POV-Ray : Newsgroups : povray.general : Fire Textures anyone? Server Time
2 Nov 2026 03:37:51 EST (-0500)
  Fire Textures anyone? (Message 1 to 15 of 15)
Subject: Fire Textures anyone?
Date: 28 Sep 2003 14:51:54
Message: <3f772dca$1@news.povray.org>
Anyone know where to find some good fire textures?
I'm trying to create a torch (kind of like you'd find in a dungeon),
and can't seem to find any good textures to use for the fire.
Also...any tips on animating the fire would be appreciated.
(i.e.  getting the flame to MOVE with each frame)
Subject: Re: Fire Textures anyone?
Date: 28 Sep 2003 16:29:21
Message: <3f7744a1@news.povray.org>
You can try with something like this:
--------8<------------8<------------8<------------8<-----------8<-------
// -w300 -h600 +a +kff50 +kc
#include "functions.inc"
camera { right x*30/60 location -z*7.5 look_at 0 angle 35 }
light_source { <10,20,-30>, .5 }
#declare TorchWood =
  texture
  { pigment
    { wood color_map { [0 rgb <.7,.4,.2>][1 rgb <.9,.5,.3>] }
      turbulence .5
    normal
    { wood 1
      turbulence .5
    finish { specular .2 }
    scale <.1,1,.1>
#declare SphericalF = function { pattern { spherical } }
#declare NoiseF =
  function
  { (1-f_noise3d(x*5,y*5,z*5)*.9)*
    (1-f_noise3d(x*15,y*15,z*15)*.4)
#declare Torch =
  union
  { sphere
    { 0,1.2 hollow scale <1,2,1> translate y
      pigment { rgbt 1 }
      interior
      { media
        { emission .5
          density
          { function
            { SphericalF(x,y,z)*
              (NoiseF(x,y-clock*3,z)*(1-clock) +
               NoiseF(x,y-clock*3+3,z)*clock)
            density_map
            { [0 rgb 0]
              [.2 rgb <.8,.4,0>]
              [.21 rgb <1,1,.2>]
              [.5 rgb <1,.9,.8>]
              [1 rgb 1]
        media
        { emission .5
          density
          { function
              (NoiseF(x,y*2-clock*3,z)*(1-clock) +
               NoiseF(x,y*2-clock*3+3,z)*clock)
            density_map
            { [0 rgb 0]
              [1 rgb 1]
          scale <1.2,2,1.2>
          translate y*1.4
      scale <1.5,3,1.5>
      rotate z*-5
      translate <.2,1.2,0>
    cone { -y*4,.15, 0,.25 }
    sphere { 0,.25 }
    texture
    { pigment_pattern
      { gradient y color_map { [0 rgb 0][1 rgb 1] }
        scale 4.25 translate -y*4
      texture_map
      { [.7 TorchWood]
        [.8 pigment { rgb 0 }]
        [.9 pigment { rgb x*.8 } finish { ambient 1 }]
        [1 pigment { rgb <1,.2,.2> } finish { ambient 1 }]
object { Torch translate -y*3 }
Date: 28 Sep 2003 16:37:06
Message: <3f774672@news.povray.org>
Took me WAY too long to figure out what that is...
Man, I must be tired! I'll have to remember that one though...
Date: 28 Sep 2003 16:46:00
Message: <3f774888@news.povray.org>
MUCH appreciated!!!
thanks!
(now if I can just get that into Moray!  hahaha)
news:3f7744a1@news.povray.org...
>   texture
>   { pigment
>       turbulence .5
>     normal
>     { wood 1
>       turbulence .5
>     scale <.1,1,.1>
> #declare NoiseF =
>   function
> #declare Torch =
>   union
>   { sphere
>       pigment { rgbt 1 }
>       interior
>       { media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [.2 rgb <.8,.4,0>]
>               [.21 rgb <1,1,.2>]
>               [.5 rgb <1,.9,.8>]
>               [1 rgb 1]
>         media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [1 rgb 1]
>           scale <1.2,2,1.2>
>           translate y*1.4
>       scale <1.5,3,1.5>
>       rotate z*-5
>     sphere { 0,.25 }
>     texture
>     { pigment_pattern
>       texture_map
>       { [.7 TorchWood]
Date: 28 Sep 2003 17:01:28
Message: <3f774c28@news.povray.org>
Okay.....maybe this is a different kind of question.
I took this texture definition, pretty much created the same thing
in Moray.  When I preview the texture, it looks fine.
But when I actually assign it to a sphere, or cone, or something,
it doesn't show up at all.
Any clues?
