POV-Ray : Newsgroups : povray.general : Slightly faster VRand_On/In_Sphere() Server Time
2 Nov 2026 02:47:42 EST (-0500)
  Slightly faster VRand_On/In_Sphere() (Message 1 to 30 of 30)
Subject: Slightly faster VRand_On/In_Sphere()
Date: 6 Nov 2003 01:56:34
Message: <3fa9f0a2$1@news.povray.org>
The following macro gives an uniform distribution within the sphere{0,1}
and is slightly faster (by 9%) than VRand_In_Sphere() from rand.inc:
#macro VRand_In_Sphere(Stream)
  #local Y = 2*rand(Stream)-1;
  vrotate ( (<sqrt(1-Y*Y),Y,0>*pow(rand(Stream),1/3)), 360*rand(Stream)*y )
And this macro gives an uniform distribution on the surface of the
sphere{0,1}. It's slightly faster than VRand_On_Sphere() from rand.inc:
#macro VRand_On_Sphere(Stream)
  vrotate ( <sqrt(1-Y*Y), Y, 0>, 360*rand(Stream)*y )
I suggest to replace the original rand.inc macros by these macros.
   Sputnik
Subject: Re: Slightly faster VRand_On/In_Sphere()
Date: 6 Nov 2003 09:10:45
Message: <3faa5665$1@news.povray.org>
> <sqrt(1-Y*Y),Y,0>
I think that will cause points to be more dense towards the top and bottom
of the sphere, won't it?
It might be possible to correct it by running Y through some function like
acos() or something, but that would have to be researched.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 6 Nov 2003 13:55:42
Message: <3faa992e@news.povray.org>
Can you mathematically prove that the distribution is even?
Date: 6 Nov 2003 14:52:26
Message: <cjameshuff-4BAFBE.14520006112003@netplex.aussie.org>
In article <3fa9f0a2$1@news.povray.org>,
Hmm, I haven't had time to go over the mathematics, but these look like
they do give even results...
http://tag.povray.org/
Date: 7 Nov 2003 09:56:27
Message: <3fabb29b@news.povray.org>
Well, after understanding the message and going into its math a bit
more, I came to following conclusions.
I think we can agree that if Frank's VRand_On_Sphere is uniform on the
sphere then VRand_In_Sphere is uniform within the sphere.
So I considered VRand_On_Sphere which is a bit easier.
First remark I made is that the repartition is not obviously uniform.  :-)
What seem to happen here is that we have a combination of two
non-uniform transformations that may lead to a uniform repartition.
<sqrt(1-Y*Y), Y, 0> is non uniform in terms of length of the circle,
there will be more points in the middle of the circle and less at the
top and bottom, but then the rotation is not uniform either as it will
spread the points of the top and bottom on smaller surfaces.
The remaining question is : does the one exactly counter the other ?
I haven't answered this one yet, and I would really like to avoid doing
it with my rusty math, isn't any math student around willing to do it ??
There's just a few arcos integrals and stuff like that implied I think.  :-)
JC
> #end
> #end
>    Sputnik
Date: 7 Nov 2003 14:48:46
Message: <3fabf71e@news.povray.org>
Good point. It may very well do so. The <sqrt(1-Y*Y), Y, 0> distribution is
related to the cosine of the angle from the center of the circle to the
point <sqrt(1-Y*Y), Y, 0>. Also, the circumference of the circle which that
point is then randomly placed on is proportional to the cosine of the same
angle. Therefore, it's possible that this VRand_On_Sphere() function does in
fact work properly.
It needs to be worked out formally though.
 - Slime
Date: 7 Nov 2003 15:35:36
Message: <3fac0217@news.povray.org>
Well... I just posted an article until it popped up in my mind that
it was complete nonsense, so I canceled it again (hope that helps...)
Furthermore (as non-native speaker) I mixed up longitude and latitude
again -- @#$%!!!
I had to take pencil and paper and have a closer look:
>> #end
Okay, so the area size on a sphere between latitudes theta1 and theta2
is (where theta is not really the latitude but measured downwards from
the pole):
  integral theta1..theta2 over 2*pi*sin(theta) d(theta)
which is
  area = 2*pi*(cos(theta1)-cos(theta2))
The probability for the vector to be inside that area is:
  P(v in area) = P(cos(theta2)<= y < cos(theta1))
where y=2*rand(Stream)-1, i.e. uniformly distributed, so
  P = ( cos(theta1)-cos(theta2) )/2
Now, if the probability is proportional to the area, the distribution
is uniform. Looking at the formulas, this is evident:
  P/area = 1/(4*pi)
...which is just what we expect and independent of theta1 and theta2.
