POV-Ray : Newsgroups : povray.general : Problem with Parse_String and #ifndef Server Time
2 Nov 2026 04:32:27 EST (-0500)
  Problem with Parse_String and #ifndef (Message 1 to 15 of 15)
Subject: Problem with Parse_String and #ifndef
Date: 10 Sep 2003 12:21:10
Message: <3f5f4f76$1@news.povray.org>
Hey Guys!
I want to check if a certain pigment is already defined and otherwise
define it. Normally that would be no problem, #ifndef does the job.
Unfortunately, I create my pigments dynamically within the SDL code.
Every pigment gets a number. The pigment's name would be
	Parse_String(concat("Pigment",str(Number,0,0)))
but this does not work with #indef. The following code reports: "Parse
Error: Expexted ')', '(' found instead". The error occurs right after
"Parse_String" in the code:
<code>
#include "strings.inc"
#local Number = 34;
#local PigmentName = concat("Pigment",str(Number,0,0));
#ifndef(Parse_String(PigmentName))
	#debug "no pigment defined, yet\n"
</code>
I understand this from the parser's point of view - normaly, opening
brackets inside #ifndef() do not make sense, as identifiers aren't
allowed to contain brackets. In the case of Parse_String(), however,
it makes sense.
I see no reason to rewrite the parser because of this, but I'd like to
know if there is another possibility to check if an identifier from
which I got only the name as a string is already declared.
BTW, declaring such an identifier is possible: while
<code>
#declare Parse_String(PigmentName) = pigment { rgb<1,0,0> }
</code>
gives an error,
<code>
Parse_String(concat("#declare ",PigmentName)) = pigment { rgb<1,0,0> }
</code>
works perfectly.
Thanks in advance,
Florian
//=================[web: http://www.torfbold.com]==================\\
#local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
.1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
<8,-3,-8>*10}// [www.povray.org]     [www.imp.org]     [www.irtc.org]
Subject: Re: Problem with Parse_String and #ifndef
Date: 10 Sep 2003 12:29:44
Message: <3f5f5178$1@news.povray.org>
How about this:
write your own Parse_String which always outputs to
"somefile.ext".
Then do:
#ifndef (#include"somefile.ext")
I'm not quiet sure if that'll work though.
As for the last part of your post:
#declare Parse_String... = ...
processes down to
#declare #include "blabla" = ...
So, I'd expect it to complain. Hm, which might
be a reason for #ifndef to complain for the above:
#ifndef (#include"...") ?
You've got to experiment. Perhaps writing the entire
#ifndef () ... #debug ".." #end
to disc and #including that.
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
"Florian Brucker" <tor### [at] torfboldcom> schrieb im Newsbeitrag
news:3f5f4f76$1@news.povray.org...
> Hey Guys!
> <code>
> #local Number = 34;
> #end
> </code>
> it makes sense.
> <code>
> </code>
> gives an error,
> <code>
> </code>
> works perfectly.
> Thanks in advance,
> Florian
Version: 6.0.515 / Virus Database: 313 - Release Date: 01.09.2003
Date: 10 Sep 2003 12:34:19
Message: <c5kulvsca8m0ppns155dbjjp8d4rocqsp1@4ax.com>
On Wed, 10 Sep 2003 18:22:47 +0200, Florian Brucker <tor### [at] torfboldcom> wrote:
> <code>
> #local Number = 34;
> #end
> </code>
Try this:
#local Number = 34;
#local PigmentTest = concat("(defined(",PigmentName,")?yes:no)");
#if(!Parse_String(PigmentTest))
ABX
Date: 10 Sep 2003 12:44:36
Message: <3f5f54f4$1@news.povray.org>
Hi Tim!
That did the job!
if anyone is interested, here's the code:
<code>
#declare TestIdent = 1;
#macro IFDEF2(Name)
	#declare TEMPDEF__ = 0;
		"#ifdef(",Name,")
			#declare TEMPDEF__=1;
		#end"
	(TEMPDEF__)
#if (IFDEF2("TestIdent"))
	#debug "defined\n"
#else
	#debug "nope\n"
</code>
result: defined
Thanks Tim!
Greetings,
Florian
Date: 10 Sep 2003 12:51:17
Message: <3f5f5685$1@news.povray.org>
Hey ABX
> #local Number = 34;
> #end
Wow, that's a nice idea!
