POV-Ray : Newsgroups : povray.general : What is news.povray.org trying to do? Server Time
17 Aug 2025 05:14:10 EDT (-0400)
  What is news.povray.org trying to do? (Message 1 to 4 of 4)
Subject: What is news.povray.org trying to do?
Date: 5 Aug 2003 19:06:51
Message: <3f30388b$1@news.povray.org>
Has anyone experienced this? Some time after I've checked the newsgroups
on news.povray.org (up to an hour later), ZoneAlarm detects that
news.povray.org (204.213.191.226) tries to access ports 1070 and 1066
(and several others, but those are the only two in my current log) on my
computer. None of the port lists I've checked with mention that these
ports are assigned to anything. I'm using Netscape 7.1 (although I
believe that this happened with earlier versions - 4.78 and 7.0 - I
bypassed 6.0) and it seems to happen only if I keep Netscape running. As
long as ZoneAlarm blocks the access, I'm not too worried, but I am
curious as to what is going on.
Subject: Re: What is news.povray.org trying to do?
Date: 5 Aug 2003 23:11:53
Message: <Xns93CEEBF752FD1None@204.213.191.226>
Tim Riley <tim### [at] netscapenet> wrote in news:3f30388b$1
@news.povray.org:
Probably just the news server timing out your connection.  Some news
servers have a default timeout of one hour.
When you connect as a client to a news server (or any other server for that
matter), your PC picks an available port to which the server can send data.
You connect to a server's service port, but to send data back to you, the
server needs a client port to send it to.  These client ports are
arbitrary.  So while you might connect to the nntp port (119, I think) on
the server, the server sends you back data on an available port selected by
your PC (usually higher than 1023 (the "well known ports")).
Date: 6 Aug 2003 07:15:09
Message: <3f30e33d$1@news.povray.org>
In article <3f30388b$1@news.povray.org> , Tim Riley
> computer.
You connected to the sever and left the connection open.  It is about to be
closed by the server because your client is blocking that server resource
for too long without doing anything (not nice).  So the server you are
connected to has to tell your client that the connection will be terminated.
ZoneAlarm just picks this up and generates a false message.  Report it as a
bug to the developers of ZoneAlarm.  It should not report such things
because they are simply the proper way to end a connection that was left
open.
    Thorsten
e-mail: tho### [at] trfde
Date: 6 Aug 2003 12:08:16
Message: <3f3127f0@news.povray.org>
> open.
Makes sense, however, I don't see the same thing from any of the other
news servers I frequent. Maybe they don't time-out, or their time-out
values are longer than I'm on the computer. I don't think that it is a
bug in ZoneAlarm. It doesn't try to judge the validity of any accesses;
it's up to me to decide what access I want to allow. I'll trust
news.povray.org and put it on ZoneAlarm's trusted list.
Thanks for the reply.