So I think that it really works.
Cheers,
Wolfgang
Date: 7 Nov 2003 18:58:00
Message: <3fac3188@news.povray.org>
  Well, I think this is not automatic, but needs proof. :)
  (Btw, has anyone proven mathematically that the current official
macros produce even distributions?)
Date: 7 Nov 2003 21:36:47
Message: <3fac56bf$1@news.povray.org>
I am convinced that they do.
Honestly, I'm not sure of the proper mathematical procedures to use when
evaluating a distribution curve. Nonetheless, I understand the logic behind
what causes an uneven distribution and how to go about correcting it; I have
a very good intuition about this sort of thing (IMO at least ;) ) and during
the POV-Ray 3.5 beta I took a good look at the two functions out of
curiosity. I determined, simply by reading the code, that the
VRand_In_Sphere function provided an uneven distribution, because it wasn't
using the pow(..., 1/3) trick to pull things away from the center. I
verified my suspicions, fixed the problem and submitted what is now the
current VRand_In_Sphere function.
Anyway, I've thought long and hard about both functions, and I am absolutely
certain that both of them provide even distributions.
I have been known to be wrong... =)
 - Slime
Date: 8 Nov 2003 04:14:40
Message: <3facb400@news.povray.org>
I think my posting from yesterday proofs it.
The vector is rotated by a random amount around the Y axis, so it
is sufficient to prove that the probability for the vector being
in a certain latitude range is equal to the area covered by it
(divided by 4pi, of course). Now read on in my previous posting.
Wolfgang
Date: 8 Nov 2003 11:11:00
Message: <3fad1594$1@news.povray.org>
Even if the distribution of these functions are indeed even, it should
still be considered that some scenes made using the current macros may
be designed to depend on their exact output, not just the distribution.
(Just like some scenes were made to depend on the old noise_generator
before it was changed in POV-Ray 3.5.) This means that if new macros
with different output are introduced, backward compatible alternative
macros must be provided as well. This however, doesn't necessarily
prevent some users from being confused when their scenes suddenly look
different, if they're not aware of the new macros that have replaced the
old ones.
Now the question is: Is the 9% speed increase worth the hassle with the
backwards compatibility issue? I'm not for or against, I just want to
make sure that the issue is being considered.
Rune
rune|vision:  http://runevision.com **updated Sep 28**
POV-Ray Ring: http://webring.povray.co.uk
Date: 8 Nov 2003 12:49:14
Message: <cjameshuff-EDDF1A.12480208112003@netplex.aussie.org>
In article <3fac3188@news.povray.org>, Warp <war### [at] tagpovrayorg>
Well, I've done empirical tests that seem to show that they do. And come
up with another interesting fact: points on a sphere are uniformly
distributed on each axis. Makes sense once you realize why (The
boundaries of each slice subtend a greater angle as you near the edge of
the sphere, where the radius is smaller. Any two slices through a sphere
of the same thickness have the same surface area.), but a bit surprising
to realize.
Date: 8 Nov 2003 13:10:51
Message: <3fad31ab@news.povray.org>
  Probably not worth.
  To get a speed boost you can simply copy the macro from the include
file to your scene file. This should noticeably increase its speed due
to how POV-Ray parses macros in include files.
Date: 8 Nov 2003 16:28:44
Message: <cjameshuff-FFFF7F.16272608112003@netplex.aussie.org>
In article <3fad31ab@news.povray.org>, Warp <war### [at] tagpovrayorg>
>   Probably not worth.
A speed boost, but for a different reason. This new version is indeed
faster (by 12% by my measurements...call it 10%). It's also shorter and
easier to understand. I doubt there would be very many scenes that would
be adversely affected. The macro versions defined could be made
conditional on the POV-Ray #version, or just left alone with slightly
modified names. It's a small improvement, but I think it would be worth
it...assuming the macros can be proven to work right. (They seem to,
from my measurements, but I haven't proven it.)
Date: 8 Nov 2003 16:43:09
Message: <3fad636d$1@news.povray.org>
Is it possible to use SDL to determine the current #version, and then define
a different macro based on that? Then the better versions could be used for
scene files marked for version 3.5.1 (or whatever), and the older versions
used for older scene files.
 - Slime
Date: 8 Nov 2003 18:01:27
Message: <3fad75c6@news.povray.org>
What exactly do you understand by a "proof"?
Wolfgang
Date: 8 Nov 2003 18:33:27
Message: <3fad7d47$1@news.povray.org>
Alchohol content of a beverage, percentage divided by half.
