Tsutomu just sent me this so I thought I'd share.
All are abstract images with code.
http://members.jcom.home.ne.jp/tom3d/pov45/ilpov45e.htm
http://members.jcom.home.ne.jp/tom3d/pov46/ilpov46e.htm
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Subject: Re: Isosurfaces functions by Tsutomu Higo
Date: 1 Aug 2003 15:06:14
Message: <3F2ABA25.37F573BD@gmx.de>
Those look good, similar to some of Friedrich Lohmueller's pictures in
some ways.
Those isosurface functions are not exactly 'easy evening literature' btw -
i usually have to split them into handy chunks before i start to
understand what's going on...
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 1 Aug 2003 17:45:10
Message: <3f2adf66@news.povray.org>
His is one of my favorite websites... very nice mathematical modelling.
Douglas C. Eichenberg
dou### [at] nls net
http://www.getinfo.net/douge
>some ways.
>Christoph
Even you? I don't feel so bad now. While I was looking at these, I was
thinking -- another weekend down the tubes, trying to figure out what makes
them work.
And I was also thinking, another great idea I never would have thought of.
And, another world of possibilities opening up.
(So many thoughts.)
Gilles, thanks for sharing these.
Tsutomu Higo, if you're reading this, really nice stuff. Thanks.
Dave Matthews
Date: 1 Aug 2003 21:55:50
Message: <3f2b1a26@news.povray.org>
Before I even read your response, I was thinking to myself, "It's times like
this when I really wish I was smarter..." ;-)
Most of my isosurface work is based on isoCSG (thank you!) with the various
pigment functions used similar to a normal. For the first time since
graduating from college 12 years ago, I've actually wished I had more than a
math minor.
Jeremy
"Gilles Tran" <tra### [at] inapg inra fr> wrote in news:3f2aa6af$1
@news.povray.org:
Cool stuff on his site, thanks for sharing. I was looking around his
site and found the "Hair" under the "CONNECT%" category. Love it, short
and simple Povray code, yet brilliant for having come up with it. I
wanted to see if it could be easily animated, so I did a short animation
with it (Windows Media):
http://www3.sympatico.ca/4ad/images/HigoHair.wmv
Cool effect! And all I did was put a clock variable on lines 26 and 27
of his "lpcohair.txt" file. Rendered in less than 3 hours for 300 frames
at 512x384.
Source file: http://www.asahi-net.or.jp/~nj2t-hg/ilpov5e.htm
Lines 26 and 27 were modified to:
#declare Xr =Xr+(6+clock*20)*rand(R1);
#declare Yr =Yr+(6+clock*20)*rand(R1);
Tsutomu has a great mathematical mind's eye.
> short and simple Povray code, yet brilliant for having come up with
> it. I wanted to see if it could be easily animated, so I did a short
> animation with it (Windows Media):
Now that is cool!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
"Rick [Kitty5]" <spa### [at] kitty5 com> wrote in news:3f2e0c57$2
@news.povray.org:
> Now that is cool!
Thanks,
Cheers!
"Gilles Tran" <tra### [at] inapg inra fr> wrote in message
news:3f2aa6af$1@news.povray.org...
> G.
> - POV-Ray and Poser computer images
> - Posters
How would I contact him? I also like his work but I need to simplify the
function declarations to make them more accessible. Here is an example of
what I would do with his golden egg rotation sample:
+ start code +
// INT '03.07 / Yellow
// By Tsutomu HIGO URL: http://www.asahi-net.or.jp/~nj2t-hg/
// Modified by David Wallace 8/4/2003
#version 3.5;
global_settings {
max_trace_level 4
assumed_gamma 2.2
location <0.5, 2.2, -0.3>
look_at <-0.3, 0, 0.1>
angle 120
light_source {<600, 550, 50> color rgb <0.8, 0.8, 0.8>}
#declare Rl=1.5;
#declare Rs=0.1;
#declare Diva=32;
#declare Py=0.3;
#declare Pa=2*pi/Diva;
#declare eps = 1e-6;
#declare vsq = function { x*x+y*y+z*z }
#declare ycir = function { Pa*int(acos(x/sqrt(x*x+z*z+eps))/Pa+1/2) }
isosurface {
function {
(pow(x-Rl* cos(ycir(x,y,z)),2)
+pow(z-Rl*z/abs(z+eps)*sin(ycir(x,y,z)),2)
+pow(y-0.3*(int(y/0.3)+0.5),2)-pow(Rs,2))
*(vsq(x,3*y-1.8,z)-1.38*1.38-0.2*cos(25*pi*pow(vsq(x,y-1.38/3-.6,z),2)+pi))
-0.0004
threshold 0
max_gradient 30
contained_by {box {<-Rl-Rs-0.1, -Rs, -Rl-Rs-0.1>, <Rl+Rs+0.1, 1.8,
Rl+Rs+0.1>}}
open
pigment {color rgb <1, 0.8, 0>}
finish {
ambient 0.3
diffuse 0.5
reflection 0.3
specular 1
phong 0.5
brilliance 1
rotate z*-25 rotate y*10
no_shadow
background {color rgb <0, 0.3, 0.4>}
+ end code +
I only added the vsqr and ycir functions to shorten and simplify the final
function, whose render is identical to the original (I checked).
Some of the source files contain an email address, for example lphsdlpn
on the HOSE% page.
Mike Williams
Gentleman of Leisure
Date: 7 Aug 2003 20:25:28
Message: <3f32edf8@news.povray.org>
Yes, that is pretty cool!
A few months ago, in order to make the hair even more realistic, I tried
using a semi-transparent reddish (redhead) pigment, and then merging the
segments (instead of a union). The results were extremely impressive, but
if I recall correctly, it took about 2 days to render.
For certain close-ups of Poser models, I've thought it might nifty to add
some of this type of hair in with the Poser hair, but I've never tried it
myself. Properly placed, that effect might make poser hair become more
realistic, since most people don't have perfect hair. With
semi-transparency (glassy hair), it should even look good with
back-lighting.
Jeremy
