POV-Ray : Newsgroups : povray.general : Image clips with POV Server Time
12 Jul 2026 08:42:42 EDT (-0400)
  Image clips with POV (Message 1 to 4 of 4)
Subject: Image clips with POV
Date: 4 Oct 2003 16:20:57
Message: <3f7f2ba9@news.povray.org>
Is it possible to use image clips with POV?
Actually, I have a sequence of bitmaps, called 'my-file-01.tga',
'my-file-02.tga' etc.
I like to use bitmaps for animated heightfield, every frame of animation
with a new bitmap, for animated footprints on the sand, etc.
Rest of the scene and material for heightfield needs to be the same.
Any suggestions, experience?
Thanks
Subject: Re: Image clips with POV
Date: 4 Oct 2003 17:12:35
Message: <ag2551-dl5.ln1@control-alt-del.ch>
> animation with a new bitmap, for animated footprints on the
> sand, etc. Rest of the scene and material for heightfield needs
> to be the same.
My idea looks as follows (not tested):
  tga concat("my-file-",str(clock,2,0), ".tga")
Greets & HTH
Dave
Dave "tPassive" Vogt| ruby -e "n=gets.to_i;a=(2..n).to_a;a.each{
Linux  user  #225040| |x|puts x;(x*2).step(n,x){|j|a.delete j}}"
____________________|_____________________________             |
PGP Key: http://control-alt-del.ch/public_key.asc \____________/
Date: 4 Oct 2003 17:19:53
Message: <3f7f3979$1@news.povray.org>
news:3f7f2ba9@news.povray.org...
Just tie the frame_number built-in identifier to your file name:
#declare Myfilename=concat("my-file-",str(frame_number,-1,0));
height_field{tga Myfilename}
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 5 Oct 2003 08:32:36
Message: <3f800f63@news.povray.org>
  You probably want to use frame_number instead of clock.