Date: 8 Nov 2003 20:54:23
Message: <3fad9e4f@news.povray.org>
  Mathematical proof. Should be unambiguous and checkable by anyone.
Date: 9 Nov 2003 04:14:51
Message: <ub1sqvs1c3mmhmdjce4773gn691tvobnvf@4ax.com>
On Sat, 08 Nov 2003 18:34:08 -0500, Tim Cook <z99### [at] bellsouthnet> wrote:
I beg to differ, Quote …
Only the English could invent 'proof' in 1762, which was the technical standard
by which strength was measured until 1st January, l980.   If  gunpowder and
alcohol were mixed and  the spirit was weaker than proof strength (57% ABV),
there was just a damp fizzle. However, when whisky and gunpowder were mixed  and
there was enough alcohol in the mixture to cause ignition, then the gunpowder
flashed, providing the 'proof' of  stronger alcohol.
To compare: Gay Lussac's ABV to UK and US Proof:
100% (Pure alcohol)  =  175 UK Proof  = 200 US proof
50% =  87.5 UK Proof = 100 US proof
46% =   80.5 UK Proof = 92 US prof
For UK proof  multiply ABV by 1.75, for US double it
Regards
Date: 9 Nov 2003 05:09:37
Message: <3fae1261$1@news.povray.org>
There, see?  I was right by way of accident in wording my formula;
dividing something BY half, not IN half, is the same as multiplying
by two...haha!  *sweatdrop*  *hides*
Date: 9 Nov 2003 05:28:16
Message: <kh5sqvc1f6aifrno92u9ir08nptm6m05kt@4ax.com>
On Sun, 09 Nov 2003 05:10:37 -0500, Tim Cook <z99### [at] bellsouthnet> wrote:
By accident? No, I don't believe that.
Regards
Date: 9 Nov 2003 09:15:17
Message: <3fae4bf4@news.povray.org>
Then please check my proof in the other posting(s).
It should be easy to follow. For convenience, I copy-and-paste
it here again:
A: VRand_On_Sphere(): surface vectors.
The area size on a sphere between latitudes theta1 and theta2
the pole):
which is
(because y = r * cos(theta) and r=1 here).
Now, the probability per area can be calculated as:
  P/area = 1/(4*pi)
- q.e.d.
So, it works for the sphere surface vectors.
B: VRand_In_Sphere(), full sphere.
For the full sphere, there is not much difference, just the
radius is chosen to be randomly distributed using
pow(rand(Stream),1/3)).
I don't believe that this is right until someone (me?) proves
it to be right - ;)
Wolfgang
Date: 9 Nov 2003 09:45:31
Message: <3fae530a@news.povray.org>
> it to be right - ;)
As shown last time, we already have a function for the uniform
distribution on a sphere surface. For the VRand_In_Sphere() function,
it is therefore sufficient to prove that the radius calculation
(i.e. vector length) is correct.
For that purpose, it must be shown that the probability for the
vector being of a certain length range is equal to the volume
enclosed by that radius range (divided by 4*pi/3, of course).
The sphere volume between radii r1 and r2 (r2>r1) is:
  V = 4*pi/3 * (r2^3 - r1^3)
The vector length l is calculated as l=a^(1/3) with a=rand(Stream),
hence l^3 is uniformly distributed in the range 0..1.
The probability for the vector to end in the volume V (i.e. radius
range r1..r2) is:
  P(vector in V) = P(r1 <= l < r2) = P(r1^3 <= l^3 < r2^3) =
and as l^3=a:
  = P(r1^3 <= a < r2^3) = r2^3 - r1^3
Hence, the quotient (probability per volume) is:
  P/V = 3/(4*Pi)
...which is what we want.
- q.e.d.
So, it works; VRand_In_Sphere() is uniformly distributed in the sphere.
Any doubts or problems?
Wolfgang
Date: 12 Nov 2003 02:41:10
Message: <3fb1e416$1@news.povray.org>
I vote for 'not worth'.
I'm pretty much convinced that the proposed distribution are even, but I
agree with your arguments. And I would also add that it is better to
have a clearly even distribution in the include file rather than a
distribution that is very clever but not so clear, even if it's faster.
JC
> old ones.
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 12 Nov 2003 08:33:56
Message: <3fb236c4@news.povray.org>
  IMHO that's irrelevant.
  The main features should be speed and ease of use. Algorithmic complexity
is irrelevant.
Date: 12 Nov 2003 23:37:57
Message: <3fb30aa5$1@news.povray.org>
Oh boy, what a long thread ...
I've not looked at this thread for a while and I am astonished
about the many responses (and strange sidetracks ...). Next time
when I post such a thing I will provide a proof together with it,
but here it seems unneccessary now as Wolfgang did it (thanks for
that).