>   texture
>   { pigment
>       turbulence .5
>     normal
>     { wood 1
>       turbulence .5
>     scale <.1,1,.1>
> #declare NoiseF =
>   function
> #declare Torch =
>   union
>   { sphere
>       pigment { rgbt 1 }
>       interior
>       { media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [.2 rgb <.8,.4,0>]
>               [.21 rgb <1,1,.2>]
>               [.5 rgb <1,.9,.8>]
>               [1 rgb 1]
>         media
>         { emission .5
>           density
>           { function
>             density_map
>             { [0 rgb 0]
>               [1 rgb 1]
>           scale <1.2,2,1.2>
>           translate y*1.4
>       scale <1.5,3,1.5>
>       rotate z*-5
>     sphere { 0,.25 }
>     texture
>     { pigment_pattern
>       texture_map
>       { [.7 TorchWood]
Date: 28 Sep 2003 17:22:36
Message: <3f77511c@news.povray.org>
  The fire (and the smoke) is not a texture but a media which is defined
in the inside of the sphere (the texture in my code is just the wooden
texture of the torch).
  That is, you can't use it as texture but you have to use it as media
inside a hollow sphere, as in my code.
  Btw, the "smoke" is actually not smoke, but some light-emitting media.
You might need to change it to absorbing media or remove it completely.
Date: 29 Sep 2003 11:37:52
Message: <3f7851d0$1@news.povray.org>
"-s0da-" <ske### [at] msncom> a écrit dans le message de news:
3f774888@news.povray.org...
> MUCH appreciated!!!
> thanks!
There is Luis's "InsertCode" pluggin which allows you to insert any POV code
into a Moray scene
http://lightning.generator.tuxfamily.org/modules.php3?op=modload&name=Moray_
plugins&file=index
And I don't know if it works in Moray 3.3 or if it is a 3.5 feature but in
the material editor
create a new material, delete texture, select material, right click you can
find a direct code option
then type your code or right click in code window and paste formerly copied
code
HTH
Marc
Date: 29 Sep 2003 11:40:28
Message: <3f78526c@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de news:
3f77511c@news.povray.org...
Yes, as wrote Warp, the key word is "hollow"
in the modify tab of your sphere, check the hollow checkbox
Marc
Date: 29 Sep 2003 11:56:11
Message: <4glgnvon1e6nbndomtr8qr8i558b76r089@4ax.com>
On Mon, 29 Sep 2003 17:39:18 +0200, "Marc Jacquier" <jac### [at] wanadoofr>
>the material editor
Ver 3.5 :-{
Regards
Date: 29 Sep 2003 13:09:49
Message: <3f78675d@news.povray.org>
that's EXACTLY what I am looking for!  Thanks a BUNCH!
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:3f7851d0$1@news.povray.org...
> > MUCH appreciated!!!
> > thanks!
code
> into a Moray scene
> plugins&file=index
> the material editor
can
copied
> code
> HTH
> Marc
Date: 29 Sep 2003 13:19:24
Message: <3f78699c@news.povray.org>
Figure this out...Any clue?
I have the torch mounted on a wall (plane)...looking at it from a
45 degree angle.  With just the torch, and the wall behind it,
the flame is visible.  However...when I put another wall, perpendicular
to the back wall, and back  a ways from the torch (so as to give a
corner type backdrop to the torch lighting), for some unexplicable
reason, the torch stays visible, but the flame vanishes.
I've tested this back and forth.  I remove the corner forming plane, and
the flame reappears.  Put it back...flame disappears.  Can't figure this
out.
And no...the plane is not in between the camera and the flame, otherwise
the torch wouldn't be visible.  it's just the flame that vanishes.
and I checked the light source as well...it's behind the camera, not blocked
out at all by the plane.
Anyone ever seen this behavior before?  Material being affected by objects
around it?  outside of its boundaries?
news:3f78526c@news.povray.org...
