray for Windows
v3.5\include\mesh_demo\test.pcm
Found mesh with 40000 smooth triangles and 40602 points.
Done. ----
test.pcm 2 785 121 bytes ("PCM4",)
I didn't expect the file to be bigger.
Do these set of include files make an incompatible mesh2 object for
Winmeshcomp?
That's normal because the program is calculating in a busy-loop and does
not listen to Windows' queries.
I don't know how Windows programs are made "responsive" even while they
are making heavy calculations. I suppose that they have to make some
system call once in a while or something similar. Does anyone have a tip?
The mesh2 format is already pretty minimal. The only thing where pcm
could save is in additional syntax.
The "PCM4" format is not completely identical to mesh2 and may in some
cases store more information than necessary. It depends a lot on what
the mesh2 contains.
>> WinMeshcomp
> does
Multi-threading.
Launch a new thread for the calculations, and let the old one handle the
GUI.
An alternative would be to do the calculations in small chunks (easy if
there's a big loop involved) and do a message dispatch between chunks.
In my opinion, the MT approach is the preferred one. It's both cleaner and
more robust.
