POV-Ray : Newsgroups : povray.general : Image_map on the caps of a cylinder Server Time
12 Jul 2026 10:12:18 EDT (-0400)
  Image_map on the caps of a cylinder (Message 1 to 7 of 7)
Subject: Image_map on the caps of a cylinder
Date: 5 Sep 2003 15:21:11
Message: <3f58e227$1@news.povray.org>
Hiya all....
I'm trying to create a washer shape (difference of 2 cylinders) and I want
to put an image_map on the ends/caps of the cylinder.  POVRay seems to want
to wrap the image_map around the cylinder.  Is there any way around this
problem?
Greg
Subject: Re: Image_map on the caps of a cylinder
Date: 5 Sep 2003 17:11:55
Message: <3f58fc1b@news.povray.org>
> problem?
  One solution which comes to mind is using a disc primitive with the
image mapped onto it (with planar mapping) and putting the disc on the
end of the cylinder (you can make the cylinder open to avoid coincident
surfaces).
Date: 6 Sep 2003 09:50:25
Message: <3f59e621@news.povray.org>
Make a block with the thickness of your washer as one dimension and other
dimensions somewhat larger than the outer diameter of your washer.
Apply the Image map to the block
SCG-intersect this block with your cylinders.
have fun,
Frans.
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:3f58fc1b@news.povray.org...
want
want
> > problem?
> surfaces).
Date: 6 Sep 2003 10:00:22
Message: <3f59e876@news.povray.org>
"Greg Lee" <lee### [at] govonca> wrote in message
news:3f58e227$1@news.povray.org...
> Hiya all....
I want
to want
this
> problem?
Would this work?
cylinder{ 0, z, 0.5
   pigment{ image_map{ jpeg "whatever.jpg" } translate -0.5 }
Alf
Date: 6 Sep 2003 12:24:07
Message: <qg2klvc32i7ulgejtn3g9tlfds46mdeth5@4ax.com>
On Fri, 5 Sep 2003 15:20:35 -0400, "Greg Lee" <lee### [at] govonca> wrote:
>Hiya all....
>problem?
Another way to do it would be to create a cylindrical mesh and map your images
using UVMapper.
Regards
Date: 6 Sep 2003 17:11:23
Message: <lbjklvo64nbtb47ge1rbdnde1jkd3417hl@4ax.com>
On Sat, 06 Sep 2003 17:24:05 +0100, Stephen McAvoy <McA### [at] aolcom> wrote:
>using UVMapper.
I've posted a sample in povray.binaries.animations
Regards
Date: 8 Sep 2003 12:07:02
Message: <3f5ca926@news.povray.org>
Hiya all.....
Thanks for all the info.  I tried Warp's suggestion and it worked like a
charm.  I will keep Stephen's suggestion, as I can see this being useful
with nonstandard face.
Thanks again
Greg
want
want
> > problem?
> surfaces).
