http://www.schloerb.com/Dreamscape2/
- Slime
[ http://www.slimeland.com/ ]
These look very good, thanks for sharing the link.
Bonsai
___ __ __ _ ___ ___ _
| _ ) \ \( ) _) _ )( )
| _ \() |\ \ |\ \/ _ \| |
|___/__/_)\__)___)/ \_)_)
www.b0n541.net
"Hi. I'm a signature virus. Add me to your signature - help me spread!"
Heyya Slime,
Those are really cool.
When I went to d/l them I discovered the link was a bit slow. I
don't know if that's temporary, just me, or what; but they're on
my webserver and if you'd like to href to them on my server
instead, just email me for the URL.
> - Slime
If riding in an airplane is flying, then riding in a boat is swimming.
47 jumps, 13.2 minutes of freefall, 27.3 ff vertical miles.
Good day!
"Slime" <fak### [at] email address> wrote in news:3f5bae82@news.povray.org:
Humm, ahh...Houuuuu!!!! All sucked in! These are great!
Thank you very much Slime!
Ciao!
Mart
Martin Bélair [MAB]
Montréal, Québec, Canada
bad### [at] hotmail DOT com
Well, I just finished one of my other projects. And now I'm left
wondering. I never really used the sky sphere before. After
reading about it, I suspect that's the wrong way to use these
Dreamscape pics.
What is the best way to use the images?
I am not sure it is the "best way", but it is "my way":
sky_sphere {
image_map {jpeg "sky1.jpg"}
scale 2
translate -1
rotate 70*y
>Dreamscape pics.
> sky_sphere {
> pigment {
> scale 2
> translate -1
> rotate 70*y
Even without testing I can say that doesn't work at all.
The sky backgrounds are (hemi)spherical projections so you have to use
the spherical map type (was it map_type 1?).
However, since they are not spherical projections but hemispherical (only
half of the sphere), this is not enough. You need to create a pigment
from <0,0,0> to <1,1,0> where the upper half consists of the image (and
the lower half has whatever) and then apply a spherical warp.
So it should look something like this (completely untested, so it may
have bugs):
sky_sphere
{ pigment
{ image_map { jpeg "sky1.jpg" once }
scale <1,.5,1> translate y*.5
warp { spherical }
"Warp" <war### [at] tag povray org> a écrit dans le message de
news:3f60975b@news.povray.org...
(only
Actually these sky images are fully spherical, the website just doesn't show
the bottom half(pure black of course) in the previews...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
I see. In that case it's enough to do:
sky_sphere
{ pigment { image_map { jpeg "whatever" map_type 1 } }
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> sky_sphere
Yes, the recent website got me thinking, and creating an image to put on
the background was just what I needed. My camera to create the image
was this:
spherical
location <0,0,0> // position
look_at <0,0,1> // view
angle 360 // horizontal degrees
180 // vertical degrees
And the sky sphere to use the output is this:
sky_sphere {
image_map{ tga "starynight.tga" map_type 1 }
rotate x*-100
(The rotate was needed so that the moon on the sky image was where I
wanted it.)
It was perfect for putting a moon in the sky in my animation, so it
would always be the same angle, no matter where I placed the camera.
Tom A.
