POV-Ray : Newsgroups : povray.general : Writing binary files with POV script Server Time
2 Nov 2026 05:20:39 EST (-0500)
  Writing binary files with POV script (Message 1 to 17 of 17)
Subject: Writing binary files with POV script
Date: 22 Aug 2003 04:35:18
Message: <3f45d5c6$1@news.povray.org>
I would like to generate a df3 file directly from a pov script,
generating it from pigments, a bit like Gilles' makecloud macro. But I
had a look at the documentation, and it seems that you can only output
text to a file.
So I was wondering if there was a trick to do it, and if not, if it's
going to be implemented in some next POVray version.
JC
PS: I know I can generate images with povray and make a df3 file with
some utility, but I already have too much utilities installed and I'd
like to do it in one step.
Subject: Re: Writing binary files with POV script
Date: 22 Aug 2003 04:50:11
Message: <n1mbkv84lo46jhm5o66kjpdlso1ridpfov@4ax.com>
On Fri, 22 Aug 2003 10:35:17 +0200, "JC (Exether)" <no### [at] spamfr> wrote:
> text to a file.
It was discussed a few times. It is not possible to make binary files.
> JC
See text format called extended density_file format at
http://staff.aist.go.jp/r-suzuki/e/povray/iso/df_body.htm
ABX
Date: 22 Aug 2003 04:51:39
Message: <3F45D99B.9A2BD0BB@gmx.de>
> text to a file.
This patch can read text density files.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 22 Aug 2003 07:27:47
Message: <3f45fe33@news.povray.org>
  The reason for this is that due to how POV-Ray (well, actually C)
internally works, you can't write the byte value 0 to a file (any other
value is writable).
  In order to be able to write any byte values (including 0) to a file,
a specialized function would have to be added. Perhaps someone could make
a patch...
  (The reason why 0 is not writable is because in C's string-handling
functions it marks the end of the string. The writing C function will
stop at that point and will not write the 0 nor anything which comes
after it. In order to write raw binary data, a different C function
needs to be used (which is not a string function). There's no feature
in the POV-Ray scripting language which would use such function and
thus this is not possible currently.)
Date: 22 Aug 2003 07:28:56
Message: <3f45fe78@news.povray.org>
By the way, in theory it could be possible to write a DF3 file from
POV-Ray as long as it doesn't contain any 0 byte... :)
Date: 22 Aug 2003 13:35:17
Message: <3F46544F.A3AF6F80@hotmail.com>
> text to a file.
> JC
I suppose that you could use chr() to write the bytes to the file.
John
Date: 22 Aug 2003 14:11:57
Message: <3f465ced$1@news.povray.org>
How about this:
Use the existing file output functions to write
a hex-ASCII version of your file, and then, in
a POV INI file, use the Post_Scene_Command or
Post_Frame_Command directive to execute a
converter app to turn the text into binary form.
Ray Gardener
Daylon Graphics Ltd.
"Heightfield modeling perfected"
http://www.daylongraphics.com
"JC (Exether)" <no### [at] spamfr> wrote in message
news:3f45d5c6$1@news.povray.org...
> text to a file.
> JC
Date: 23 Aug 2003 07:53:31
Message: <Xns93E04FFEDA04CPOVMIKA@204.213.191.226>
"Ray Gardener" <ray### [at] daylongraphicscom> wrote in
news:3f465ced$1@news.povray.org:
> How about this:
> Ray Gardener
>> text to a file.
>> JC
Being from the Unix arena, there is always a way even when it seems
impossible. Bright idea Ray!
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Date: 24 Aug 2003 19:20:41
Message: <3f493f8c.4383761@localhost>
>text to a file.
For years I've been wishing that binary file read/write commands
would be added to povray (I once has a pov-script that was
rendering audio data to a text file.  I ended up writing it as
something like a uuencoded file and then having a separate
program to in turn convert that text file to the wave file).
However, it might is best that vinary I/O not be added.
Consider the ability to have a pov-script that in turn writes
a (binary) .exe file containing a virus?  Or what is to stop
povray from overwriting the system password file, or
command.com?
Date: 24 Aug 2003 19:53:19
Message: <3f494fef$1@news.povray.org>
> command.com?
The very same thing that prevents the text I/O feature of POV
from overwriting command.com with a text file: the inherent
pure-hearted goodness of the POV community. ;)
Date: 24 Aug 2003 20:08:08
Message: <3f49535d@news.povray.org>
> command.com?
  What stops it from doing it now?
  You can easily make a POV-script which overwrites c:\autoexec.bat with
some nasty command. You can make one which overwrites important system
files with 0-sized files (or containing whatever garbage you like).
  Support for binary writing does not add any additional danger which is
not there already.
  And the answer to the question: I/O restrictions.
  (In NT-based and Unix-based systems the OS will probably not allow
overwriting such files, but in older Windows systems it's very possible.)
Date: 25 Aug 2003 03:50:01
Message: <3f49bfa9$1@news.povray.org>
I understand that it is not possible with the current primitives due to
that fact that they are text primitives. Still, I think that it would be
interesting to have this possibility with extra primitives (like a
POV-script write_char/read_char accepting any byte value). I spoke of
DF3 files because that's what I had in mind, but there is plenty of
examples where this could be usefull, like model conversion from pov to
any other utility for example audio files and so on (pov-guys
imagination is endless it seems).
There's always the possibility to run an extra converter program but it
would be so nicer to have this built-in. I hope it will be possible in
some future version of our beloved POVRAY.  :-)
JC
>>text to a file.
>>JC
> ABX
Date: 25 Aug 2003 08:53:55
Message: <3f4a06e3@news.povray.org>
> text to a file.
What about endianess?  Maybe the first byte or something could be used
to record the endianess used so that the data could be swapped if needed.
Brendan
Date: 25 Aug 2003 11:03:26
Message: <3f4a253e$1@news.povray.org>
In article <3f4a06e3@news.povray.org> , Brendan Ryan <bjr### [at] ritedu>
>> text to a file.
Nothing.  It does not matter.
    Thorsten
e-mail: tho### [at] trfde
Date: 26 Aug 2003 03:00:59
Message: <3f4b05ab@news.povray.org>
Well, endianess can be taken into account by the primitives, you can
have primitives outputing 4 bytes integers or IEEE floats so that you
don't have to care about endianess. There could be a variable to give
endianess of the machine too.
JC
>> text to a file.
> Brendan
Date: 26 Aug 2003 14:22:37
Message: <3f4ba56d@news.povray.org>
In article <3f4b05ab@news.povray.org> , "JC (Exether)" <no### [at] spamfr> wrote:
>>> text to a file.
As said, to create df3 files, you don't need to know anything about
endianess.
    Thorsten
Date: 28 Aug 2003 18:53:33
Message: <3f4e5563.13380919@localhost>
I had forgotten all about that.  :D