> Marc
Date: 29 Sep 2003 14:03:41
Message: <3f7873fd@news.povray.org>
Try this also:
#macro FireMap(Type)
 #local Inverse = 0;
 #switch (Type)
  #case (1) // Brightest flames, bright red to pale yellow
   #if ( Inverse )
    color_map {
     [ 0.0 rgb <0.0, 0.0, 0.0> ]
     [ 0.2 rgb <0.0, 0.0, 0.0> ]
     [ 0.2 rgb <0.0, 0.6, 0.6> ]
     [ 0.6 rgb <0.0, 0.4, 0.8> ]
     [ 1.0 rgb <0.0, 0.0, 0.5> ]
   #else
    color_map {
     [ 0.2 rgb <1.0, 0.4, 0.4> ]
     [ 0.6 rgb <1.0, 0.6, 0.2> ]
     [ 1.0 rgb <1.0, 1.0, 0.5> ]
  #break
  #case (2) // Slightly dimmer, with more red
   #if ( Inverse )
    color_map {
     [ 0.35 rgb <0.0, 0.0, 0.0> ]
     [ 0.40 rgb <0.0, 0.6, 0.6> ]
     [ 0.50 rgb <0.0, 0.6, 0.6> ]
     [ 0.65 rgb <0.1, 0.1, 1.0> ]
     [ 0.75 rgb <0.1, 0.1, 1.0> ]
     [ 0.80 rgb <0.0, 0.0, 0.8> ]
   #else
    color_map {
     [ 0.40 rgb <1.0, 0.0, 0.0> ]
     [ 0.50 rgb <1.0, 0.0, 0.0> ]
     [ 0.65 rgb <1.0, 1.0, 0.0> ]
     [ 0.75 rgb <1.0, 1.0, 0.0> ]
     [ 0.80 rgb <1.0, 1.0, 0.5> ]
  #break
  #case (3) // Medium flames with red and orange
   #if ( Inverse )
    color_map {
     [ 0.25 rgb <0.0, 0.0, 0.0> ]
     [ 0.25 rgb <0.0, 0.5, 1.0> ]
     [ 0.50 rgb <0.0, 0.5, 1.0> ]
     [ 0.75 rgb <0.0, 0.3, 0.6> ]
   #else
    color_map {
     [ 0.25 rgb <0.8, 0.0, 0.1> ]
     [ 0.50 rgb <0.8, 0.0, 0.1> ]
     [ 0.75 rgb <1.0, 0.5, 0.0> ]
  #break
  #case (4) // Mostly red with violet/orange mix
   #if ( Inverse )
    color_map {
     [ 0.00 rgb <0.0, 0.0, 0.0> ]
     [ 0.35 rgb <0.7, 0.3, 1.0> ]
     [ 0.65 rgb <0.7, 1.0, 0.3> ]
     [ 1.00 rgb <0.0, 1.0, 1.0> ]
   #else
    color_map {
     [ 0.35 rgb <0.3, 0.7, 0.0> ]
     [ 0.65 rgb <0.3, 0.0, 0.7> ]
     [ 1.00 rgb <1.0, 0.0, 0.0> ]
  #break
  #case (5) // Dark red/orange embers
   #if ( Inverse )
    color_map {
     [ 0.3 rgb <0.0, 0.0, 0.0> ]
     [ 0.3 rgb <0.0, 0.7, 0.7> ]
     [ 1.0 rgb <0.4, 0.8, 0.6> ]
   #else
    color_map {
     [ 0.3 rgb <0.2, 0.1, 0.1> ]
     [ 1.0 rgb <0.4, 0.1, 0.2> ]
  #break
#macro Fire( Type, Size )
 interior {
  //ior 1.1
  media {
   emission 0.6
   method 3
   samples 5, 20
   intervals 1
   variance 1/1000
   confidence .995
   density {
    spherical
    turbulence 1.50
    omega 0.7
    lambda 1.7
    FireMap(Type)
    scale Size*0.5
#declare cFlame = sphere {
 y, 1
 scale <.8, 3, .8>
 pigment { rgbt 1 }
 hollow
 no_shadow
 Fire( 2, <1.5, 4, 1.5> )
Feel free to play with the color maps if you want.  I keep the inverse
option for when I need to make a negative image later.
Date: 29 Sep 2003 14:24:23
Message: <3f7878d7@news.povray.org>
  The flame (and the camera) are probably inside the wall.
  Try inverting the wall (ie putting its normal to point to the opposite
direction, to the side where the fire is).
  Another solution is to make the wall "hollow", but I wouldn't recommend
that because it's conceptually the wrong solution (why would you want
your scene inside the plane when it clearly should be outside?).
Date: 29 Sep 2003 14:33:03
Message: <cjameshuff-C04270.14322929092003@netplex.aussie.org>
In article <3f78699c@news.povray.org>, "-s0da-" <ske### [at] msncom>
Chances are, the plane is facing the wrong way. The camera and torch are
inside it, and because it isn't hollow, there's no media in it. I bet
you get a warning message, something like "camera in non-hollow object".
http://tag.povray.org/
Date: 29 Sep 2003 15:36:35
Message: <3f7889c3$1@news.povray.org>
Bet that's it. DAMN, why didn't I think of that.
DOH!
hahahaha
thanks for you help!
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