You know, two answers to my post in 10 minutes. And both helped me
solve my problem. That's what I call a great community :)
Thanks,
Florian
Date: 10 Sep 2003 13:18:16
Message: <3f5f5cd8$1@news.povray.org>
In article <3f5f4f76$1@news.povray.org> , Florian Brucker
> it makes sense.
This isn't the parsers problem, it is your scene.  You simply do not
generate a valid scene with what you do.  This should be clear from the
specification of #ifndef (taking only a single identifier).
However, this isn't all.  There is a second misconception.  What you expect
is #macros to behave like macros, not functions.  However, if you read the
chapter in the documentation which explains the difference between the
POV-Ray #macro and what most people commonly expect from macros (and how
macros return something), you will notice that what you do cannot work as
expected.
Even worse, there is a third roadblock in your code, which is that a #macro
name can also be checked with an #ifndef.  And actually this is what the
parser catches first and reports an error for.  nevertheless, the first two
problems would persist even if this would be accepted by the parser.
    Thorsten
e-mail: tho### [at] trfde
Date: 10 Sep 2003 13:45:26
Message: <3f5f6336@news.povray.org>
It would be nice if the string parsing was an internal command which
could be used anywhere.
  I suppose #parse would be a good name. This way you could do things like:
#declare #parse(concat(name1, name2)) = 5;
  That is, the parser would take the string given as parameter to #parse
and parse its contents as if it was just plain text appearing at that place
in the file. This would certainly be handy for many things.
  (OTOH it accentuates the importance of I/O restrictions because it would
allow making extremely obfuscated SDL code.)
  I think one important feature of this #parse command that differentiates
it from other commands is that it should be possible to appear *anywhere*
in the code. Even though this is not strictly indispensable, it would
certainly make it more useful.
  That is for example this:
#de#parse("cl")are ab#parse("cde")fg = 5;
would be effectively the same thing as:
#declare abcdefg = 5;
  I don't know if this behaviour would be easy to implement in the current
parser, but just an idea...
Date: 10 Sep 2003 13:50:46
Message: <3f5f6476@news.povray.org>
In article <3f5f6336@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Aren't *you* the one who usually argues for well structured code? ;-) ;-)
    Thorsten
Date: 10 Sep 2003 16:01:12
Message: <3f5f8308@news.povray.org>
  In C++ yes, but the POV-Ray SDL is a hacker language. :P
Date: 10 Sep 2003 16:33:11
Message: <3f5f8a87$1@news.povray.org>
Do you mean a language for 'hacks', or a language for 'hackers'?
Date: 10 Sep 2003 17:23:50
Message: <3f5f9666@news.povray.org>
  Mainly I meant a language for hackers. You know, that type of language
which you can use to make marvelous things with an incredibly short piece
of code... which is also so obfuscated you don't understand it at all... :P
Date: 10 Sep 2003 18:02:15
Message: <3f5f9f67$1@news.povray.org>
> Thanks Tim!
> Greetings,
> Florian
You're welcome. I figured this one pretty
fast because I had similiar ideas about dynamic
texture/array/object generation some months
ago, and gave thought to those issues at
that time. And seeing your code, it was
rather simple to just write my initial thoughts
about it... :-)
Tim Nikias v2.0
> Hi Tim!
> That did the job!
> <code>
> #macro IFDEF2(Name)
> "#ifdef(",Name,")
> #end"
> (TEMPDEF__)
> #end
> #debug "defined\n"
> #else
> #debug "nope\n"
> #end
> </code>
> result: defined
> Thanks Tim!
> Greetings,
> Florian
Date: 10 Sep 2003 21:35:38
Message: <cjameshuff-987A4F.21354710092003@netplex.aussie.org>
In article <3f5f6476@news.povray.org>,
Aren't you forgetting who started the scrambled signature craze?
http://tag.povray.org/
Date: 10 Sep 2003 21:46:01
Message: <3F5FD3A4.FCFB328A@pacbell.net>
I haven't (in case he conveniently forgets) and would be more than
happy to name names.
Ken Tyler
Date: 11 Sep 2003 08:10:50
Message: <3f60664a@news.povray.org>
  But I'm proud of that. :)