Because the usage of such a macro should not depend on its inner
workings, I think it is bad (or at least questionable) programming
style to rely on the specific algorithm used for the implementation.
(Remember: the macro is supposed to deliver *random* points, so
even a truly random hardware generator that never repeats the same
(long) sequence should be accepted!)
If this dependence is required, the macro should be *copied* to the
scene: this will prevent these special scenes from breaking while
leaving room for improvements for the majority of the other scenes.
(BTW: calling a copied macro is *much* faster than calling an
included macro, when it is used very often.)
Refraining from such improvements sounds to me a little bit like
"don't improve the accuracy of POV-Ray's geometric calculations,
my scene depends on the rounding errors". (O.K., don't take this
argument toooo seriously: I wrote "to me" and "a little bit" :-)
So I now suggest to use the new macros in rand.inc, but leave
the old macros as comment (or renamed to ..._Old).
Or: leave the old macros and include my macros with the suffix
"_New" or as comment ...
   Sputnik
Date: 13 Nov 2003 04:21:08
Message: <3fb34d04$1@news.povray.org>
"Frank 'Sputnik' Rothfuß" <fr### [at] computermuseumfh-kielde> wrote in message
news:3fb30aa5$1@news.povray.org...
<snip>
I think you're missing the point - when using rand in a scene I will often throw
various seeds at it until I get a distribution I like. This distrib will be
random - I'm not aiming for a particular numeric sequence - but in the interests
of a nice image some random sequences will produce better results.
Take a look at:
http://www.tomandlu.co.uk/webres/raytracing/gallery/pics/tmsummer.jpg
and
http://www.tomandlu.co.uk/webres/raytracing/gallery/pics/tmwinter.jpg
the branch distrib is undeniably random, but a different sequence will not
produce the same aesthetic effect. Now in this case I'm using plain rand + my
own algorithms, but if the supplied macros are to be taken seriously, then they
have to produce consistent results. Bug fixing is one thing, but (fairly)
arbitary changes every time a speed-increase is found is another. Much better
IMHO to provide improved macros with different names (or some sort of version
directive as suggested by others).
Date: 13 Nov 2003 17:58:10
Message: <3fb40c82@news.povray.org>
O.K., now I see this point.
So my macros are good if speed is important, but
"backward compatibility" isn't (if the particular
sequence doesn't matter; and in new scenes);
otherwise the current macros will be neccessary.
Copying is better than including (in the case of
these macros): a copied macro is faster; the scene
is protected from changes in the include file.
   Sputnik
Date: 17 Nov 2003 18:30:06
Message: <3fb959fe@news.povray.org>
#macro EvenSpherePoint(pos, rad, sd)
    #local irad = sqrt(min(rand(sd),0);
    #local long = rand(sd)*2*pi;
    #local hemi = select(rand(sd)-0.5, -1, 1)
    #local azim = pow(rand(sd), x)*pi*0.5;
    #local dir = <cos(azim)*cos(long), hemi*sin(azim), cos(azim)*sin(long)>;
    #local pnt = pos+dir*irad*rad;
    pnt
What should x be in order to get a truly even distribution (or at least
something close)?
I set up an Excel spreadsheet comparing cos(x*2/pi) to 1-(x*x)^n
for -1<=x<=1 in steps of 0.01 and 0.002.  I calculated the sum of the
differences between the functions, essentially looking of a value of n where
the integrals of these functions were identical.  Excel came up with
0.875969064, or 1/(pi-2).  x in the phi function is double that.
"Wolfgang Wieser" <wwi### [at] gmxde> wrote in message
news:3fae530a@news.povray.org...
> > it to be right - ;)
> range r1..r2) is:
> and as l^3=a:
>   P/V = 3/(4*Pi)
> - q.e.d.
> Wolfgang
Date: 18 Nov 2003 14:45:53
Message: <cjameshuff-35296B.14423918112003@netplex.aussie.org>
What are you trying to do? Your messages don't seem to have much to do
with the ones they reply to. And what advantages do your versions have?
We already have two simpler versions that are tested and pretty well
proven to give the correct distribution.
Plus I see several errors in your code, even after syntax is corrected
enough for the macros to parse...for example, "min(rand(sd),0)" is
always 0. Using max() doesn't make any more sense...it would have no
effect. "pow(rand(sd), x)" is meaningless...raising a random number to a
power of < 1, 0, 0>? Fixing the parentheses and semicolons, removing the
min(), and substituting 2 for x gave something that didn't even come
close to an even spherical distribution, with either of your macros.
